| V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters |
Thread Tools |
On a list for a 2014 Z28
![]() Drives: 2010 Camaro 2SS M6 Join Date: Oct 2008
Do you think that the car needs a separate Clutch Fluid reservoir
So like the Title said do you think that the Camaro needs a separate Clutch Fluid reservoir, Like the C6 and the G8 or are you happy with it the way it is?.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 00 Blazer Join Date: Aug 2008
I am curious why you think it does? Is it not working properly? It's an idea that's way overdue in my opinion. Fewer components are cheaper to make and maintain. Till it fails I don't see why it would be an issue.
I for one do not like the mix of brake and Clutch Fluid in one reservoir, Think of the ABS on your car and if you drive it all the time what is going to happen to you big $ brakes, this pic is after 1 week in the brake and Clutch reservoir for the Fluid.
Looks normal. With the dark background hard to tell.
The fluid system is sealed dust from the clutch won't get into the juice unless there is a defect. And if your temps are nominal for eng and tranny you should be fine. |
So why do C6 and G8 come with a separate reservoir for those car but us Camaro guy's don't get one, and here you go.
This is what it will look like.
#6 |
![]() ![]() ![]() Drives: 2006 LeMans Blue C6 Vette Join Date: Dec 2008
Yes
#7 |
HEMI Hunter
Drives: 06 GTO / 79 Z28 Join Date: Jun 2009
I'm satisfied with a common reservior, one less component to fail.
2SS/RS M6 CGM E-Force
#8 |
![]() Drives: "Modi" son of "Thor" Join Date: May 2009
I would like to see the aftermarket offer this option.
Clutch dust can't be a good thing for the ABS to deal with IMO
Adopted & signed by Scott 8/15/09 Officially "Son #2 of Thor" ![]() ![]() |
#9 |
i really dont care
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 662 6 injectors 6 spd dual exhaust Join Date: Mar 2008
Clutch dust cannot get in the fluid no more than brake dust can. Its a sealed system and the discoloration you see is completely normal. I have no issue with the combined system, works good lasts a long time.
#11 |
![]() Drives: 69 Camaro Join Date: Apr 2008
I don't think it would be too hard to separate the reservoirs, like other LSx-powered cars. For a car that's tracked, it would probably be a worthwhile investment.
#12 | |
![]() Drives: corvette Join Date: Apr 2009
Clutch dust does get into the clutch fluid system in Corvettes and I see no reason why it won't happen on the same type of system in the Camaro. You will end up with clutch dust in your brake fluid if this system is like the Corvette's. This is a bad design. Look for Chevy to change this soon because it appears to be a cost cutting measure. |
#13 | ||
Upgrading to a DOT4 fluid sounds like a good idea. GM now is recommending DOT4 for all Corvettes, including those whose owner's manuals state DOT3. There is a list of good DOT4 fluids on my website’s clutch care page. I use two different fluids interchangeably. (1) GM Super DOT4 expensive and hard to find (2) Prestone DOT4 cheaper, widely available, including Walmart Only brand to avoid is Valvoline. It leeches to black almost immediately. Good luck with your car. Ranger Hi i have been looking at your post's for a long time now on this forum, But I got the new camaro last month and noticed that the brake and clutch reservoir is combined into the brake reservoir. I am planning to split the two apart and give the clutch its own reservoir but am wondering if I can upgrade the fluid in the clutch to dot 4 instead of dot 3. Do you think that this would be a problem. And i did this yesterday like i said in 1 1/2 hours and all the parts are $22.00 parts you need are: #1 new reservoir from a GTO a Holden part # 92065790 list $19.33 but can get for $15.00 #2 a hose clamp, Range 1/4-5/8" less than $1.00 #3 a rubber plug for the brake master cylinder reservoir. $ 0.75 #4 2 self tapping metal screws for the new reservoir. $ 0.50 #5 And this is the end Dot 4 Brake fluid "Prestone" . $ 2.75 And that is it.
