Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Audio / Visual / Electronics/ Gauges / Nav
Old 01-29-2014, 04:55 PM   #1
tonyG
Drives: 2011 2SS/RS
Alpine PDX 1.1000 *1,000 watt amp* FOR SALE
I have an Alpine PDX 1.1000 amp. This amp was in my previous vehicle pushing a JL audio 13w7. This amp had minor blemishing on the exterior and was sent to alpine for repair. Im friends with a local audio store owner and we sent it to alpine marked -inoperable- so they would completely disassemble the unit and inspect it and repair if necessary. we didnt think they would actually fix the exterior but they did and completely repaired it . So what I have is a completely new refurbished Alpine PDX 1.1000 from alpine.
Asking $400.00 OBO
Size:  105.4 KBName:  IMG_0234.jpg
Size:  129.2 KBName:  IMG_0235.jpg
Size:  73.0 KBName:  IMG_0236.jpg
the only reason it was sent to alpine was due to the cosmetic issues and i didn't think they would fix that but they did. meanwhile i bought a PDX M12 (second gen PDX) and ended up with two amps, this one has never been used since i got it back from alpine. Paid 195 to have alpine fully service the amp.
more info from alpine
SPECIFICATIONS
CEA-2006 Power Ratings
CEA-2006 Power Rating: (4/2 I? @14.4V Ƈ%THD+N), S/N 80dBA, ref:1W into 4 I?) 1000W x 1
RMS Power Ratings
Per channel into 4 Ohms: (@14.4V Ƈ%THD+N, 20Hz - 200Hz) 1000W x 1
Per channel into 2 Ohms: (@14.4V Ƈ%THD+N, 20Hz - 200Hz) 1000W x 1
Sound Tuning
Crossover: Variable, 50Hz - 200Hz (-24dB / oct), Low-Pass
Dimensions
Heat Sink (WxHxD) mm: 257mm x 192mm x 62mm
Heat Sink (WxHxD) in: 10-1/8'' x 7-9/16'' x 2-7/16''
General
Power Requirements: 14.4V DC (11V to 16V)
Input Sensitivity: 0.1V to 8.0V (For Rated Power)
Frequency Response: 20Hz - 200Hz (20Hz/-3dB)
Speaker Impedance: 4 or 2 I?
Signal to Noise: CEA 2006 S/N Ratio (IHF A Weighted, Reference: 1W into 4I?) 80 dBA
FEATURES
Install
Connectors: Quick Disconnect Terminals
Terminal Layout: One-Sided
Screw Mount / Wire Cover: Integrated Wire and Mounting Screw Terminals
Mounting Design: Easy Stacking
General
Amplifier Type: Class-D (Digital)
Channel Design: 1 Channel (Mono)
Thermal Control: Thermal Management Control
Power Supply: Resonant Mode Power Supply
Power Supply Design: DC-DC PWM Power Supply
Board Circuitry: STAR Ciruit
Current Protection: Auto Over-Current Protection
Power Indicator: Top Mounted Blue LED Power/Status Indicator
RCA Output: Non-Fading Pre-Amp Output
Crossover: Adjustable Low-Pass
Connector Plating: Gold Plated Input, Output, Power and Speaker Terminals
Pre-Amp Stage: Discrete
Final Outputs: MOSFET
Board Design: 4-Layer Glass Epoxy PC Board
Gain Control: Adjustable
tonyG is offline   Reply With Quote
