BORLA
Old 01-19-2014, 06:12 PM   #1
JDH
SKRPION
JDH's Avatar
Drives: 2013 Camaro 2LT RS
Oil pressure on 2013
I have been watching my oil pressure gauge a lot lately. When I start my Camaro its around 30psi. As I drive sometimes it goes up to 70psi. Only 3400 miles. Only has had 1 dealer oil change. Doesn't seem normal to me. Any ideas?
JDH is offline   Reply With Quote
Old 01-19-2014, 06:35 PM   #2
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
The filter can blow off at 100 psi so no, that doesn't seem normal to me. More details please: LT, SS, mods, type of pressure gauge, etc
...and you're not Jesse D. Halter, are you?
ChrisBlair is offline   Reply With Quote
Old 01-19-2014, 06:40 PM   #3
mikeyg36
Drives: 2015 Z/28 #533
I know the V6 will hit 70 when cold or accelerating. Let me find the thread...
mikeyg36 is offline   Reply With Quote
Old 01-19-2014, 06:42 PM   #4
JDH
SKRPION
JDH's Avatar
2lt RS could it be the oil pressure sensor
Old 01-19-2014, 06:43 PM   #5
mikeyg36
Here you go
http://www.camaro5.com/forums/showthread.php?t=273243
Old 01-19-2014, 06:56 PM   #6
Blue-J
Blue-J's Avatar
Drives: 2013 2LT HWSE
Mine had 5,000 miles last year before being garaged and had your same readings. Similar after first oil change.
Blue-J is offline   Reply With Quote
Old 01-20-2014, 08:40 PM   #7
Chevrolet Customer Svc
Drives: GM Vehicles
JDH,
I understand that you're seeking thoughts and opinions (with several responses already posted), but send me a message if you want to take it a step further and get an official diagnosis. I will then reach out to the dealer's Customer Care Specialist for additional assistance with potentially resolving this at the dealer level.
William R.
Chevrolet Customer Care
Old 01-20-2014, 08:42 PM   #8
AKA-22
AKA-22's Avatar
Drives: ELLE-1
its normal...
AKA-22 is offline   Reply With Quote
Old 01-20-2014, 08:43 PM   #9
AKA-22
AKA-22's Avatar
Drives: ELLE-1
yes, normal there is a gm bullitain somewhere I will look for
#PIP4690D: Normal Characteristic - High Oil Pressure Gauge Readings - (Oct 16, 2012)
Subject:Normal Characteristic - High Oil Pressure Gauge Readings
Models:2010 - 2013 Chevrolet Camaro
Equipped with 3.6L LLT or LFX Engines
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Some owners may comment that the oil pressure gauge is indicating that the engine appears to be operating with very high oil pressure.
Recommendation/Instructions
Under various engine operating conditions 60 psi (413 kpa.) of oil pressure may be displayed on the oil pressure gauge. This should be considered as normal operation. In addition, during a cold engine start-up (especially during cold ambient temperatures) the oil pressure gauge may display at 70 psi (482 kpa.) or all the way to the right. This condition should also be considered as normal operation. As the engine and oil warm up, the gauge should begin to return to approximately 60 psi (413 kpa.).
Important: Because these operating pressures are considered normal operation, no repair attempts or parts should be replaced.
Customer Information
Please communicate to the customer this condition is a normal operating characteristic of their vehicle. This condition will not impact the designed performance or reliability of the vehicle.
Old 01-20-2014, 09:03 PM   #10
cant_get_rite
Drives: 2013 CRT/2LT/RS
Condition/Concern
This...
I have a 2013 2LT. Bought it in August with 29 miles. My gauge did the same thing so I took it in to the dealer. They said it is normal. We even test drove another 2013 with 79 miles and it did the same thing. No worries
cant_get_rite is offline   Reply With Quote
Old 01-20-2014, 10:07 PM   #11
Austin45
The Logistician
Austin45's Avatar
Drives: 2012 LFX 45th Anniversary
My 2LT oil pressure gauge flies everywhere, it's normal. If you notice, at the end of the gauge there isn't a red line. Also, you want variable oil pressure, if it was constant something would be wrong. It's a useless gauge in my opinion.
Austin45 is offline   Reply With Quote
