Emblempros
Old 02-02-2014, 04:50 PM   #1
blackswan
blackswan's Avatar
Drives: Yes
Loud metallic rattle, worse when cold and in reverse - take a listen
Always tough to convey a sound, but wondering if anyone else has this noise.
From inside it sounds like a muffled rattle around and under the shifter. However, with a recorder outside the car is sounds like a very loud metallic rattle.
It's worse when ice cold (first start of day) but on occasion you can hear it when in reverse backing up a hill or on moderate acceleration in drive from a dead stop. So load seems to matter, does not do it at all in N.
Take a listen and share your thoughts, it's very loud (though apparently not loud enough for a dealer mechanic to hear of course - ).
blackswan is offline   Reply With Quote
Old 02-02-2014, 05:26 PM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Well I can tell you that's not normal.....
Sure sounds like something is lose...
Almost like a heat shield or exhaust part.
Mods:
Old 02-03-2014, 01:56 AM   #3
wutshotDJroomba
wutshotDJroomba's Avatar
Drives: 2012 Camaro LS/SC
Agreed. I once had a similar wicked rattle under my car only when in Drive stopped, or when slowly accelerating. I slid under the car with a rubber mallet and lightly tapped on the pipes until I finally found out that one of my axle-back exhaust bolts had come loose. Crazy to think something near the back could resinate all the way towards the front, but that's the exhaust system for you. Even if you don't have an aftermarket exhaust like mine there's still a chance it could be a heat shield or just a loose clamp/bolt/etc. as Kaboom1701 stated... It's worth it to get under there and take a look before you bite the bullet and finally decide to take it in.
"....Empty your mind, be formless. Shapeless, like water. If you put water into a cup, it becomes the cup. You put water into a bottle and it becomes the bottle. You put it in a teapot, it becomes the teapot. Now, water can flow or it can crash. Be water, my friend.”
-Bruce Lee
wutshotDJroomba is offline   Reply With Quote
Old 02-03-2014, 12:12 PM   #4
blackswan
blackswan's Avatar
Drives: Yes
Great ideas, thanks guys. Yeah, I know it's not normal - pretty loud! It's actually been into the dealer, they replaced the catalytic on one side - twice. No idea why they don't think it might be the other one now.
Old 02-03-2014, 06:33 PM   #5
skibik
Guest
Drives: bbbbbb
Either the cats are bad again and they should replace both not just one side as it maybe the other side. Not sure exactly what is inside the resonators but could be a baffle come loose if there is one in there. Sound transmits through the car and it may also be a loose baffle from inside the muffler. Sounds like a trip back to the dealer to me.
Dean.
skibik is offline   Reply With Quote
Old 02-03-2014, 10:53 PM   #6
wutshotDJroomba
Dean.
I've had a cat converter replaced twice, first the driver's side, then the passenger a few months later rattled. It's quite a problematic part on this car, well at least on mine it appears to be. I don't believe they're exactly built to last what with the constant amount of heat applied, so it eventually weakens, but mine hasn't given me an issue since replacement. There is also the long shot that something wasn't tightened enough after it was removed and replaced and now it's rattling. Seems like detective work is order, as Skibik said the sound will transmit throughout so check the entire system, heat shields included if you're able to and keep us posted if you can.
-Bruce Lee
Old 02-04-2014, 12:28 PM   #7
blackswan
blackswan's Avatar
Drives: Yes
Yes going to a different dealer who may have sufficient diagnostic skills to actually fix it.
Old 02-19-2014, 05:19 PM   #8
Vai
Drives: In the process of buying a Cam
I have this same issue in my car. Going to take it in Saturday and hopefully they will be able to pin point the issue and fix it...very annoying
Vai is offline   Reply With Quote
Old 02-25-2014, 12:52 PM   #9
blackswan
blackswan's Avatar
Drives: Yes
What did they say?
Old 03-16-2014, 10:02 PM   #10
blackswan
blackswan's Avatar
Drives: Yes
Unbelievably, or maybe it is believable, the dealer left my tranny a quart low and that's what the noise was, NOT a catalytic converter. Frustrating as I brought it in right after the tranny flush saying it sounds like he transmission. Nope, they knew better and became pretty rude when I kept coming back with the same noise. Told me if there was no "light on the dash" there is no tranny problem. Really.
Took an awesome dealer to figure it out in about 5 minutes upon hearing this noise, that the other dealer said is nothing or couldn't hear it.
Old 03-16-2014, 10:09 PM   #11
RobertRS
RobertRS's Avatar
Drives: 2014 2SS L99
Wow! Glad to hear you got that ironed out. At least you know who you won't be taking it back to in the future.
RobertRS is offline   Reply With Quote
Old 03-16-2014, 10:19 PM   #12
blackswan
blackswan's Avatar
Drives: Yes
Totally, real sad treatment and waste of GMs dollars. They even claimed they did pressure tests in the tranny and checked fluid levels, etc. when I brought it back insisting it was the tranny. At least I didn't have out of pockets expenses for that "work", but did pay a couple hundred for the flush. Nice eh?
Old 03-16-2014, 10:51 PM   #13
6bangerBOOM
6bangerBOOM's Avatar
Drives: 2016 1SS SW
I believe I've seen a few people report that they found rocks caught up in their crossmember that were the cause.
6bangerBOOM is offline   Reply With Quote
Old 03-20-2014, 09:39 AM   #14
blackswan
blackswan's Avatar
Drives: Yes
Well, that wasn't this noise though, see above. Dealer botched tranny flush.
