SDTW Custom Wheels & Tires
Old 01-05-2014, 09:38 PM   #15
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Originally Posted by grocerygetter View Post
Gt9 is great for a positive displacement blower. I got it verbatim from LPE not to use that cam with a centrifugal. In a nutshell it has to do with the boost curve of pd vs centri. Much better cam choices out there for a centri.
I'm sure I could have spec'd as custom cam for my setup, but the GT9 is working great with my D1SC. I especially like the wide LSA for my automatic. Of course, my boost curve is different from other centris because of my wastegate.
For the OP, I added my GT9 before I added the blower, when I was full bolt-ons. I gained 50rwhp. FWIW.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 01-05-2014, 09:41 PM   #16
Bubble85
Drives: 2012 SS
Thanks padre
Bubble85 is offline   Reply With Quote
Old 01-05-2014, 09:47 PM   #17
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
Spoke with Ryan @ LPE directly when I was researching. They said almost verbatim:
"The GT9 cam was specifically designed for the TVS 2300 blower and has hundreds of hours of testing put into it to get it just right."
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 01-06-2014, 12:22 PM   #18
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
it is also pretty hard on valvetrain parts. it has the lsk lobes.
9.60@144.5
Original motor with 46,000+miles JRE TUNING custom grind cam Whipple A6 NO WEIGHT REDUCTIONS and Drive it to the track
94guy is offline   Reply With Quote
Old 01-06-2014, 12:24 PM   #19
Bubble85
Drives: 2012 SS
Called lpe I was told that the gt9 cam is fine for centri and if they were building that's what they would use. They also said I should only expect to see 30-35 rwhp gain
Old 01-06-2014, 03:01 PM   #20
grocerygetter
instigator
grocerygetter's Avatar
You may have got some random tech. The guy I talked to said out of the LPE line to use the GT11. After doing my own research the GT11 isn't bad, but still not optimal for boost. The GT9 is optimal for boost...but it is specifically made for the roots blowers.
If you can't get 80+whp off a cam on a blower car...look elsewhere. I'm telling ya...with a centri, you are barking up the wrong tree.
I did my research and thus netted 110whp off a cam swap. Trust me here.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 01-06-2014, 03:02 PM   #21
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
I don't think Ill gain 80hp with my 227/243-114.
Old 01-06-2014, 03:41 PM   #22
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
I was was told it wasn't the best for centrifugal blowers. After looking around I thought I would look into testing on what a gm cam can make. I'm going to try to make 780-800 rwhp on corn.
Trob85 is offline   Reply With Quote
Old 01-07-2014, 12:04 PM   #23
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Bo, I gained 90 rwhp with a smaller but very similar cam to yours 227/239-115 same lift. I think you will get more out of yours. I also lost a 1 lb of boost
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 01-07-2014, 12:11 PM   #24
Bo White
Bo White's Avatar
Like I said I don't think I'll gain 80 lol, jk.
As long as I'm 650rwhp on the dynos local to me I'm good. Anything more than that is just icing on the cake.
I'm expecting some loss in boost. I've ported enough cylinder heads for boosted cars to see that happen, its no biggie on that end.
Old 01-07-2014, 12:14 PM   #25
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
Better cams out there. Get someone to cut you a custom grind for your car. Doesn't cost much more or get a proven centri cam.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 01-07-2014, 12:36 PM   #26
Bo White
Bo White's Avatar
The reason I went with the cam I bought was because one of the fastest G8s in the country had this cam and a procharger. It also sounded awesome lol.
Old 01-07-2014, 01:45 PM   #27
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Who might that be?
ECS Novi 1500 supercharger, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 10.41@133mph
bct10985 is offline   Reply With Quote
Old 01-07-2014, 02:16 PM   #28
Bo White
Bo White's Avatar
