Old 01-05-2014, 03:08 PM   #1
LedfootLarry
Drives: 2003 corvette Z06
!02mm TB on TVS 2300
I have a tvs 2300 on a 402, in a 2003 Z06 vette. It has a fairly large cam ,
243 247 623 623 , 114LS.
I have cathedral heads, afr 245`s.
I just finished install on a 3" exhaust.
I am running an 8 rib with 8" overdrive harmonic, 3.3" snout pulley, and overdrive cog drive.
It is achieving 13lbs boost , and dyno`ed around 650/650.
I am running a 90mm tpis TB now, and want to pulley down to a 2.9",
How much more will I get out of it with a 102mm TB ? Because the 102 as you know wil set me back $1000. all said and done. I had to come to the Camaro side, as hardly any vettes max these set-ups out TIA....Larry
LedfootLarry is offline   Reply With Quote
Old 01-05-2014, 03:15 PM   #2
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
I think I saw about 28 rwhp from my 102. Typical gains are in the 20-30 rwhp with ported inlet.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 01-05-2014, 04:51 PM   #3
STSL
Drives: 2010 ZR1 Camaro
At your power level I would say about 40. And you get get the tb much less than $1000.Awesome heads by the way who recommended those with a Maggie?
STSL is offline   Reply With Quote
Old 01-06-2014, 07:09 PM   #4
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
At about 750 whp a stock LSA throttle body becomes a major restriction. Your 90 is a little bigger. No matter how you mix it, with similar AFR's you need a certain amout of air to make a certain amount of horsepower. The throttle body is one of those items that until it actually becomes a restriction bigger is not necessarily better, for example if 3 cars are racing down a highway that has 3 lanes they will be just as fast as a highway that has 5 lanes. Only when the road is a restriction, less lanes than cars, will it have a major effect on traffic. You may see a few horses by swapping the throttle body at 650 whp but in my opinion you need another 50 whp before it will make much difference. I don't think it is worth the price at this point.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 01-06-2014, 07:21 PM   #5
2010SSRSM6
2010SSRSM6's Avatar
Are you in Ontario, California or the cold one up north? If you are in California, call Ryne or Mike @ Cunningham Motorsports (951) 677-0716 or if you're in Canada, shoot them an e-mail (best way to get in touch with them either way) at sales@cunningham-motorsports.com. They will get you all the info you need and not steer you in the wrong direction.
You can check out their website to see some of what they do. http://www.cunningham-motorsports.com/
Good luck
Old 01-06-2014, 07:34 PM   #6
STSL
At less than $600 and a gain of 35hp-40hp it will be the cheapest HP he can get
Old 01-06-2014, 08:09 PM   #7
jessrayo
Speed Freak
jessrayo's Avatar
Mine cost $1000 and I don't think it will give him more than 20 whp because I don't think the 90 is a restriction at all at 650 whp. Plus the car does not idle as nice with the 102. Just my opinion, but my build is pretty similar to his...
Old 01-06-2014, 08:16 PM   #8
STSL
I have done a ton of Maggie builds and never seen less than 25rwhp and that's 550rwhp cars .The 90 is always a restriction in my testing.We have perfect idle as well that may be in your tune and a 102 can be had for less than $600
Old 01-06-2014, 10:12 PM   #9
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
I'm making 16.5psi on a 2.95" pulley, without a 102mm throttle body. I also have ported heads, 2" headers, big cam, etc. You will be limited by belt slip before the throttle body.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 01-06-2014, 10:19 PM   #10
STSL
So you don't think your car would pick up with a 102?
Old 01-06-2014, 10:22 PM   #11
1sikss
Drives: 2011 camaro ss
whats the most you can port your stock tb for the maggie?
1sikss is offline   Reply With Quote
Old 01-06-2014, 10:23 PM   #12
STSL
Not enuff to do much of anything...The snout will go to 107 pretty easy
Old 01-06-2014, 10:43 PM   #13
1sikss
i see so then you would need a 102 tb dam that gets more expensive lol..
Old 01-06-2014, 10:45 PM   #14
STSL
It never ends LOL..It would be the cheapest HP youll get and it lowers your IATs
