Old 07-22-2009, 11:56 PM   #1
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
Who else is bouncing off the fuel cut-off?
I'm a bit of an old school racer and I shift gears when I feel the car dropping out of the power band. The problem I am having is that the fuel shut off kicks in before the car runs out of power.
Clearly, there is more power in the LS3 motor past 6,500 rpm. Is it possible to tune the fuel shut off up to 7K?
Hylton is offline   Reply With Quote
Old 07-23-2009, 09:17 AM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
If you have a tune done, At that time it can be done.
Old 07-23-2009, 11:54 AM   #3
gpr
Drives: never fast enough
I would also be curious in this and would like to see someone make a dyno pull out to 7000 rpms, as all dyno runs i have seen the power really hasn't started dropping off at the rpms they shut it down at.
gpr is offline   Reply With Quote
Old 07-23-2009, 11:57 AM   #4
Hylton
Hylton's Avatar
Exactly! When you look at the dyno sheets on here, they all stop the pull when the car is still in the powerband! Consequently, this translates into slower quarter mile times because you cannot shift at the most optimal RPM.
Old 07-23-2009, 12:13 PM   #5
2SSRS@Gen5diy
After looking on some posts on a different forums i think that it is set to 6500 rpm is that the valve springs will not go a lot more and live.
Old 07-23-2009, 12:20 PM   #6
Hylton
Hylton's Avatar
Sounds like an upgrade is in order.....
Old 07-23-2009, 12:32 PM   #7
Robin Lawrence
Robin Lawrence's Avatar
Drives: 2010 Camaro 69 Nova
In stock form the horsepower is falling off before you are feeling it. I have made 30 plus pulls on the dyno in many configurations including head and cam and the power still drops over prior to the 6600 cut off.
Shift sooner, it's faster and a lot easier on parts. Unloading and loading is what causes torsional stresses that break parts.
Robin
Holley Performance Products
Robin Lawrence is offline   Reply With Quote
Old 07-23-2009, 12:46 PM   #8
Hylton
Hylton's Avatar
Robin
But if you powershift the car, you need to be able to run into high rpm in order for the engine to "drop" into the optimum rpm range when the clutch is let out. I know this is not something that can be tested on the dyno but I'm sure you know what I mean.
Old 07-23-2009, 12:52 PM   #9
Robin Lawrence
Hehe, forgot about that 500 to 600 over and the limiter won't allow that.
I have had several stock cammed LS3's on the dyno and with carb intakes they pulled to 6900 RPM. THe valve springs are decent.
Robin
Old 07-23-2009, 12:58 PM   #10
Hylton
Hylton's Avatar
Robin
Cool, thanks! Time to go play with the ECM...
Old 08-19-2009, 03:35 PM   #11
600hp-lpe
Drives: 2010
Lingenfelter makes an electronic shift light.. sounds like you need one.
600hp-lpe is offline   Reply With Quote
Old 08-19-2009, 03:37 PM   #12
Hylton
Hylton's Avatar
What I really need is to move the cut-off up 500 rpm.
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 10:56 PM
Nitrous System ?????s PoleCat2SSRS2010 Forced Induction - V8 29 12-08-2010 06:55 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
Americans unwilling to pay for big fuel economy gains, carmakers say Scotsman General Automotive + Other Cars Discussion 7 04-18-2008 01:27 PM
