Solo Performance
Old 01-30-2014, 01:09 AM   #1
B-_-RAD
Banned
Drives: ...
Oil, Oil, and more Oil!
For those of you that have done a cam swap, what oil are you using, and why? I've heard many people say M1 is fine but I am thinking of switching over to vr1. For those who are using vr1 are you using the conventional (silver bottle) or synthetic (black bottle)?
B-_-RAD is offline   Reply With Quote
Old 01-30-2014, 06:00 AM   #2
mdub76
mdub76's Avatar
Drives: 2010 2ss/RS IOM GFX M6
Use Royal Purple HPS 10w30. What the shop recommends for the zinc
mdub76 is offline   Reply With Quote
Old 01-30-2014, 06:29 AM   #3
The Blue Ox
The Blue Ox's Avatar
Drives: 2010 SS L99 Inferno Orange
VR1 Synthetic! I have been using Valvoline for a long time!
I first started using Valvoline back in the late 70's after an older fellow told me a story about Valvoline! He raced VW rails( I had a pretty fast one) and ran Castrol. Castrol is supposedly made for air cooled engines. He took his car out on the track and shortly after, his red oil light lit up! He brought the car in, dumped the Castrol out and replaced it with Valvoline! He got back out on the track and the light never came on again!! ..... That's what sold me, on Valvoline!!
IMO, Valvoline, keeps the engine cleaner on the inside, than a lot of other oils!!
The Blue Ox is offline   Reply With Quote
Old 01-30-2014, 06:40 AM   #4
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
Do not use M1with a cam swap. Look for an oil that has a good amount of zinc.
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 01-30-2014, 07:53 AM   #5
jgray1978
jgray1978's Avatar
Drives: '12 2SS/RS 45th vert, '14 2SS/RS
I've heard too that M1 is a no-go. I've used M1 Gold in my Caddy and conversion van for years. I have yet to change the oil in the Camaro but will too be visiting your subject matter soon.
jgray1978 is offline   Reply With Quote
Old 01-30-2014, 08:16 AM   #6
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Mobil 1 15w50 per my Builder. Due to the Zinc.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 01-30-2014, 08:23 AM   #7
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
The main reason Mobil is heard about on this subject is its the most commonly used oil by far. Not saying that there's nothing else to it but just on the mathematical odds of it. I use it now but I'm stock internal. Will I change when I do my cam swap? Probably not but will run a zinc additive if I do stick with Mobil.
Old 01-30-2014, 09:59 AM   #8
B-_-RAD
Banned
Drives: ...
The zinc additive is too expensive, it was like $13-$17 a bottle and only does 4-6 qts. There is so much conflicting info, I think im just going to go with vr1. I'm doing the night fury cam and they said its fine to use m1 though
Old 01-30-2014, 10:33 AM   #9
BooSSted
BooSSted's Avatar
Drives: 2017 Z06 / 2012 CTS
I've read with the properties of today's oils, a "additive" may not bond / mix with your current oil defeating the process of using or adding zinc (ZDDP) content. Which oil contains the highest levels of ZDDP, I've heard good things on the Mobil 1. There is a good report on this site crushing some of the popular like the Royal Purple finishing last...
BooSSted is offline   Reply With Quote
Old 01-30-2014, 10:37 AM   #10
bkscott
bkscott's Avatar
Mobil 1 15w50 has a Hi zinc content.
Old 01-30-2014, 11:18 AM   #11
B-_-RAD
Banned
Drives: ...
50wt is way to thick for a daily driver imo.
Old 01-30-2014, 02:42 PM   #12
bkscott
bkscott's Avatar
I guess it depends on where you live.
Old 01-30-2014, 05:38 PM   #13
B-_-RAD
Banned
Drives: ...
^ Yes it does. Too cold here unfortunately.
According to comp the cam should be broken in with break in oil and treated like a flat tappet cam on the first start. Has anyone on here actually used break in oil with a new cam?
Old 01-30-2014, 06:56 PM   #14
Bo White
Bo White's Avatar
First I've heard of breaking in a roller cam.