#14 |
![]() Drives: 2005 C6 Corvette Join Date: Mar 2009
Clutch dust getting into the fluid is a well known issue with the LS motors and manual transmissions.
Has been happening on C6 corvettes from some time - only on the C6 you can cycle the fluid with fresh stuff given the separate tank. Not sure why they did this on the Camaro - I like being able to cycle out my fluid periodically with fresh DOT4. Easy process, only take a few minutes and I can have clean fluid. Check your fluid after about 10k and you won't believe how black it looks. Definately clutch dust getting by. |
#15 |
I did at 4500 mi and was so mad, That i did the redesign and add the new reservoir yesterday, And now i an going to L.V. to get parts for my new tail lights, This will be the test drive on the new reservoir.
#16 | |
![]() Drives: 1969 Chevelle, 2010 1LT Join Date: Jun 2009
#17 |
Dances With Mustangs
How much fluid does the clutch require? Is that reservoir big enough?
Blue Angel is here!! ![]() 1SS/RS LS3 M6 IBM |
#18 |
Well it's good info, the vette info, and I would eat the crow plate. But still want to see proof that this system is getting contaminated. What does the service schedule say for refreshing the brake fluid?
#19 | |
Do you have your car at this time? and do you daily drive it, If you do you will see the color go from gold to brown in no time.
#20 |
Well I wound not cause I am Mr Automatic anyways.
![]() And won't have one for a couple years. |
#21 |
Would rather be riding
Drives: 2012 SS LS3 Join Date: Jul 2009
Yes I do, clutch fluid always gets dirtier faster.
Change it when it gets dirty. Google brake fluid though and educate yourself. DOT 3 and DOT 4 are compatible and are both hydroscopic, which means it is able to absorb moisture. Some of the discoloration is water in the fluid which it is designed to change to a darker color the more moisture it absorbs. DOT 3, and DOT 4 Brake fluid will just turn dark from sitting around with the cap off, thats why the instructions always tell you to add only fluid from a sealed container, preferrably new stuff. So don't go to the parts store and buy the big bottle to just top off your system. It absorbs moisture from the air, and condensation from heat. I still think they should have seperate reservoirs as a failure on one system could cause both brakes and clutch to fail. |
#22 |
The fluid would need a more scientific analysis. As well as long term testing of the system as a total. Right now saying it's gonna fail early is just an assumption based on what appears to be dirty fluid. When it could be a non issue if the maint schedule is followed. That's why I asked what the interval is?
I trust the engineers that it's good for the job. When it actually fails or a scientific fluid test can show some problem then there is a basis for a mechanical issue outside normal maint. |
#23 |
Okie doke
They should have separated them and had different reservoirs. My guess is it is cost cutting.
Crowley
#24 |
![]() Drives: 1969 Firebird, 2010 Camaro SS Join Date: Jul 2009
Less parts means less to break. Now saying that I dont have mine yet. When I do maybe my opinion will change but I like to think it was thought out buy guys smarter than me.
2SS RS CGM LS3, 11.97@119mph with Pirelli lined fender wells![]() |
#25 | |
that is right, But the only thing that can break is a plastic reservoir, that is all i did.
| Thread Tools | |
| Winner, winner - Jalopnik compares the Big 3 | Number 3 | 5th Gen Camaro SS LS LT General Discussions | 31 | 04-17-2011 03:24 PM |
| What's considered a Muscle Car? | SyN | General Automotive + Other Cars Discussion | 125 | 09-25-2010 12:04 AM |
| MATRIX – 24HR REVIEW CAMARO 2SS/RS - NO BS!! | Matrix | 5th Gen Camaro SS LS LT General Discussions | 54 | 06-14-2009 02:37 PM |
| The Camaro, what it has come to mean for me | Number 3 | 5th Gen Camaro SS LS LT General Discussions | 23 | 04-13-2009 09:31 PM |
| 2010 SMS Mustang | TFord | General Automotive + Other Cars Discussion | 19 | 01-22-2009 11:00 AM |
