Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Exterior Parts & Accessories
Old 01-24-2014, 06:34 PM   #1
OHIO SPEED
OHIO SPEED's Avatar
Drives: 2010 1LT v6 Twin Turbo
Arrow NEW EXTERIOR Hoods, Spoilers, Body Kits, Splitters New Parts Added Daily
OHIO SPEED is having a Sale on All Exterior Parts for your camaro.
We will be adding to this sales list as we will have 100's of great deals!
If there is a part you need just pm us and we will get you the pricing!
(1) 2010 2013 Chevy Camaro v8 SS v6 LT LS COPO Style 4" Bolt On Hood Reverse Cowl
(2) 2010 2014 Chevy Camaro SS v8 6.2L Razzi 4 pc. Body Kit (unpainted)
(3) Ohio-Speed now carries the 3DCarbon product line for the Chevy Camaro.
The styling kit is available as a 4, 5, 6, or 7 piece kit with several accessories that may be purchased separately, including front fender vents, rear window trim and a rear spoiler.
PM for our low prices
Ohio-Speed is your #1 Online Store for High Performance Parts and Show Car Accessories!
https://www.ohio-speed.com/default.aspx
TAKE ADVANTAGE OF OUR LAYAWAY PROGRAM!
OHIO SPEED is offline   Reply With Quote
Old 01-25-2014, 04:40 PM   #2
OHIO SPEED
OHIO SPEED's Avatar
EXTERIOR Hoods, Spoilers, Body Kits, Badging-Parts for Sale! New Parts Added Daily
Ohio-Speed has the best prices on this Clear Bra Alternative!
2010 2014 Chevy Camaro v8 v6 Z28 ZL1 1LE SS RS LT LS 45th Front Nose Mask-Bra.
The Front Nose Mask (Bra) Is a Blend of Nylon and Lycra.
This provides a durable and breathable material that can protect the paint surface while not damaging the clear coat finish.
Better than vinyl or leather
Cheaper than 3M film or a new paint job
Easy 20 minute initial hardware install with no drilling
Can be installed or removed in less than 5 minutes
Will not loosen up and will always maintain a perfect fit tight fit
Easy cleaning with soap and water
1 year manufacturer warranty
MIRROR COVERS ALSO AVAILABLE ADDITIONAL 59.95
Fits all v8 models with/without GM front ground effects
Fits all v6 models with/without STILLEN front chin splitter (shown)
GREAT FOR KEEPING THE DIRT AND BUGS OFF THE FRONT WHILE ON YOUR WAY TO A CAR SHOW OR YOUR FUN FILLED VACATION!
PM for our low price with free s/h
Old 01-27-2014, 05:26 PM   #3
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now sells the Front Tow Hook for the 5th generation Camaro.
The tow hooks are laser cut using a High Definition Laser Cutter for near perfect dimensions with 3/16th thick hot rolled steel.
The tow eyelet is 2 inch per most GCR (General Competition Rules)
This is a must for all track day and drag race Camaro owners!
As the 2010 + Camaro does not have a designated or detachable tow hook like some European cars, it is common to have issues when trying to pull the car if anything where to happen.
The tow hook can be either bolted in, or welded (preferred) and comes in either Red or Black Powdercoat or in a primer so it can be painted to match.
PM for our price with FREE S/H!
Old 01-28-2014, 05:16 PM   #4
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now carries for the 2010 2014 Chevy Camaro v8 v6 Locking Fuel Cap!
Deter fuel theft and vandalism with a locking gas cap! OEM-quality construction and materials and a famous maker lock cylinder with two keys.
PM for our low price with free s/h!
Old 01-29-2014, 06:11 PM   #5
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed offers the ACS T4 Splitter which is latest product driven by enthusiast demand. The composite T4 Splitter will install on all Camaro SS front fascias and WILL NOT lower the vehicle's ride height. Mounts’ using a series of supplied mechanical fasteners and does not require the front fascia to be removed. Installation time is under 15 minutes.
The easiest splitter installation currently offered on the market. Given it won't alter the ride height, it is the most durable in addition to its complete belly pan to cover the under surface of the SS fascia. Protect your OEM paint while improving airflow of the frontal area of your Camaro.
Part comes prepped and primed in with all the required hardware and instructions.
Old 01-29-2014, 06:27 PM   #6
Supercharged SS
Drives: 2010 Camaro
If you want the best customer service around order from Jim!!
