Flowmaster Exhaust
Old 01-16-2014, 12:19 AM   #1
ilirg
ilirg's Avatar
Drives: 2011 Camaro 2ss
Lt headers and HF cats mix matching
K, I just purchases a pair of mid pipes from stainless works, do these only work with sw headers or can I go with kooks Lt headers etc.
ilirg is offline   Reply With Quote
Old 01-16-2014, 01:01 AM   #2
B-_-RAD
Banned
Drives: ...
They wont work with kooks or jba, those use bolts and flanges, sw uses slip fit. I may be interested in the mids you have if you dont use them and they are catted.
B-_-RAD is offline   Reply With Quote
Old 01-16-2014, 03:33 AM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
It all depends on how they connect. Kooks are ball and joint, TSP's are slip on, not sure about ARH's or SW's.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-16-2014, 07:17 AM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Afraid not. Like the others have said they use different types of joint connections.
Old 01-16-2014, 07:28 AM   #5
ilirg
ilirg's Avatar
Thanks, no big deal will just go with sw headers
Old 01-16-2014, 07:29 AM   #6
Apex Motorsports
Stainless Works makes a great set of headers. You will be very happy with them.
Old 01-16-2014, 03:00 PM   #7
ilirg
ilirg's Avatar
I'm a little confused. I'm looking at the sw headers, and see there are o2 bungs on the headers, and on the HF cats. The HF cats I have don't have any o2 bungs? Is there something I'm missing?
Old 01-16-2014, 03:05 PM   #8
Jason@Phastek Performance
Jason@Phastek Performance's Avatar
Drives: 2010 Camaro
Send a message via AIM to Jason@Phastek Performance
Those look similar to JBA Cats.
Jason@Phastek Performance is offline   Reply With Quote
Old 01-16-2014, 03:08 PM   #9
Apex Motorsports
There are two O2 sensors on each side. Check out the picture below with the stock components sid-by-side with long tubes and high flow cats.
Old 01-16-2014, 03:19 PM   #10
ilirg
ilirg's Avatar
I see. Damn it looks like the ones I got are made for the sw cat back.
Old 01-16-2014, 04:55 PM   #11
axis
Search Ninja
axis's Avatar
All catted or non catted midpipes will fit with any aftermarket system of the same size. It's the fitment to the header itself that's different.
Halltech CF 102 fed
Old 01-16-2014, 05:00 PM   #12
axis
Search Ninja
axis's Avatar
A lot of cats and offroad pipes don't have the O2 bungs for the rear O2 sensors. All they do is tell the PCM about the efficiency of the cats. They give ZERO feedback for the tuning of the vehicle. Since we're running HFC's or no cats at all, they should be turned off in the tune. This is what throws the cat efficiency code when you run LT's and don't tune. Most just take the rear O2 sensors off and ziptie the pigtails up high.
Halltech CF 102 fed
Old 01-16-2014, 05:16 PM   #13
ilirg
ilirg's Avatar
Oh nice, I was worried that it would be an issue with throwing codes, I didn't even take into account the tune!
Old 01-16-2014, 05:58 PM   #14
axis
Search Ninja
axis's Avatar
If you get a LT tune and the rear sensors are NOT turned off, get a new tuner.
Halltech CF 102 fed
