Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 01-22-2014, 06:34 PM   #1
OHIO SPEED
OHIO SPEED's Avatar
Drives: 2010 1LT v6 Twin Turbo
Arrow NEW SUSPENSION Coilovers,Lowering Springs,Track Packs, Bushings on Sale at Ohio-Speed
Ohio-Speed offers Suspension parts from several leading mfg.'s.
We will be adding to this sales list as we will have 100's of great deals in the very near future so check back often.
If there is a part you need just pm us and we will get you the pricing!
(1) 2010 2013 Chevy Camaro SS v6 Energy Suspension Rear Subframe Bushing Set 3-4168G
(2) 2010 2014 Chevy Camaro SS or v6 Front EZ CAM XR (16mm - PAIR)
(3) 2010 2014 Chevy Camaro SS or v6 Rear Camber / Toe Adjustment Kit
(4) 2010 2013 Chevy Camaro v8 v6 Megan Racing Street Series Coilovers
(5) 2010 2013 Chevy Camaro Whiteline Control arm - lower outer bushing (camber correction) W63430
(6) 2012 2013 Chevy Camaro v8 Eibach Front/Rear Anti-Roll/Sway Bar 38162-320
(7) 2010 2011 Chevy Camaro Hotchkis Stage 1 TVS 80115-1
PM for our low pricing with free s/h
Ohio-Speed is your #1 Online Store for High Performance Parts and Show Car Accessories!
https://www.ohio-speed.com/default.aspx
TAKE ADVANTAGE OF OUR LAYAWAY PROGRAM!
OHIO SPEED is offline   Reply With Quote
Old 01-25-2014, 04:39 PM   #2
#1stunner
#1stunner's Avatar
Drives: 2011 syn. green ls
looking to drop my 2011 v6, got anything for that, coilovers or just springs?doesnt matter which.
#1stunner is offline   Reply With Quote
Old 01-27-2014, 05:14 PM   #3
OHIO SPEED
OHIO SPEED's Avatar
Ohio Speed now offers a wide variety of Lowering Springs from the manufacturing leaders in the automotive industry today.
All with FREE S/H
(1) Eibach
(2) Hotchkis
(3) SLP.
AND MANY MORE OPTIONS
PM FOR OUR LOW PRICING WITH FREE S/H
Old 01-28-2014, 06:22 PM   #4
wer2foxs
wer2foxs's Avatar
Drives: 2010 VR SS
All with FREE S/H
(1) BMR
(2) Eibach
(3) Hotchkis
(4) Pfadt
(5) SLP.
Looking for a good price on lowering springs
wer2foxs is offline   Reply With Quote
Old 01-30-2014, 06:08 PM   #5
OHIO SPEED
OHIO SPEED's Avatar
(1) 2010 2014 Chevy Camaro v8 v6 Megan Racing Coilovers MR-CDK-CCA10
FEATURES: Chevy Camaro 2010+
SPRING RATES:
F: 62mm ID; 180mm length; 8 kg/mm
R: 62mm ID; 170mm length; 10 kg/mm
DAMPER SPECS:
F: 130mm stroke; 300mm length; M2 valving code
R: 110mm stroke; 200mm length; PVE-R-01 valving code
- 32 Levels of Damper Force Adjustment
- Rubber Dust Boot
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coil-over damper kits come with 1 year manufacturer-defect warranty.
- Must re-use the factory top hats for this application.
(2) 2010 2014 Chevy Camaro v8 v6 Megan Racing SPEC-RS Coilovers MR-CDK-CCA10-RS
Features:
SPRING RATES:
F: 62mm ID; 180mm length; 8kg/mm
R: 62mm ID; 170mm length; 12kg/mm
DAMPER SPECS:
F: 120mm stroke; 260mm length
R: 100mm stroke; 200mm length
- External Reservoir for additional oil capacity and separate compression adjustment (New feature)
- Rubber Dust Boots
- Dual-Cylinder Design
- Steel front brackets/ Aluminum rear aluminum Brackets
- 32 Levels of Damper Force Adjustable; Separate Compression and Rebound adjustments.
- All Hardware is Included
PM FOR OUR LOW PRICE WITH FREE S/H!
Old 01-31-2014, 04:51 PM   #6
OHIO SPEED
OHIO SPEED's Avatar
Ohio Speed now carries the BC Racing Coilovers for your Chevy Camaro.
2010 2013 Chevy Camaro v8 v6 BC Racing BR Coilovers Front and Rear, #80-62-180-8-V & #110-62-170-10-V
BR model which is perfect for street driving and occasional road course duty.
With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier.
You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in.
All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response.
BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Separate full length height adjustable
- One year warranty
- Rebuildable
Inventory levels change daily and you will be notified of any delays.
Technical
Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
Patented concave lower locking ring, to prevent unseating.
Springs are made of SAE9254 high strength, durable steel.
Compression tested at over 500,000 tires with less than 5% deformation.
T6061 Aluminum utilized in spring locks and seats for high strength and lightweight.
Iron lower brackets on MacPherson struts to ensure rigidity.
Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking.
High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
2 step coating process utilizing nickel and chromium plating to prevent corrosion.
Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation.
An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself.
Does not include strut top bushings.
2010 2013 Chevy Camaro v8 v6 BC Racing ER Coilovers Front and Rear Q-04ER
BC Racing's newest and most advanced model yet is the ER series coilover for the 2010+ Camaro.
It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design.
