sjm autoprod
Old 02-03-2014, 03:23 PM   #1
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
Can I run a Metco breather with my Maggie?
Any benefit? I've got an Apex catch can on there now and was looking to add a breather but isn't it a closed PCV system?
L99 With a Maggie
Nutro is offline   Reply With Quote
Old 02-03-2014, 03:51 PM   #2
Sickness91Z28
Reaper Crew
Sickness91Z28's Avatar
Drives: Blown 2010 Camaro SS
I plan on running one of these: http://www.jreperformanceparts.com/2...-breather.html
2010 Camaro SS
SLP TVS2300 Blower, Blower Cam, Lingenfelter Heads, Meth Injected, 5lbs of Boost@700 BHP
Pedders XA Coilovers
Sickness91Z28 is offline   Reply With Quote
Old 02-04-2014, 10:29 PM   #3
Nutro
Nutro's Avatar
BUMP
L99 With a Maggie
Old 02-04-2014, 10:37 PM   #4
Supercharged SS
Drives: 2010 Camaro
Originally Posted by Nutro View Post
BUMP
Prob not a good idea. The Metco breather doesn't have a check valve. It will allow unmetered air back into the engine and cause some issues. Get one with a check valve.
Old 02-04-2014, 10:55 PM   #5
Nutro
Nutro's Avatar
Thanks, Jamie. Would this Mightymouse one work well for $70?
http://mightym0use.wix.com/mm-solutions#!lsx/cqtl
L99 With a Maggie
Old 02-04-2014, 11:00 PM   #6
Supercharged SS
Drives: 2010 Camaro
I can't tell if it has a check valve. Any breather with a check valve will work.
Old 02-04-2014, 11:57 PM   #7
Sickness91Z28
Reaper Crew
The link I posted has a check valve.
2010 Camaro SS
Old 02-05-2014, 12:58 AM   #8
Dznts
Anabolic Connoisseur
Dznts's Avatar
I use the Rx breather with check valve, no issues at all.
Old 02-05-2014, 09:30 AM   #9
Nutro
Nutro's Avatar
Hmm the MightyMouse one might work well. Here is a message about it from the owner
"yes there is a large disc inside the breather that lets any positive pressure freely exit, and when vacuum returns to the crank case it seals to keep the stock pcv routing and function intact."
L99 With a Maggie
Old 02-05-2014, 11:00 AM   #10
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
The Trick is to have the Valve oriented the right way, It must let crankcase Pressure out but not let atmospheric air in.
Any check valve will not work, we tested a lot of valves before we found one that would holdup and was light enough to open with even the slightest Pressure.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 02-06-2014, 07:06 AM   #11
grocerygetter
instigator
grocerygetter's Avatar
Stock, this breather does NOT work properly. It inhales, not exhales.
I modded one and it works the opposite. But I switched to Holley valve covers and don't use it now.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 02-06-2014, 07:07 AM   #12
grocerygetter
instigator
Is there not a modded metco that has a proper check valve? I thought that was what is in his link?
-John S.
Thanks to:
Tony@ dv8motoring
Old 02-06-2014, 09:07 AM   #13
JANNETTYRACING
Yes We make them Here, for Both OEM and Holley Valve covers.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 02-06-2014, 03:53 PM   #14
grocerygetter
instigator
that's what I thought. If you buy an off the shelf METCO I know it does NOT have the check valve. I asked Summit. .
-John S.
Thanks to:
Tony@ dv8motoring
