Caryle Racing
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Exterior Parts & Accessories
Old 02-20-2014, 04:33 PM   #15
OHIO SPEED
OHIO SPEED's Avatar
Drives: 2010 1LT v6 Twin Turbo
NEW EXTERIOR Hoods, Spoilers, Body Kits, Splitters New Parts Added Daily
Ohio-Speed now carries the 3DCarbon product line for the Chevy Camaro.
2010 2013 Chevy Camaro v8 3D Carbon 7pc. Body Kit 691811
The styling kit is available as a 4, 5, 6, or 7 piece kit with several accessories that may be purchased separately, including front fender vents, rear window trim and a rear spoiler.
It is manufactured in OEM-quality high-pressure injected molded polyurethane and is backed by 3dCarbon's factory-matching warranty.
It is also available pre-painted.
Kit Includes: Front Air Dam, R/L Side Skirts, Rear Lower Spats R/L, Rear Spoiler, Front Fender Vents, Rear Window U-Trim.
PM for our lowest price of the year!
Ohio-Speed is your #1 Online Store for High Performance Parts and Show Car Accessories!
https://www.ohio-speed.com/default.aspx
TAKE ADVANTAGE OF OUR LAYAWAY PROGRAM!
OHIO SPEED is offline   Reply With Quote
Old 02-24-2014, 06:19 PM   #16
rjames
rjames's Avatar
Drives: 2012 45th 2ss
Just ordered my "COPO" style hood! Can't wait to get it. This with all the other body pieces I have ordered over the winter is going to be like having a new car.
WOOHOO
2012 45th M6 Coupe, Stock internals,Cam/springs,ARH 1 7/8 cat delete,Flowmaster american thunder Cat back, 3:91 gears and K&N Cold air kit. 484 RWHP 454 TQ.Acs body kit,Bmr 1" springs,Vfn copo hood going on soon! Tuned by Speed Inc. Dss 3 1/2 aluminum shaft, Dss 1000hp level 4 shafts, Eaton True Track.
rjames is offline   Reply With Quote
Old 03-01-2014, 09:23 PM   #17
#1stunner
#1stunner's Avatar
Drives: 2011 syn. green ls
Originally Posted by OHIO SPEED View Post
Ohio-Speed now carries the ACS T5 Splitter which is the latest product driven by enthusiast demand.
The composite T5 Splitter will install on all Camaro ls, Lt, RS, V6 front fascias and WILL NOT lower the vehicle's ride height.
Mounts’ using a series of supplied mechanical fasteners and does not require the front fascia to be removed.
Installation time is under 15 minutes.
The easiest splitter installation currently offered on the market.
Given it won't alter the ride height, it is the most durable in addition to its complete belly pan to cover the under surface of the Camaro V6 fascia.
Protect your OEM paint while improving airflow of the frontal area of your Camaro.
Part comes prepped and primed in with all the required hardware and instructions.
PM FOR OUR LOW PRICE WITH FREE S/H!
need a price for this to 17268
#1stunner is offline   Reply With Quote
Old 03-01-2014, 09:40 PM   #18
ssfox
ssfox's Avatar
Drives: 2011 2SS/RS Vert
Ohio-Speed now offers Sequential LED Lighting for the Chevy Camaro.
All parts for both side of the car- super easy install 2X brighter.
Lifetime warranty.
New design for the simplest possible install 2010-2013 Camaro plug and play 3157 style LED sequential lighting kit!
Comes complete with everything you need for a super easy install.
No wires to locate, no control boxes to place no complicated instructions.
If you can change a light bulb you can put in the new integrated converter pack and pre-installed sequential LED.
Literally unplug your old lamp and plug in the new lamp socket in it place and go!
Looks stock but brighter and it sequences too!
*Note: New product due to very high demand expect 2-3 weeks to ship.
PM for our low price with free s/h!
Hi Jim,
Can you PM me a price shipped to L1K 2S2 - Canada.
Thks,
Mike
2011 2SS/RS VERT
Moroso Catch Can,K&N CAI,Apex Air Scoop & Washer Relocate,ZL1 Grille,GTO Clutch Rez, Frameless 2013 mirror.
Tuned by MGS Performance
ssfox is offline   Reply With Quote
Old 04-14-2014, 04:34 PM   #19
OHIO SPEED
OHIO SPEED's Avatar
2010 2013 Chevy Camaro Big Mouth Mailslot Intake 33-4-109
Big Mouth is ACS' answer to the non-functional Camaro SS mailslot.
The Big Mouth is practically double the size, functional, and will give your Camaro that aggressive look and performance.
Manufactured in Resin Transfer Moulding (RTM): Includes:
Outer panel
Mounting ring
Templates
Adhesive
Instruction booklet
Installed with an ACS Rad Support (33-4-073) provides directed air flow to the engine compartment.
Old 04-15-2014, 01:25 AM   #20
A_DILLA
Optimus Prime
A_DILLA's Avatar
Drives: 2013 Camaro ZLS [COTW 09/22/14]
Ohio-Speed has the best prices on this Clear Bra Alternative!
(6) 2010 2013 Chevy Camaro v8 v6 Z28 ZL1 1LE SS RS LT LS 45th Front Nose Mask-Bra.
The Front Nose Mask (Bra) Is a Blend of Nylon and Lycra.
This provides a durable and breathable material that can protect the paint surface while not damaging the clear coat finish.
