Emblempros
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 01-23-2014, 04:14 PM   #1
OHIO SPEED
OHIO SPEED's Avatar
Drives: 2010 1LT v6 Twin Turbo
Arrow NEW Brake Kits, Rotors, Pads, Stainless Steel Lines New Parts Added Daily
Ohio-Speed offers all brake components from the leaders in the automotive industry.
We carry a large selection of high quality parts.
We will be adding to this sales list as we will have 100's of great deals in the very near future so check back often.
If there is a part you need just pm us and we will get you the pricing!
(1) 2010 2012 Chevy Camaro SS v8 StopTech Big Brake Kit 6 Piston Front Red 83.192.6700.71
(2) 2010 2013 Chevy Camaro V6 Baer DecelaRotor Brake Rotors 55174-020
(3) 2010 2014 Chevy Camaro v8 SSBC Big Bite Cross Drilled/Slotted Rotor Rear LH 23900AA3L
(4) 2010 2013 Chevy Camaro SS v8 Russell Performance Street Legal Brake Line Kit Stainless Steel (Front-Rear) 692380
(5) EBC RedStuff Sport Brake Pads (Front) DP31764C
(6) 2010 2013 Chevy Camaro SS v8 Hawk Performance DTC 70 Brake Pads (Front) HB122U.710
(7) Motul 660 Brake Fluid 101667
PM for our low prices with free s/h
Ohio-Speed is your #1 Online Store for High Performance Parts and Show Car Accessories!
https://www.ohio-speed.com/default.aspx
TAKE ADVANTAGE OF OUR LAYAWAY PROGRAM!
OHIO SPEED is offline   Reply With Quote
Old 01-25-2014, 03:27 PM   #2
OHIO SPEED
OHIO SPEED's Avatar
Brake Kits, Rotors, Pads, Stainless Lines For Sale New Parts Added Daily
Ohio-Speed has great pricing on Granatelli Brake Rotors with FREE S/H!
(8) 2010 2012 Chevy Camaro v8 6.2L Granatelli Slotted/Dimpled Rotors (set-4 black oxide) 467-500060
Pm for your pricing
Old 01-27-2014, 04:19 PM   #3
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now offers these Camaro V6 DecelaRotor Brake Rotors:
Baer Drilled and Slotted DecelaRotor Performance Brake Rotors for the Camaro V6
These Baer DecelaRotors are a perfect replacement brake rotor for the OEM rotors on the Camaro V6.
Every DecelaRotor features combination slotted/cross drilled patterns and rust and heat resistant zinc coating for long term performance and durability.
Baer DecelaRotors for the Camaro fit perfectly, look great, and help bring your Camaro to a stop sooner and shorter.
These brake rotors provide great braking without breaking the bank.
PM for our low price with FREE S/H!
Old 01-28-2014, 04:11 PM   #4
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now carries for the serious road racer the ultimate in brake pads!
(1) Chevy Camaro SS v8 EBC Orangestuff Race Brake Pads Front DP91210
(2) Chevy Camaro SS v8 EBC Orangestuff Race Brake Pads Rear DP91788
EBC Orangestuff Brake Pads
Special Orangestuff Track Compound
Longer Pad Wear Life by up to 40-60%
Heat Schorched to help pre-bed the pad for quicker break-in time
Great Cold Friction Characteristics
Deep V-Grooves vent in cooler air to give dust and debris a place to escape
Great Brake Fade Resistance when Temperatures Start to Climb
Track Only Material, Not for Street Use
Race Brakes for the Track!
The EBC Orangestuff Brake Pads were formulated for scrubbing off speed on the track. EBC has perfected the compound for extreme track use The high friction material used in the Orangestuff brake pad has been designed to deliver high amounts of cold braking power that stays consistent even when braking tempuratures start to increase. EBC Orangestuff also lasts up to 40-60% longer than other pads making them great for hardcore racers.
EBC's Most Powerful Pad Yet
The Orangestuff Brake Pad is EBC's most aggressive pad so far and has amazing braking power for track situations. However this pad is not street legal and due to the nature of the Orangestuff Compound it is not ment for street driving of any kind.
PM for our low price with free s/h!
Old 01-29-2014, 05:07 PM   #5
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now sells EBC 3GD Series dimpled and slotted Sport rotors which are precision-machined using premium-quality castings.
Designed with wide-aperture scraper slots and blind-drilled holes, these 3GD rotors draw cooler air in and reduce temperatures for no brake fade under load.
Plus, their dimpling helps them to avoid stress cracks.
Able to expel dirt, dust, and gases, EBC Sport rotors also maintain flat and parallel pad wear for better pad contact and better braking.
These high performance rotors are available in sporty black anodized or gold anodized finishes that not only look great, but also prevent corrosion.
Enhance the performance and looks of your car with EBC GD Series Sport rotors.