Old 01-30-2014, 06:20 PM   #7
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now carries the ACS T5 Splitter which is the latest product driven by enthusiast demand.
The composite T5 Splitter will install on all Camaro ls, Lt, RS, V6 front fascias and WILL NOT lower the vehicle's ride height.
Given it won't alter the ride height, it is the most durable in addition to its complete belly pan to cover the under surface of the Camaro V6 fascia.
PM FOR OUR LOW PRICE WITH FREE S/H!
Old 01-31-2014, 05:02 PM   #8
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now offers a Do-It-Yourself LED Sidemarker Kit.
2 = Amber 40ct. Arrays
2 = Red 40ct. Arrays
American made and mfg. Lifetime warranty against LED failure.
Do it yourself and save big!
100% USA Custom made per order.
Old 02-01-2014, 04:38 PM   #9
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed is having a HUGE SALE on Razzi Side Skirts and our price can't be beat!
2010 2013 Chevy Camaro v8 v6 Razzi Side Skirts (unpainted-2)
RAZZI® Ground Effects Packages are not soft, and rubbery like some Ground Effects Packages that are made out of urethane plastic (which are very hard to paint and difficult to install).
The AERO-FLEX® ABS Ground Effects Packages are more rigid like fiberglass but do not crack like fiberglass parts will.
Also, parts made out of fiberglass are usually very poor fitting compared to AERO-FLEX® parts.
RAZZI’s parts are commonly referred to as the "best fitting" parts in the Ground Effects industry.
AERO-FLEX® is not a "urethane" material and it is NOT a "fiberglass" material.
The accurate description of AERO-FLEX® is that it is a “co-extruded ABS composite plastic” material—a very "high tech" plastic.
PM for our lowest price of the year with FREE S/H!
Old 02-04-2014, 04:43 PM   #10
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now carries the ACS product line for the Chevy Camaro.
2010 2014 Chevy Camaro SS LT LS ACS TL1 (Zl1 Replica) Hood Extractor Insert 33-4-095
Introducing the TL1 Hood Insert self-install kit, the coolest way to upgrade your STOCK Hood.
That's right, modify your Aluminum Hood and save on re-paint and the hassles with replacement hoods.
The ACS TL1 Hood Insert self install kit pays homage to the Zl1 while matching the lines of the existent stock hood of your Camaro.
Includes
1 - ACS TL1 Hood Insert
1 - ACS Tl1 Water Deflector
1 - Front Passenger Side Hood Grill, Octagonal Mesh
1 - Rear Passenger Side Hood Grill, Octagonal Mesh
1 - Front Driver Side Hood Grill, Octagonal Mesh
1 - Rear Driver Side Hood Grill, Octagonal Mesh
6 - M6 Nut with Mounted Washer
3 - M6 U nut
3 - M6 Bolt
2 - Large Washers
4 - Standard Washers
2 - Cap Plugs
1 – Tl1 Template
1 - Adhesive Cartridge
4 – Tie Wraps
Instructions
We can hydro-dip this in a Carbon Fiber Pattern also!
Old 02-05-2014, 03:50 PM   #11
OHIO SPEED
OHIO SPEED's Avatar
NEW EXTERIOR Hoods, Spoilers, Body Kits, Parts for Sale! New Parts Added Daily
Ohio-Speed now offers our Stingray Yenko Style Bolt On Hood.
Fully Finished Underside.
PM for our low price and Freight Quote
Old 02-05-2014, 10:13 PM   #12
glc55
glc55's Avatar
Drives: 2013 ZL1 Black Camaro
Pm price and shipping 90650 thxs greg
glc55 is offline   Reply With Quote
Old 02-05-2014, 11:32 PM   #13
SS_TINHO
SS_TINHO's Avatar
Drives: 2010 Camaro SS
Pm me price for red please
13' Camaro SS 746WHP
LSA Supercharged, Built 416 Stroker, BTR Stage III Pd cam, M6, Corsa Exhaust, DMH Cutouts, Vip Modular Wheels, DSE Suspension, Squash Fuel System.
SS_TINHO is offline   Reply With Quote
Old 02-12-2014, 06:47 PM   #14
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now carries the L-88 Bolt On Hood for your Chevy Camaro.
Perimeter frame on underside is finished.
PM for our low price!
billet, body kits, camaro, exterior, hood
