SDTW Custom Wheels & Tires
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 04-14-2014, 04:26 PM   #15
OHIO SPEED
OHIO SPEED's Avatar
Drives: 2010 1LT v6 Twin Turbo
NEW SUSPENSION Coilovers,Lowering Springs,Track Packs, Bushings on Sale at Ohio-Speed
Ohio-Speed now carries the Razors Edge product line.
2010 2013 Chevy Camaro Razors Edge Bump Steer Kit (pair) 306-5030
Correct Your Bump Steer with this Razors Edge Exclusive Bump Steer Kit that features spherical rod-ends with tapered shafts for a hassle-free installation that requires no drilling of the spindle for fit.
This is not an offset steering rack bushing that the other company offers.
Don't be fooled by this band-aid fix!
Definition: Bump Steer is a change in toe* angle caused by the suspension moving up or down.
Bump Steer is built into the geometry of the suspension and steering system, and has nothing to do with turning the steering wheel.
The effect of Bump Steer is for the wheel to toe-in or toe-out when the suspension moves up or down.
This toe change or ? steering? occurs any time the suspension moves, whether it is from body roll, brake-dive, or hitting a bump in the road.
Bump Steer is undesirable because the suspension is steering the car instead of the driver.
ITEM IS IN STOCK AND READY TO SHIP!!
PM FOR OUR LOW PRICE WITH FREE S/H!
Ohio-Speed is your #1 Online Store for High Performance Parts and Show Car Accessories!
https://www.ohio-speed.com/default.aspx
TAKE ADVANTAGE OF OUR LAYAWAY PROGRAM!
OHIO SPEED is offline   Reply With Quote
Old 04-15-2014, 05:17 PM   #16
OHIO SPEED
OHIO SPEED's Avatar
2010 2014 Chevy Camaro Koni Shock Absorber Front (set of 2) (8750-1105R)-(8750-1105L)
Ohio-Speed now carries the Koni product line.
All new and are individually tailored and engineered to give your car that Koni sports feel.
Koni Shocks give your car a feeling of improved handling and less roll.
The fixed rate damping is based on our years of experience with our sport range of dampers and kits.
The bright orange dampers are sure to look good on any vehicle.
Features
Entry level performance shock absorber
Compliments lower springs
Perfect for OE replacement or vehicle improvement
Non-adjustable
Lifetime Warranty
Price is for a set of 2
2010 2014 Chevy Camaro Koni Shock Absorber Rear (set of 2) 8250-1029
Features
Non-adjustable
Lifetime Warranty
pm for our low price with free s/h!
Old 04-28-2014, 04:33 PM   #17
OHIO SPEED
OHIO SPEED's Avatar
Our ANTI-ROLL Single Sway Bar Kit reduces body roll through increased design stiffness over the stock Sway Bar.
The result: increased handling and cornering grip in any performance-driving situation.
Manufactured from cold-formed, high-strength aircraft-grade steel for precision performance, and finished with a long-lasting red powder coat finish, the ANTI-ROLL Single Sway Bar Kit comes complete with greased urethane bushings for improved responsiveness and all mounting hardware and instructions for easy installation.
Front-Rear 29mm
PM FOR YOUR SAVINGS!
Old 04-30-2014, 04:53 PM   #18
OHIO SPEED
OHIO SPEED's Avatar
2010 2013 Chevy Camaro v8 Eibach Suspension Pro System Plus Lowering Springs Anti-Roll Bars Front and Rear Kit 38144-880
The Eibach PRO-PLUS handling packages include our legendary Eibach PRO-KIT springs along with the matching ANTI-ROLL-KIT Sway Bars.
The Eibach PRO-KIT lowers your car's center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking.
Add the Eibach ANTI-ROLL-KIT Sway Bars - with increased design stiffness over stock Sway Bars - and you get pure, balanced-handling perfection.
With the Eibach PRO-PLUS installed you will immediately experience precise turn-in response, improved handling and cornering grip - in any performance-driving situation.
The Eibach PRO-PLUS works well with both factory or aftermarket performance dampers and shock absorbers.
* Your results may vary. As we have learned from racing and independent testing has proved - lowering your car or truck's ride height also improves your aerodynamic efficiency by forcing more air over the car and less underneath (where most of the drag is found on any vehicle), resulting in higher top speeds on the track and better MPG on the highway.
Front: 1.0 in Rear: 1.0 in
Footnotes: Front Sway Bar Is Tubular And 2 Way-adjustable/ Rear Sway Bar Is Tubular And 3 Way-adjustable.
