ADM PERFORMANCE
Old 09-21-2010, 08:11 PM   #141
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Originally Posted by plastrd View Post
Got mine in this weekend. You might notice from the pics that it's a bit crooked. The hose was too long so it kinks if I turn the reservoir straight so next time I change the fluid I'll lop an inch off the hose and level it out. The T bracket can be found at Home Depot next to the fasteners, the holes in the T part line up perfectly with the holes in the reservoir.
I'll let you know after a few burners if it seems to be working.
Did you go to a dot 4 fluid? and replace the fluid before and after you track event.
Old 09-21-2010, 08:19 PM   #142
plastrd
Indecisive
Drives: 2010 Camaro SS/RS
Yep, got the Prestone DOT4 stuff. I didn't do a full change, just replaced the dirty stuff I sucked out during the install but that turned out to be just about a full bottle between the brake and new clutch reservoir.
I was wondering how did you drill the holes to get yours mounted directly to the wheel tub? There's no way to fit a drill in there sideways and it's double-wall sheetmetal so I'd think you'd have a hell of a time using a self-drilling screw...
plastrd is offline   Reply With Quote
Old 09-21-2010, 08:29 PM   #143
caverman
caverman's Avatar
Drives: '69 SS Convertible
If you go back to post #124 you'll see what I did. We used a 1/4" self-tapping screw with an air ratchet. We put a small piece of aluminum tape around it to help hold it in place.
Even then it was a PITA to get it done. We first put down some painters tape, made marks where we thought the holes should go, then used a tool (not sure what it's called) that would make a punch when you pushed on it hard. That was the starting point. We then used the 1/4" selt-tape to make the holes....backing them out when done.
Once both wholes where there we put the resevior on with the same screws. You only get one whole per screw if your lucky. It's too dull after one hole to do the other.
Build Journal
Old 09-21-2010, 08:33 PM   #144
caverman
caverman's Avatar
I like the ingenuity but, no offense, personally I'm not sure I like the looks of the bracket. It makes it look like it's not mounted at all....even though I know it is. As long as you're good with it then I would leave it. Even if you went back and mounted it differently you could probably hide that hole pretty good.
I think the way the OP mounted it is the best so far. If it wasn't such a pain and for the fact that I would have two holes left behind, I would've gone back and put it in the same place as the OP.
Build Journal
Old 09-21-2010, 08:34 PM   #145
2SSRS@Gen5diy
+1 on the self-tapping screw With a 90% drill that i have.
Old 09-21-2010, 08:46 PM   #146
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
The problem with that mounting location, for me, is that the Hotchkis STB attaches at that point. I'm going to need to get really creative...
Kilo-9 is offline   Reply With Quote
Old 09-21-2010, 11:04 PM   #147
2SSRS@Gen5diy
You got a pic?
Old 09-21-2010, 11:46 PM   #148
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
I don't have it on my car yet, but here's a pic from Hotchkis:
Old 09-22-2010, 10:00 AM   #149
caverman
caverman's Avatar
Hmmm....that could be an issue.
Looks like the bracket that was used in post #140 might work. Looks like it might fit up underneath that brace.
Build Journal
Old 09-22-2010, 08:42 PM   #150
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
slap some white paint on the bracket!
justa25thTA is offline   Reply With Quote
Old 10-05-2010, 07:51 PM   #151
2SSRS@Gen5diy
Looks like a lot of members are trying to do this mod, Tell your parts guys that they need to stock this part.
Old 10-10-2010, 09:41 AM   #152
turboguy327
Banned
Drives: 2011 Chevy Camaro
How can clutch dust get into the fluid?? I dont see how dust can get past the seals when the fluid which is under high pressure doesnt leak out. Maybe its just me but I talked to a couple people at my work and they dont get it either. I just dont see the need for this. The theory behind it makes no sense. I didnt see anything like this asked yet but I may have missed it. Sorry if it has been asked already.
turboguy327 is offline   Reply With Quote
Old 10-10-2010, 11:23 AM   #153
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
I haven't figured that one out either, because if clutch dust could get into you fluid the you'd think there would be a leak somewhere. I'm just doing separate the brake and clutch fluid reservoirs. I don't like them be a single point of failure. Your clutch fluid should be changed regularly because of the heat and moisture.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 10-17-2010, 10:17 AM   #154
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
Hey everyone, I just want to make sure I am getting this right.
Also is there any benefit to replacing the original reservoir with one that comes pre plugged? (like the ones that come in automatic?)
Thanks, you guys rock .
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 01:04 AM
MATRIX – 24HR REVIEW CAMARO 2SS/RS - NO BS!! Matrix 5th Gen Camaro SS LS LT General Discussions 54 06-14-2009 03:37 PM
The Camaro, what it has come to mean for me Number 3 5th Gen Camaro SS LS LT General Discussions 23 04-13-2009 10:31 PM
2010 SMS Mustang TFord General Automotive + Other Cars Discussion 19 01-22-2009 12:00 PM
