01-24-2014, 09:04 PM | #1 |
Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
ground loop isolator Q
how many do I need to buy? was going to order FARK, door adaptors, mounting board from ******** in a couple weeks and wanted to order the ground loop isolators also on recommendation from some others from the board. just not sure if I need one or more.
thanks for the replies in advance
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
01-24-2014, 09:07 PM | #2 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
One. Goes between the FARK and the amp.
01-24-2014, 09:11 PM | #3 |
thanks JimE was thinking that was the case but couldn't find the answer for sure anywhere.
01-25-2014, 08:16 AM | #4 | |
Drives: 2011 2SS IOM Vert Join Date: Aug 2009
01-25-2014, 04:53 PM | #5 |
thanks steve, two it is
01-25-2014, 05:01 PM | #6 |
Drives: 2014 2SS RS Coupe Join Date: Aug 2013
Not quite sure why you need a Iso.. you really only need them of you're getting static from your speakers.
01-25-2014, 06:25 PM | #7 |
figure doesn't hurt!
01-25-2014, 06:33 PM | #8 |
01-25-2014, 06:44 PM | #9 |
Drives: 2013 SS/RS Black/Inferno Orange Join Date: Jul 2012
FYI, just installed FARK with a 4-channel Alpine amp, no isolators and no noise.
Jeff |
01-27-2014, 08:10 AM | #10 |
Drives: 2018 1LE Join Date: Feb 2013
You should not need a Iso. it coms down to the amp that you are using. You normal use Iso when you have long run of RCA say from a head unit to the trunk that pick up line Noise if you are use the franks you should not pick up any noise and even if you did if I were you I would use be the last thing I would do. You can ground the RCA get ride of the noise.
Thread Tools | |
