Cold Air Inductions
Old 01-15-2014, 05:10 PM   #1
Threlkeld's SS
Threlkeld's SS's Avatar
Drives: 2010 camaro ss
Joe gibbs ls3 v. Amsoil v. Redline
Im getting ready to cam my car within the next month or so but im due for an oil change now so my question is which do i go with and how long does each of these normally last. oh and i have a ls3 if that matters.
Threlkeld's SS is offline   Reply With Quote
Old 01-15-2014, 07:41 PM   #2
AMERICANMADE
Drives: 2010 Camaro SS
Check out the previous post from today "motor oil wear test rankings" there are 129 oils ranked per the wear test explained in the attached article. I believe all three of your oils are listed. Decide for yourself if you feel the testing has merit.
AMERICANMADE is offline   Reply With Quote
Old 01-15-2014, 09:35 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
How many miles do you have on your oil now? If you KNOW you're going to do the cam change in the next month or so, i'd just wait. No since in spending $80 on a oil change now, just to empty it all out for the cam swap.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-15-2014, 09:54 PM   #4
Threlkeld's SS
That's my delima and right at 5k. My dic says around 26%
Old 01-15-2014, 10:12 PM   #5
axis
Search Ninja
axis's Avatar
5k on good synthetic oil is NOTHING. You do know that the better synthetics are good for well over 15k miles? That does depend on how you drive it but in general, it's good for a lot longer than most think. If you're one of those people that are anal about changing their oil after 5k miles, then by all means change it so you can sleep at night. If you asking if your engine is going to explode by not changing till your cam swap, you'll be absolutely fine.
Halltech CF 102 fed
Old 01-15-2014, 10:15 PM   #6
Threlkeld's SS
Yea I used royal purple but I didn't know if was good for that long lol
Old 01-15-2014, 10:18 PM   #7
axis
Search Ninja
axis's Avatar
Oh yeah, you'll be fine.
Halltech CF 102 fed