2010 2013 Chevy Camaro v6 Eibach Pro System Plus Lowering Springs Anti-Roll Bars Front and Rear Kit 38143-880
Front: 1.0 in
Rear: 1.3 in
Performance Springs and Sway Bars = Superior Handling for the Serious Enthusiast
Stop Quicker, Corner Faster and Better MPG!*
Simple Bolt-On, No Modifications: Install, Set the Alignment and Carve
Million Mile Warranty
Old 05-05-2014, 04:44 PM   #19
OHIO SPEED
OHIO SPEED's Avatar
2010 2013 Chevy Camaro QA1 Sway Bar Set (Front 1" Rear 7/8") 3-Hole Adjustable (52813-52814) 52815
Designed in the USA with the latest technology and the most durable materials, QA1 sway bars afford improved handling and control by reducing body roll.
They are manufactured from lightweight 4130 chromoly steel and 1045 cold-formed steel with a gloss black powdercoated finish for maximum strength, endurance, and corrosion resistance.
The QA1 sway bars are precision CNC-formed, ensuring proper mounting in the stock location for a true bolt-on installation.
These bars also feature adjustable end links to customize roll stiffness to your personal specifications.
These sway bars from QA1 include greasable graphite polyurethane bushings, along with high-quality zinc plated hardware.
They are designed and road-tested to give your ride the grip that it needs to hold the road.
Position:Front and rear
Front Sway Bar Type:Hollow
Rear Sway Bar Type:Solid
Front Sway Bar Diameter (in):1.000 in.
Front Sway Bar Diameter (mm):25.00mm
Rear Sway Bar Diameter (in):0.875 in.
Rear Sway Bar Diameter (mm):22.00mm
Mounting Hardware Included:Yes
Sway Bar Finish:Black powdercoated
Sway Bar Material:4130 chromoly front/Steel rear
Quantity:Sold as a kit.
PM for our low price with free s/h!
Old 05-14-2014, 08:33 PM   #20
Raysmaro
Raysmaro's Avatar
Drives: 2012 45th Anniversary Camaro
Can you PM me a price for the lowering springs on a V6.
Raysmaro is offline   Reply With Quote
Old 05-21-2014, 05:52 PM   #21
OHIO SPEED
OHIO SPEED's Avatar
2010 2011 Chevy Camaro Hotchkis Sport Suspension Stage 2 TVS Track Pack 80116
The Hotchkis Sport Suspension Track Pack for the 2010 Camaro offers a sleek lowered stance, dramatically improved handling and superior driver control.
Our engineers poured over track testing data to develop a balanced handling system that is comfortable enough for the street but well balanced for the occasional track day or your favorite twisty road.
The system includes Sport springs that lower ride height 1-inch with a higher rate for superior performance, paired with front and rear lightweight adjustable sway bars and a unique aluminum chassis brace manufactured out of elliptical aluminum tubing for superior strength and ground clearance.
All components are manufactured in the USA, come with complete hardware, greasable bushings and are finished off in a durable powdercoat finish. This bolt on upgrade can transform your Camaro into a canyon carver in minutes.
Features:
•Tuned, Balanced System combines sport springs adjustable sway bars, and aluminum chassis bracing
•Sport Coil Springs, Front 210lbs/in, Rear 440 lbs/in, 1" Lowered Stance
•Lightweight 1.25" tubular front and 1" adjustable rear sway bars.
•Includes greasable polyurethane bushings, and mounts.
•Strong lightweight aluminum chassis brace reduces sub-frame flex and wheel hop.
•Durable, gloss powder coat finish.
•Direct bolt- on installation
Benefits:
•Reduces body roll, improving handling performance and drivability.
•Reduced sub frame flex, and wheel hop.
•Sleek, lowered stance with sporty, yet comfortable ride
•Improves steering response and cornering ability.
•Allows suspension tuning for optimum track or street performance.
•Contains all necessary mounting and bushings
•Bolt-In installation no vehicle modifications.
PM for our low price!
Old 05-27-2014, 04:47 PM   #22
OHIO SPEED
OHIO SPEED's Avatar
2010 2011 Chevy Camaro Hotchkis Stage 3 TVS Race Pack 80117
Lightweight 1.25” tubular front bar. 210% stiffer than stock SS
Lightweight 1 3/8” adjustable tubular rear bar +500,630,800% stiffer than stock SS
Greasable polyurethane bushings, mounts.
End links feature highest quality 3-piece PTFE lined heim joints with high articulation spacers and CNC machined aluminum Sleeves with wrench flats.
1” Lowered sport coil springs with high performance rates, F.210lbs/in, R.440 lbs/in
Chassis Max Strut Brace designed to clear Magnuson supercharger systems.