The external reservoirs hold much more oil than the conventional coilover, allowing the coilover to operate for a much longer period of time before overheating.
The external reservoirs also house the secondary piston, which allows for the fine tuning of compression.
This is the perfect coilover system for the person who wants to fine tune their setup using the separate, 30-way, rebound and compression tuning dials.
52mm Mono-Tube Shocks
External Reservoir Mono-tube shock design
30 levels of damping force adjustment, adjusts both compression and rebound separately
Twin piston design
One year warranty
Rebuildable
Technical
The enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
PM for our low prices with free s/h!
Old 02-07-2014, 04:17 PM   #7
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now allows you to get your Camaro down!
Chevy Camaro v8 v6 Air Lift Performance Suspension 5" Drop Full Kit Digital 95775
With 5" of drop and all the versatility of air, the Air Lift Performance kit is the best choice for show stance, daily driving AND track performance.
Get the looks you crave with the performance you need!
Give your ride a sleek, new look by lowering it with these Air Lift performance manual adjusting air suspension kits.
They are capable of lowering your ride by up to 4.9 in.
These kits are made with high-quality materials and include shocks, as well as all other parts necessary for a complete installation for your front and rear suspension.
If you want total control over your ride's height, Air Lift performance manual adjusting air suspension kits are the thing for you.
PM for our low price with free s/h!
Old 02-10-2014, 03:31 PM   #8
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now carries the H&R Suspension product line for the Chevy Camaro.
2010 2011 Chevy Camaro v8 H&R Super Sport Spring Set 50778-77
Enhance the look of your vehicle with a reduced fender well gap.
H&R Sport Springs lower the vehicle center of gravity and reduce body roll for better handling.
The progressive spring rate design provides superb ride quality and comfort.
A lower wind resistance signature will make the vehicle more streamlined and improve gas mileage.
If you are only looking to improve one part of your vehicle’s suspension, you cannot go wrong with installing Sport Springs.
Fun to drive, H&R Sport Springs are the number one upgrade for your vehicle.
1.8" Front Drop/ 1.7" Rear Drop
Product Specs
Spring Position Front and rear
Spring Type Coil
Progressive Rate Spring Yes
Bushings Included No
Spring Finish Blue powdercoated
Quantity Sold as a kit.
Old 02-12-2014, 06:39 PM   #9
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now sells the KW Variant 1, Variant 2, Variant 3 and the Clubsport
KW factory pre-set dampening.
The ideal system for customers who like to choose the customer lowering of their vehicles while counting on the extensive driving tests of our experienced engineers who have preset the dampers for the ultimate balance between sporty driving, comfort and safety.
Old 02-15-2014, 03:44 PM   #10
ZuluKilla8
ZuluKilla8's Avatar
Drives: 2010 Camaro 1SS/RS RJT
PM me price for pfadt 1.25 springs for a 13 ss
2010 Camaro SS LS3 Holley Hi-Ram Manifold,Custom grind boost cam,Vortech V-3,10Rib 3.47 Pully Airfilter Pipe Delete, 10 PSI, TSP LT Headers, Flowmaster Outlaws, Alky Control Meth Kit, PFADT 1.25, ZL1 Fuel Pump, DSS 1000HP axles, Mantic ER2 Clutch, Full BMR rear suspension drag pack upgrade. C6 Vette 18 rims with M/T 305 out back. COPO Hood
Race Proven Motorsports tuned
ZuluKilla8 is offline   Reply With Quote
Old 02-20-2014, 04:23 PM   #11
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now offers these Eibach Pro Spacer kits are designed to move the wheel out further into the fenderwell.
15mm, 20mm, 25mm, 25mm Available
They are made from aircraft-quality aluminum and have a corrosion-resistant finish. The spacers come available in different widths for most applications.
Wheel Spacers, Aluminum, 14mm x 1.50 RH Thread, 5 x 4.75 in. Bolt Pattern, Chevy, Pair
Brand:Eibach
Part Type:Wheel Spacers
Product Line:Eibach Pro Spacer Kits
PM for your low price with free s/h!
Old 02-25-2014, 05:52 PM   #12
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed has the Whiteline Rear Differential - Mount Bushing W93356 for Sale!
Rear Diff - mount bushing
Fix annoying differential movement and noises whilst ensuring appropriate differential pinion angles for maximising power transfer to the wheels with Whiteline.
Increased NVH
We carry a full line of Whiteline products.
PM for our price with free s/h!
Old 03-15-2014, 04:54 PM   #13
OHIO SPEED
OHIO SPEED's Avatar
NEW PRODUCT!
Ohio-Speed now carries the Whiteline Suspension product line.
2010 2012 Chevy Camaro Whiteline Front/Rear Sway Bar Kit BCK001
PRODUCT BENEFITS
Whiteline’s complete ‘sway bar vehicle enhancement kit’ boasts a 27mm 3 point adjustable front & 27mm 3 point adjustable rear sway bar plus sway bar links, essential to ‘Activate More Grip’.
NOTES: IMPORTANT
Excl ZL1 models - contains BCF80Z, BCR22XXZ, KLC178 & KLC144 - essential to "Activate more grip"
PM for our low price!
Old 04-05-2014, 05:50 PM   #14
OHIO SPEED
OHIO SPEED's Avatar
Spring savings continue on all HOTCHKIS Suspension parts including:
2010 2013 Chevy Camaro Hotchkis Sport Suspension Chassis Max Handle Bars 20104
autocross, camaro, handling, race, suspension
