BeckyD @ James Martin Chevy
Old 01-21-2014, 05:40 PM   #15
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
You could put the stock box back on when you drop it off at the dealer. But as for the exhaust leak. I did not troque my DT shorties, massive leak no CEL. got in a hurry. Then when it warmed up I went back to torque them down.
Old 01-21-2014, 06:00 PM   #16
BigBOSS
BigBOSS's Avatar
Drives: 2010 Camaro 1LT/RS, 6M, IBM
I don't even know if I kept my stock intake lol, no idea where it would be haha. Anyways, I am selling my Camaro soon since I just bought a Ford Raptor, just waiting to hear back from a coworker on whether they want to buy it for their son or I will be selling it to Carmax probably.
I know Carmax typically wants the car stock as far as wheels and stuff but I wonder if they would care about me having the AIRRAID CAID, Metra Kit, and a Kenwood DNX9960. hmmmmm
2010 Camaro 1LT/RS
Mods: Staggered 20" Lexani LX15 Wheels, Airraid CAI, AAC Blue LED Dome/Trunk Lights, AAC LED License Plate Lights, AAC LED P13W Running Lights w/Harness, Metra Radio Kit, Kenwood DNX9960 DDIN Radio, JL Audio 10" W6 Sub, JL Audio 500/1 Amp, ******** Sub Box and Amp Rack, AeroExhaust Resonators
BigBOSS is offline   Reply With Quote
Old 01-22-2014, 09:15 AM   #17
TooCool5
TooCool5's Avatar
Cat warranty is separate from the 5/100.
Old 01-22-2014, 02:23 PM   #18
BigBOSS
BigBOSS's Avatar
What is it then?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
2010 Camaro 1LT/RS
Old 01-26-2014, 08:10 PM   #19
BigBOSS
BigBOSS's Avatar
Ok now today it only showed P0430 bank 2. What the ****?
2010 Camaro 1LT/RS
Old 01-26-2014, 08:22 PM   #20
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Causes for P0430:
No AIR, CKP, CMP, ECT, EVAP, IAT, MAF, MAP, HO2S (Left Bank), Misfire, Fuel Trim (Left Bank), Injector, TP, Transmission or VSS codes set, in closed loop, ECT input over 124°F, VSS from 20-75 mph, throttle angle over 2%, engine speed below 3500 rpm, MAP input 25-80 kPa, MAF input 15-100 g/sec, then the PCM determined the Bank 2 Catalyst had degraded below its threshold.
Have you cleaned the MAF yet?
Old 01-26-2014, 09:34 PM   #21
BigBOSS
BigBOSS's Avatar
Originally Posted by Ventmaster View Post
Causes for P0430:
I removed the maf from the CAI tube today to get a look at it. Not sure exactly what to clean. It's a bunch of plastic with 2 little tiny wires that looked like a bobby pin, which is what I assume I am supposed to clean but it looked fine?
I did pull off the air filter and knocked a bunch of junk off of it though thinking maybe the maf wasn't getting enough air. Turned the car on and off a couple times while clearing the fault codes. But each time I scanned for faults it came back
2010 Camaro 1LT/RS
Old 02-01-2014, 04:32 AM   #22
danyell123
Drives: white corolla xli
if you want to get good camaro parts on any other type of car parts then you must visit this http://www.amcarparts.co.uk/engine/list.html I will must say your problem will must be solve when you may get good parts.
danyell123 is offline   Reply With Quote
Old 02-01-2014, 10:41 AM   #23
shrinkdoc
Drives: SRT Yugo GT Super Sport with Manual
This what I'm currently using- http://shop.advanceautoparts.com/web...-crc_7070079-p
And Nutbutt's right, could be an exhaust leak.
I've heard of a few Camaro owner's stock exhaust manifold gaskets have simply gone bad and starting leaking without provocation.
If this persists, there's always a trip to the dealer to fall back on!
I cleaned mine yesterday, exactly the one I used.
shrinkdoc is offline   Reply With Quote
Old 02-01-2014, 11:50 AM   #24
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Easy maintenance !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 02-16-2014, 08:59 PM   #25
BigBOSS
BigBOSS's Avatar
Forgot to post back a couple weeks ago but the CEL is gone now. I used the MAF cleaner posted in this thread as well as dumping a can of Seafoam in my tank and driving til nearly empty. Not sure if it was one or the other that solved the problem or the combination of both but it has been gone for 2 weeks now.
Thanks for the suggestion on cleaning the MAF even though when I visually inspected it, it looked 100% clean.
2010 Camaro 1LT/RS
Old 02-16-2014, 10:28 PM   #26
Ventmaster
Ventmaster's Avatar
Thank you for getting back with us. The MAF provides a great deal of info to the ECM and can trigger many issues.
I know there are a few members who routinely (every other oil change) give it a spray on general principle, and report good results!
Old 02-17-2014, 07:20 AM   #27
Nutbutt
Nutbutt's Avatar
Wish more people would return after problem solved to help future problems ! Good to know it worked out
Old 02-19-2014, 12:11 AM   #28
BigBOSS
BigBOSS's Avatar
Well, bad news.. both codes came back tonight. WTF?
2010 Camaro 1LT/RS
