sjm autoprod
Old 07-23-2009, 09:35 PM   #1
Jeffsss
Drives: 2017 Camaro SS 1LE
Jack lift points
Where are GM's recommended jack lift points along the frame rails?
Jeffsss is offline   Reply With Quote
Old 07-24-2009, 06:39 PM   #2
Jozef
Drives: 2010 1LT Black on Black
If I'm usng a floor jack, I try to lift at the suspension connection joints. I assume these areas are used to a lot of stress...
Jozef is offline   Reply With Quote
Old 07-24-2009, 07:42 PM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
there are two points on either side of the car, one for each wheel. check page 9-79 of your owners manual.
I piss excellence
and fart awesomeness
Old 08-08-2009, 06:59 PM   #4
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
Anyone have an actual picture, not drawing of what the "indicated mark" looks like? I couldn't see it the other day when I had mine on the ramp changing my oil.
Thanks
Li0nel1234 is offline   Reply With Quote
Old 08-08-2009, 09:16 PM   #5
CamaroSpike23
Truth Enforcer
there should be a notch in the frame rail where the jack will "lock in"
I piss excellence
Old 08-08-2009, 09:31 PM   #6
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
Drives: Sky Redline & Camaro 2SS/RS
Yea, these points will work with a scissor Jack, but NOT with a floor jack, my rail started to kink, so I backed down quickly.
Does anyone know where to put the floor jack pad???
ITS HERE! : 2010 Camaro 2SS / 6 Speed Manual (No other way) / Silver Ice Metallic / Inferno Orange Interior Accent / RS Package / Polished Wheels / SOLO MACH X CAT BACK
Xmicro_SS is offline   Reply With Quote
Old 08-10-2009, 12:19 PM   #7
john797
Drives: 2010 RS/SS Camaro LS3
what about the jack stands
Lets say you get it jacked up, now where do you place the jack stands? The manual says to use them just not where to put them. I just got the car and haven't gotten under it yet.
john797 is offline   Reply With Quote
Old 08-11-2009, 03:55 AM   #8
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
crossmember or under the ball-joints or the pinch welds where they say you can lift from(you just have to lift from somewhere else then )
Gentry78 is offline   Reply With Quote
Old 08-11-2009, 08:06 AM   #9
Ranger 75
Ranger 75's Avatar
Drives: 2010 Camaro 2SS IBM
Yea! This is a major problem of mine also when I get under mu SS a floor jack point doesn't jump out nothing looks strong enough to support the weight. I know there is a member a hell of a lot smarter than me that knows the answer!
Ranger 75 is offline   Reply With Quote
Old 08-11-2009, 08:27 AM   #10
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
I am still waiting for someone to chime in with some wisdom and maybe a picture. I hate lifting from the diff.
Old 08-11-2009, 10:16 AM   #11
Ranger 75
Ranger 75's Avatar
Yep! Someone will pop in.
Old 08-11-2009, 11:15 PM   #12
LS 1st gen
Kept the Faith.
LS 1st gen's Avatar
Drives: 2010 VR 2SS
Send a message via AIM to LS 1st gen
Doing my oil change tomorrow. I'll be using a floor jack and jack stands. If no one chimes in by then, I'll be sure to post up pics of whatever I find.
Any other Camaro specific oil change tips?
GORDON 2010 Camaro # 13694 Victory Red 2SS manual | White rally Stripes | Polished Wheels | Rotofab CAI| MGW Shifter| Kooks LT's| Magnaflow X-pipe|FM 40 Delta Flows | Elite Tunnel Brace | "Ginger"
LS 1st gen is offline   Reply With Quote
Old 08-12-2009, 06:43 AM   #13
Ranger 75
Ranger 75's Avatar
Good Luck, Waiting for post!
Old 08-12-2009, 07:18 AM   #14
Croathlete
Danny
Croathlete's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via AIM to Croathlete
Jack up the passenger side of the car. The oil will come out much easier (at least on the SS).
2SS/RS CGM with black rally stripes
DON_RAFA describing my Noweeds cutouts - "Very Strong. When I couldn't see you I still heard you. Sounds like your car is pissed at the world."
Please help me fight back by supporting me in the 2010 American Cancer Society's Relay for Life. Every little bit helps. Click here for more information. Thank you to those that have donated!
Croathlete is offline   Reply With Quote
Just thought I'd share TAG UR IT Off-topic Discussions 33 05-12-2011 03:04 PM
where do you jack up the car if you have a flat or oil change /also wheel lock photos camarossrs2150 5th Gen Camaro SS LS LT General Discussions 30 11-10-2009 11:45 AM
I need a car lift. Can anyone help me? mmollo 5th Gen Camaro SS LS LT General Discussions 7 07-04-2009 01:47 PM
If the El Camaro makes it to production.... Silverado General Automotive + Other Cars Discussion 8 02-21-2008 10:17 AM