Chassis Max underbody brace, manufactured from Hotchkis exclusive, extruded aluminum arrow tubing.
All Necessary Grade 10.9 hardware
Designed for maximum performance 5th Gen Camaros headed for autocross and track days, the Hotchkis Sport Suspension Race Pack is a tuned, balanced complete suspension solution for the Gen 5 Camaro.
Born on the track and engineered for razor-sharp handling performance, the Race Pack improves steering response and stability, eliminates understeer and subframe movement and allows for precise driver control.
Starting up front, the system includes a strong, lightweight Strut Tower Brace designed to clear Magnuson super chargers. To improve vehicle feel and offer a more aggressive stance, 1” lowered coil sport springs with performance rates are utilized.
To control body roll, Hotchkis Competition Sway Bars are included; a high-strength tubular 1.25” front bar and three-way adjustable 1.375” rear bar allow you to dial-in the way the car responds to throttle steer and driver input. High quality 3-piece lined end links are included for both front and rear.
The Hotchkis Chassis Max undercar brace, ties the rear sub frame to the uni-body, reducing wheel hop and subframe movement.
This brace features Hotchkis exclusive aerodynamic extruded aluminum tubing for maximum weight savings and excellent ground clearance.
All necessary hardware and complete installation instructions are included.
Application Guide:
10-11 Chevrolet Camaro
Old 06-06-2014, 05:01 PM   #23
OHIO SPEED
OHIO SPEED's Avatar
2010 2014 Chevy Camaro SS or v6 Front EZ CAM XR (16mm - PAIR) 81280
2010 2014 Chevy Camaro SS or v6 Rear Camber / Toe Adjustment Kit 87430
Old 06-09-2014, 09:36 PM   #24
NSCRFN3
NSCRFN3's Avatar
Drives: 2010 Camaro RJT 2SS/RS M6
Just ordered a set of coil overs. Can't wait to get 'em!
NSCRFN3 is offline   Reply With Quote
Old 06-12-2014, 05:50 PM   #25
OHIO SPEED
OHIO SPEED's Avatar
2010 2013 Chevy Camaro LT LS v6 3.6L Eibach Pro Street S Coilover Kit (Height Adjustable Only) 38144-711
High Performance, Eibach Tuned Coil-Overs.
Quick - Adjustable Lowering.
Optimal Tuning for Aggressive Performance.
One-Year Warranty.
Now, using the very same Eibach technology used in the latest Formula 1 car, you can get each corner of your vehicle looking and performing its very best.
Eibach's exciting new PRO-STREET-S, stainless steel bodied coil-over spring & damper packages let serious drivers quickly adjust the ride height of each individual wheel.
Eibach ERS Racing Springs and ERD Racing Dampers are used in top-level racing series all over the world.
We have used this experience, gained from many decades at the highest levels of International Motorsport, including Formula 1, NASCAR, CART, IRL, Super Touring Car and the World Rally Championship, to now put these technological masterpieces into the hands of performance enthusiasts everywhere.
Front: 0.0" - 2.0"
Rear: 0.0" - 2.4"
Old 06-14-2014, 09:17 AM   #26
NSCRFN3
NSCRFN3's Avatar
WOW! Got them yesterday! Was not expecting them this quick at all. Website said 7-10 days. Under promise and over deliver....that's what I'm talking about! lol They look great! Will check back when I get them put on soon! Thanks Jim!
Old 06-28-2014, 05:51 AM   #27
X25
X25's Avatar
Drives: '16 C7 Z51
Has anyone tested Megan Racing SPEC-RS Coilovers on track? I am basically in the market for the best affordable coilover for my '15 1LE for both daily driving and extensive track use during the season.
X25 is offline   Reply With Quote
Old 07-02-2014, 05:01 PM   #28
OHIO SPEED
OHIO SPEED's Avatar
2010 2013 Chevy Camaro LT LS v6 3.6L KW V1 Coilover Kit 10261017
Ohio-Speed now sells the KW Variant 1: Sporty - Balanced.
KW factory pre-set dampening.
The ideal system for customers who like to choose the customer lowering of their vehicles while counting on the extensive driving tests of our experienced engineers who have preset the dampers for the ultimate balance between sporty driving, comfort and safety.
KW Coilover Kit V1 Chevrolet Camaro
Lowering
Front Lowering: 0.9" to 2.0"
Rear Lowering: 0.8" to 2.0"
Notes
1: Front and rear height adjustable by threaded shock bodies
autocross, camaro, handling, race, suspension
