Old 02-03-2014, 02:10 PM   #15
gml1998
gml1998's Avatar
Drives: 2010 Synergy Green Camaro
Here is a better picture
gml1998 is offline   Reply With Quote
Old 02-03-2014, 02:38 PM   #16
RubyCamaro
Jan
RubyCamaro's Avatar
No it isn't. I have some closer up pics at home. I'll try to find one that shows it this evening if I can remember to.
Old 02-05-2014, 11:40 AM   #17
redleader
redleader
Drives: 2010
:-) x Thx
redleader is offline   Reply With Quote
Old 02-09-2014, 01:58 PM   #18
noisemker
noisemker's Avatar
Drives: RY 2LT/RS
did you also have 2 leftover screws from the heat sheild?
Airaid Intake And Solo CatBack Solo Highflow Cats
noisemker is offline   Reply With Quote
Old 02-13-2014, 11:46 AM   #19
redleader
redleader
Drives: 2010
I think in the Instructions you put those back on the Manifold before you bolt it back on the Engine?
Old 02-13-2014, 08:39 PM   #20
noisemker
noisemker's Avatar
Drives: RY 2LT/RS
i just reread it and founf this #14 on the instructions but im not quite sure what it means
Old 02-16-2014, 04:42 PM   #21
noisemker
noisemker's Avatar
Drives: RY 2LT/RS
could anyone explain it a bit better, the bolt holes dont line up with the iceolator one so I cant see how they would be put back in. Anyone that installed this have any advice?
Old 02-16-2014, 05:03 PM   #22
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Just the one bolt that mounts from the engine to the manifold don't line up. You really don't need it. In post 15 the guy made a brace thing. The six bolts on top line up, that's what you need. That's for the 3/8, if you go 1inch you need 6 longer bolts.
Eddiefuzz is offline   Reply With Quote
Old 02-16-2014, 07:34 PM   #23
RubyCamaro
Jan
RubyCamaro's Avatar
This is the best pic I could find in my pics but you can see it is just out or alignment a bit & the bolt is left out. Like others have said, the important bolts still work & it is fine without this one.
Old 02-17-2014, 04:14 PM   #24
noisemker
noisemker's Avatar
Drives: RY 2LT/RS
these are the parts I have left over. The 2 bolts would go behind the engine to connect to the firewall I believe, just want to make sure they dont need to go back in because the holes didnt line up anyway.
Old 02-17-2014, 05:20 PM   #25
Shift_Rejected
2010 2SS RS
Shift_Rejected's Avatar
Drives: 2010 2SS RS (L99)
Those things aren't important as long as you don't go over 50mph..
J/K, the two rear bolts and the front bracket are not used with the iceolator. Which is good cause those real bolts are a pain.
~ Build Thread | 371HP & 390 TQ
Performance Mods: K&N Cold Air Intake | Pypes Cat-Back Exhaust | Aluminum Paddle Shifters | VaraRam Wedge | Cross Drilled/Slotted Rotors | Hawk HPC Pads | M.M. Ported Throttle Body | Kooks 1 7/8 Headers w/ High Flow Cats | Dyno Tune @ RPM
Cosmetic Mods: Rally Stripes (style1, style2, style2.2) | Splitter | Painted Calipers | Door Projector Lights | Front-Emblem Delete | Cup Holder Lighting | Quarter Window Covers | Phantom Grille | Ghosted Side Markers | Tinted Fog Lights | ZL1 Rockers | Tail Light Bezels
Shift_Rejected is offline   Reply With Quote
Old 02-17-2014, 05:53 PM   #26
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Correct, as all have pointed out. Leave the bolts out, not required anymore. I have had the ice-olator now for 30K miles, no issues.
Old 02-17-2014, 05:59 PM   #27
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: Longest things on Earth
Ice-o-lator FTW
its a syn is offline   Reply With Quote
Old 02-17-2014, 06:00 PM   #28
redleader
redleader
Drives: 2010
Cheers everyone :-)
I'm so use to over-engineering things myself.
CLOSED.
