Solo Performance
Old 01-15-2014, 10:48 PM   #1
Shady4
Drives: 2010 Camaro SS/RS
Drone strikes again
Hey guys,
I have LT headers, highflow cats, magnaflow tru x pipe, and borla s-type mufflers and ever since I added the x pipe the drone has been horrible. Before I was able to cope with it just slightly coming in around 1600rpm's but now its so much worse at around the same rpms.
I've heard of ways like installing a J pipe to eliminate the drone effect and was wondering what your guys' thoughts were about it, how much it cost you, or if anything else has worked for you.
Thank you!
2010 SS/RS L99
1 7/8 LT with high flow cats, Magnaflow tru X Pipe, K&N CAI.
Shady4 is offline   Reply With Quote
Old 01-15-2014, 11:14 PM   #2
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Curious, why did you go x pipe?
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 01-15-2014, 11:55 PM   #3
Shady4
I wanted to do the resonator delete on my l99 and read that x pipe was a good choice for a tiny bit extra HP and torque.
2010 SS/RS L99
Old 01-16-2014, 12:27 AM   #4
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
The J pipe will remove drone if done properly. Our stock muffler is basically straight pipe with a j pipe. I would assume that the j would need to go downstream the borla to effectively remove drone. Hopefully someone has done this with your setup or similar and can confirm, but it seems like common sense to me based on the stock muffler downstream from the resonator.
Old 01-16-2014, 12:44 AM   #5
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Found this old thread with great info. This guy made j pipes upstream some glasspacks (I think) :\
http://www.camaro5.com/forums/showth...ight=helmholtz
Old 01-16-2014, 03:39 AM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
You could switch to a resonated X pipe and get it back to where you were.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-16-2014, 06:07 AM   #7
Mwalterhouse
Mwalterhouse's Avatar
Drives: 2010 Camaro SS/RS LS3
Resonated X pipe is the solution.
Mwalterhouse is offline   Reply With Quote
Old 01-16-2014, 07:14 AM   #8
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
This is a pretty effective solution.
Old 01-16-2014, 11:08 AM   #9
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
I did a resonated x pipe on my LS3, with only an outlaw axelback, and did not reduce the drone much at all. J pipes will do it. Get photos of the Solo ones and take to a good muffler shop. They can take two 180 degree sections per side, 2.25" diameter is fine, cut and weld to an S shape to the correct length(you need to give them that, about 28" or so) they cut a hole in your pipes right ahead of the mufflers, they will determine where to fit everything. My guy even fabbed up adjustable end caps so you can change the length depending where the drone is(rpm)
Cost me $150 lot and killed the drone, just exhaust sound now.
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And DSE swaybars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 01-16-2014, 11:27 AM   #10
Birm
Birm's Avatar
Drives: Florida Speed & Power
J Pipes are an excellent option. The Resonated X-didnt do much for me... just my $37 and change.
Birm is offline   Reply With Quote