2010 2013 Chevy Camaro LT LS v6 3.6L EBC GD Series Sport Rotors Slotted/Dimpled (Rear Set) GD7518
2010 2013 Chevy Camaro LT LS v6 3.6L EBC GD Series Sport Rotors Slotted/Dimpled (Front Set) GD7521
Old 01-30-2014, 05:14 PM   #6
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed carries the EBC product line for your Chevy Camaro.
(1) EBC RedStuff 3000 Sport Brake Pads (Rear) DP31829C
(2) EBC RedStuff 3000 Sport Brake Pads (Front) DP32014C
These Redstuff 3000 series ceramic brake pads from EBC are made of heavy-duty material for seriously fast road and track combination use.
These are truly impressive, fast road pads for repeated heavy braking.
They have good bite for highway driving and have been pounded on race tracks during development.
They emit far less dust than semimetallic pads and feature EBC Brake-In surface coating, which conditions the rotor surface and accelerates pad bed-in.
They are capable of withstanding limited track day usage. If you are looking for a track pad, try the Yellowstuff pad.
PM FOR OUR LOW PRICES WITH FREE S/H!
Old 01-31-2014, 03:55 PM   #7
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now carries the Butler Built product line for your Chevy Camaro.
Butler Built Brake Duct Single Hose/Black (right-left) - 10.5" x 6.0" x 2.0"
This helps lower the temperature of the rotor.
Mount on left and right side panel and the air will flow directly on the rotor to cool the whole brake system.
For use with 3" Brake duct hose
Sold as a pair
Old 02-04-2014, 03:36 PM   #8
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed has great pricing on R1 Concept Brake Rotors.
Chevy Camaro v8 Premium Cross-Drilled Slotted Rotors (Front Set) PDS.62124
Chevy Camaro v8 Premium Cross-Drilled Slotted Rotors (Rear Set) PDS.62119
Features:
- Cross-Drilled & Slotted Design
- Drilled holes provides maximum air circulation for increased cooling
- Diamond slots reduces debris and prevents pad glazing
- Chamfered holes for increased durability
- Double disc ground finish reduces rotor vibration
- Meets or exceeds OEM standards
- Same Vane count as OEM parts
- Mill balanced ensures long lasting durability
- High Carbon
- Black Electro-Coated for rust protection
- Fitment guaranteed
Old 02-07-2014, 03:23 PM   #9
OHIO SPEED
OHIO SPEED's Avatar
NEW Brake Kits, Rotors, Pads, Stainless Lines For Sale New Parts Added Daily
Ohio-Speed now offers these Chevy Camaro v8-v6 SSBC Big Bite Cross Drilled/Slotted Rotors for Front and Rear.
Precision Drilled holes vent super heated gases, eliminating brake fade.
Precision Turbo slotting maintains a clean pad surface giving you maximum grip and quiet braking.
Quality controlled to ensure every rotor meets and exceeds OE standards.
Improved braking in wet weather driving.
Cooler operating temperatures ensure maximum friction between the pad and rotor for maximum stopping power.
Vehicle Applications
2010 2011 2012 2013 2014 Chevrolet Camaro
Rotor Specs
Diameter: stock
Thickness: stock
Venting: Uni-Directional
Standard Finish
Cross Drilled & Slotted
Bolt Pattern: Stock
Important Information
Minimum wheel size: stock
Old 02-12-2014, 05:43 PM   #10
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now carries the StopTech Product Line.
2010 2014 Chevy Camaro v8 StopTech Powerslot Slotted Brake Rotors (Front Set) pls-hps-combo (Rear set available also)
Stopping Power. Improve your 2010+ Camaro stopping power with a set of Powerslot rotors.
These rotors feature a slotted design that helps evacuate gasses, brake dust, shed heat, and keep the brake pad surface clean.
This design even improves wet weather response in rainy conditions for better stopping power.
The performance and quality you're looking for in Hawk Performance HPS brake pads.
These Hawk Performance HPS brake pads are designed to ensure performance, safety, and quality on the street.
Hawk Performance HPS compound provides advanced braking characteristics to enhance your driving experience.
This unique compound combines the safety and quality of aerospace design with the braking technology of motorsports.
PM for our low prices with free s/h!
Old 02-18-2014, 03:28 PM   #11
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed is having a sale on our Stainless Steel Brake Line Kits
v8 and v6 applications are available
Goodridge G-Stop
Russell
StopTech
Old 02-20-2014, 03:26 PM   #12
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now offers Brake Duct Hose.
3" ID
10 Feet Long
Black
300 degree
PM for your low price with free s/h!
Old 03-15-2014, 03:52 PM   #13
OHIO SPEED
OHIO SPEED's Avatar
SALE CONTINUES!
2010 2012 Chevy Camaro SS v8 6.2L Baer Decelarotor Brake Rotors Front/Rear
55163-020
55175-020
Free s/h!
Old 03-23-2014, 07:24 PM   #14
yellowdreamz
Drives: 2013 IFO ZL1
PM me pricing for stainless brake lines for ZL1 and 3 qts Motul 660.......
yellowdreamz is offline   Reply With Quote
brakes, camaro, pads, rotors, stainless steel lines
