Old 01-20-2014, 04:11 PM   #1
BigBOSS
BigBOSS's Avatar
Drives: 2010 Camaro 1LT/RS, 6M, IBM
Check Engine Light
P0420 catalyst system low efficiency bank 1
I haven't modified anything on my Camaro in a couple years, the only bolt-on's I have installed are an Airraid CAI and replaced the mufflers. I haven't touched the cats. Over the past month or so I have gotten this CEL code randomly on some days.
Any ideas?
2010 Camaro 1LT/RS
Mods: Staggered 20" Lexani LX15 Wheels, Airraid CAI, AAC Blue LED Dome/Trunk Lights, AAC LED License Plate Lights, AAC LED P13W Running Lights w/Harness, Metra Radio Kit, Kenwood DNX9960 DDIN Radio, JL Audio 10" W6 Sub, JL Audio 500/1 Amp, ******** Sub Box and Amp Rack, AeroExhaust Resonators
BigBOSS is offline   Reply With Quote
Old 01-20-2014, 04:19 PM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
How many miles on your car? The driver's side cat could be failing just from use.
Data from the MAF can also cause this code, so I'd also give it a clean!
Old 01-20-2014, 04:37 PM   #3
BigBOSS
BigBOSS's Avatar
It has around 53,500 miles. What would be the correct way of cleaning the MAF without damaging it?
2010 Camaro 1LT/RS
Old 01-20-2014, 04:51 PM   #4
Ventmaster
Ventmaster's Avatar
Pick up a spray can of cleaner at any auto parts store and follow instructions closely (don't hold it too closely to the sensor) and allow to dry before use. Eazy-peazy!
Cat's should be good for at least 100K miles, hopefully the cleaning will do it.
Old 01-20-2014, 04:57 PM   #5
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Do you race the car? This would cause them to foul prematurely.
Old 01-20-2014, 05:15 PM   #6
BigBOSS
BigBOSS's Avatar
Nope. It's my DD.. I'll get on the throttle every once in a while since Austin drivers can be pretty retarded.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
2010 Camaro 1LT/RS
Old 01-20-2014, 05:16 PM   #7
BigBOSS
BigBOSS's Avatar
Mind giving me a link to a product you would recommend?
2010 Camaro 1LT/RS
Old 01-20-2014, 06:28 PM   #8
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Take a look for an exhaust leak. Typically you can see leaks on the camaro since the cars run rich. Look for black carbon streaks on exhaust joints up front. Seen this before on muffler jobs where moving things around resulted in leaks by the manifold and cats.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 01-20-2014, 07:00 PM   #9
Ventmaster
Ventmaster's Avatar
This what I'm currently using- http://shop.advanceautoparts.com/web...-crc_7070079-p
And Nutbutt's right, could be an exhaust leak.
I've heard of a few Camaro owner's stock exhaust manifold gaskets have simply gone bad and starting leaking without provocation.
If this persists, there's always a trip to the dealer to fall back on!
Old 01-21-2014, 08:39 AM   #10
TooCool5
TooCool5's Avatar
That is a pesky code, MAF cleaning is a good start, also torque the exhaust manifold bolts and look for leaks, also fuel injector clean sometimes helps clean the 02's.
Check your glove box manual, the cat is covered under extended warranties.
Old 01-21-2014, 02:41 PM   #11
Flashpoint135
Rev Head
Flashpoint135's Avatar
Drives: 2016 SS
I had the same issue, took it into the dealer and they replaced the cat under warranty. Mine is also a daily driver, >60,000 miles. I have a Cold Air Inductions CAI but stock exhaust.
Flashpoint135 is offline   Reply With Quote
Old 01-21-2014, 03:37 PM   #12
BigBOSS
BigBOSS's Avatar
Is the cat covered under the 100,000 mile powertrain warranty? How many years does that come with?
I'm at 53,500 miles and have had the car 4.5 years.
2010 Camaro 1LT/RS
Old 01-21-2014, 03:40 PM   #13
The Stig
knows 2 facts about ducks
The Stig's Avatar
Check Engine Light
5 year 100,000 miles I believe. But yes, the catalytic converter is covered under the powertrain warranty.
Click to view my build thread
Old 01-21-2014, 03:43 PM   #14
BigBOSS
BigBOSS's Avatar
Think they would give me shit for having the AIRRAID CAI and different mufflers? I know it depends on the dealer ultimately..
2010 Camaro 1LT/RS