Better than vinyl or leather
Cheaper than 3M film or a new paint job
Easy 20 minute intial hardware install with no drilling
Can be installed or removed in less than 5 minutes
Will not loosen up and will always maintain a perfect fit tight fit
Easy cleaning with soap and water
1 year manufacturer warranty
MIRROR COVERS ALSO AVAILABLE ADDITIONAL 59.95
Fits all v8 models with/without GM front ground effects
Fits all v6 models with/without STILLEN front chin splitter (shown)
GREAT FOR KEEPING THE DIRT AND BUGS OFF THE FRONT WHILE ON YOUR WAY TO A CAR SHOW OR YOUR FUN FILLED VACATION!
2014+ version to be out very soon!
Can you pm me Shipped?
TO VIEW MY JOURNEY CLICK BELOW --> COTW 09/22/2014 <--
http://www.camaro5.com/forums/showth...12#post7909512
A_DILLA is offline   Reply With Quote
Old 04-15-2014, 05:13 PM   #21
OHIO SPEED
OHIO SPEED's Avatar
Front Splitter Rub Guards 15pc. Black Chrome or Stainless Steel
Ohio-Speed now offers Splitter Guard Washers to protect the front splitter from dragging or scraping the ground or grinding the screw heads off at the attach points.
We make them out of stainless steel to hold up longer than other products out there.
The Splitter Washers come stainless or black chrome carbon steel.
The Splitter Washers can be used on most any hollow splitter that cars of today have, foreign and domestic.
pm for our low price with free s/h!
Old 04-15-2014, 05:24 PM   #22
monte1214
monte1214's Avatar
Drives: 2013 Camaro SS Convertible
Hi Jim.
Can you PM me Price to L1C 1L2 in Ontario.
Thanks!
Lifetime warranty.
monte1214 is offline   Reply With Quote
Old 04-18-2014, 10:09 AM   #23
reissdvm
Drives: 2010 2ss
Can I get prices on the splitters t4 and 5?
Thanks
Adam
reissdvm is offline   Reply With Quote
Old 04-20-2014, 06:24 PM   #24
AllBlckChvy
AllBlckChvy's Avatar
Drives: Black 2LS
how much for this to 88011?
MRT V2.0 | VMax CNC Ported TB | BMR 1.25" drop springs | Staggered 22x9/10.5 Limited Edition Black Giovanna Dalar 5 Wheels | MGP Calipers | Halo Projector Headlights | Blinglights Dual Color Foglights | Gun Smoke tail, side markers, reverse light tint | 5% Tint all around
AllBlckChvy is offline   Reply With Quote
Old 04-23-2014, 07:44 PM   #25
PIGSMOKR
2010 Lingenfelter SS
PIGSMOKR's Avatar
Drives: 2010 lingenfelter ss
So thx to my wife, (she backed into my car I ordered the zl1 bumper conversion and copo hood. Dropping it off at body shop next week for proper fitment and paint. I threw the hood on real quick to see it and it fits really good to start with. Thanks ohio speed. Will post more pics after its painted.
2010 ss, forged 376 ci bottom end with diamond pistons, 640 lift comp cam, 260cc prc heads, fast 102 with nw throttle body, full exhaust, f1 - a pro charger powder coated all black, alky dual nozzle meth kit, monster twin disc clutch, dss driveshaft and axles, 391 gears, full suspension, 20' rohana rc22 wheels, 305/35/20 m/t DR, 840rwhp.
PIGSMOKR is offline   Reply With Quote
Old 04-26-2014, 05:31 PM   #26
OHIO SPEED
OHIO SPEED's Avatar
Thanks again pigsmokr! can't wait to see everything on it's going to look great!
Old 04-28-2014, 04:29 PM   #27
OHIO SPEED
OHIO SPEED's Avatar
Ohio-Speed now carries the L-88 Bolt On Hood for your Chevy Camaro.
Perimeter frame on underside is finished.
Old 04-30-2014, 04:48 PM   #28
OHIO SPEED
OHIO SPEED's Avatar
RimPro-Tec Wheel Band System 18" to 22" C7-WB01
RimPro-Tec is a highly developed durable plastic formula extrusion that is easily applied to the wheel via an adhesive 3M VHB tape.
The design consists of a carrier that is adhered to the wheel and an inner that is interchangeable allowing the customer to make changes to the appearance of their vehicle depending on different moods and the color of their car.
The innovative and patented design of the product allows minimal fitting time and produces no safety issue, having been tested by the independent New Zealand transport research Agency TERNZ.RimPro-Tec reduces the risk of curb damage.
Wheel refurbishment is timely and costly. When refurbishment takes place the wheels require removal from the vehicle and colour matching is not always satisfactory and the wheels are left in some cases in a non-original condition.
This exercise that can reoccur each time the vehicle is maneuvered against the curb.
RimPro-Tec allows customers to alter and individualise the appearance of their vehicle to their own choosing.
RimPro-Tec dramatically reduces the risk of damage to your precious and vulnerable alloy wheels from scrapes and scuffs caused by contact with the curb when parking and maneuvering.
RimPro-tec is available in a range of colors or is supplied in discreet colors that match those of the wheel.
Customers can buy the inner colored aspect of RimPro-Tec separately.
Each RimPro-Tec System comes complete with a full set of either 4 x Silver inners + 4 x Silver outers or 4 x Black inners + 4 x Black outers, Fitting tool, 4 x Preparation Wipes and Installation instructions.
Choose which RimPro-Tec System best suits your rims and then why not add a different color inner from the full range below to make your rims stand out from your friends or suit your mood.
PM for the lowest price available anywhere!
billet, body kits, camaro, exterior, hood
