Old 02-01-2014, 11:31 AM   #1
redleader
redleader
Drives: 2010
Iceolator for Manifold - left over bracket
So I have installed this:
And in the process it says to leave out the Front Manifold support bracket, and it's OK to do that...
The one the chap is holding here with his left hand:
http://www.camaro5.com/forums/showthread.php?p=7279607
But has anyone got an alternative Bracket we CAN put on?
redleader is offline   Reply With Quote
Old 02-01-2014, 11:54 AM   #2
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Just leave it there. You really don't need it. You can hold onto the bolt in case you ever return it to stock. If you want to use the engine cover, you can add a few washers under the little post to the left of the throttle body.
Eddiefuzz is offline   Reply With Quote
Old 02-01-2014, 11:57 AM   #3
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Disconnect the battery if your going to unplug the Throttle body. I just left the connection and set the throttle body to the side. Is that a 10mm or 25mm?
Old 02-01-2014, 12:27 PM   #4
redleader
redleader
Drives: 2010
Thanks EddieFuzz,
I have my CatchCan mounted via the Post so all should be good for the Engine Cover level.
It is a 5/8"? Iceolator via. Apex ... it's NOT the 25mm it's the thinner one ... and a new Ported TB at the same time! :-)
Old 02-01-2014, 04:03 PM   #5
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Great, you should really notice a difference. Two really good MODS, two of my first, your on your way...I just put Hotchkis front end links on...Have fun.
Old 02-01-2014, 09:16 PM   #6
eblanchette
eblanchette's Avatar
Drives: 1LE
I just removed mine so it does not look like something's not right. I'd say remove it.
eblanchette is offline   Reply With Quote
Old 02-02-2014, 07:49 AM   #7
redleader
redleader
Drives: 2010
I saw this on another Forum Post ... but it was to do with the 25mm Iceolator ... not sure ours would give enough height.
Old 02-02-2014, 08:35 AM   #8
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
drill out both holes over standard size. to the next I think 3/8" and it will fit
Old 02-02-2014, 08:58 AM   #9
RubyCamaro
Jan
RubyCamaro's Avatar
Mine is left out & no problems. Never put the engine cover back on & like it like that!
Old 02-02-2014, 11:28 AM   #10
redleader
redleader
Drives: 2010
That's to All :-)
What a Team! :-)
Old 02-02-2014, 01:25 PM   #11
gml1998
gml1998's Avatar
Drives: 2010 Synergy Green Camaro
I made an adapter for mine. A piece of 1/4 inch aluminum plate with 2 holes drilled in it and a piece of 3/4 inch aluminum round stock with 1 hole drilled through center. I realize it probably isn't necessary but it does give it a finished look.
gml1998 is offline   Reply With Quote
Old 02-02-2014, 01:39 PM   #12
redleader
redleader
Drives: 2010
More photos plz!
Drawings!
Maybe Cake :-)
Old 02-02-2014, 05:09 PM   #13
RubyCamaro
Jan
RubyCamaro's Avatar
Okay. Here ya go:
Old 02-03-2014, 01:58 AM   #14
redleader
redleader
Drives: 2010
Originally Posted by RubyCamaro View Post
Okay. Here ya go:
Looks like your support Bracket is on there?
