RDP Motorsport
V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters
Old 07-26-2009, 10:07 AM   #26
bbardo
bbardo's Avatar
Drives: "Modi" son of "Thor"
2SSRS, Is this Holden part available in the US from Chevrolet dealers ?
Thanks
Originally Posted by 2SSRS View Post
#1 new reservoir from a GTO a Holden part # 92065790 list $19.33 but can get for $15.00
2SS/rs named "Modi"
Adopted & signed by Scott 8/15/09
Officially "Son #2 of Thor"
bbardo is offline   Reply With Quote
Old 07-26-2009, 11:25 AM   #27
2SSRS
On a list for a 2014 Z28
2SSRS's Avatar
Drives: 2010 Camaro 2SS M6
In a word Yes that is how i got it.
2SSRS is offline   Reply With Quote
Old 07-28-2009, 05:14 PM   #28
LDGn63
LDGn63's Avatar
Drives: WNABEE
Originally Posted by bbardo View Post
I would like to see the aftermarket offer this option.
Clutch dust can't be a good thing for the ABS to deal with IMO
+1000
Why oh Why?
Windshield=10" vertical
mirror= 3 7/8" (that's almost 4") vertical
that means that the mirror is 38.75% the size of the vertical windshield...
it sure seems like the ratio could be better... just sayin....
our collective MIRROR patch:
http://www.camaro5.com/forums/showthread.php?t=24612
LDGn63 is offline   Reply With Quote
Old 08-22-2009, 08:55 AM   #29
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
Anybody think a slightly larger resevoir will help with cooling. Finding a way to keep the brake fluid more cool will be next!
The reason I have seen to do this is to try and keep some heat out of the system...
ZZcamaro is offline   Reply With Quote
Old 08-22-2009, 09:12 AM   #30
2SSRS
2SSRS's Avatar
Good point, I know that the color if the brake fluid is not getting dark like when it was combined.
Old 08-22-2009, 09:13 AM   #31
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
I'll be changing to steel-braided brake lines; those help a little in dissipating heat plus give a more solid feel to the brakes. If you're doing that much braking (i.e. HPDE or autocrossing) you might want to look into brake ducts for cooling and/or 2-piece brake rotors. I'm trying to find rotors but so far nobody is saying they have one yet for this car. Everything is "in development" lol.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is online now   Reply With Quote
Old 08-22-2009, 04:09 PM   #32
SoloSK71
SoloSK71's Avatar
Another note added to my build list. Thanks for the info guys.
- SK
- 2G1FT1EW9A9132212
- Life is hard when destiny believes in you.
- As coherent as a pit bull in a spin dryer. A dribbling tartan frothbucket.
- Good money, bad girls. How can life be any better?
- God saves. The devil invests.
- This may be the ultimate guide to problem solving.
Originally Posted by MontyCarlo View Post
it's not a WD-40 problem, so it's got to be a duct tape problem
SoloSK71 is offline   Reply With Quote
Old 08-22-2009, 04:24 PM   #33
CamaroSpike23
The Jalopy Jedi
CamaroSpike23's Avatar
Send a message via MSN to CamaroSpike23 Send a message via Yahoo to CamaroSpike23
Brembo already has a Big Brake Kit for the camaro.
http://www.camaro5.com/forums/showthread.php?t=32767
Originally Posted by Bulldogwinters View Post
Read that link that Spike posted, it'll tell you everything you need to know.
I piss excellence
and fart awesomeness
Old 09-02-2009, 01:42 PM   #34
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Drives: 2SS RS, SIM, 6pd, 20"Alum
So my car has around 7000 miles on it. I just checked the resevoir today and the fluid is a "Killians Red" color. It was a clear golden color not to long ago.
My cap also leaks.
I'm going to take it into the dealership and have them take a look... I may try this separate reservoir fix though.
Embalmer is offline   Reply With Quote
Old 09-04-2009, 11:29 PM   #35
Doc
Doc's Avatar
Yeah they do make a big brake kit and it's got big break-you prices. Racing Brake now has a 2-piece front rotor for the SS that they're selling to Camaro5 members for 25% off. We have a group buy in progress:
http://www.camaro5.com/forums/showthread.php?t=40428
Just need 5 more people to get the deal. We'll get the rotors for $322 each and they are 4.5 lbs lighter than the stock rotors and do a MUCH better job of dissipating the heat.
1SS/RS LS3 M6 IBM
Old 09-05-2009, 10:53 AM   #36
SoloSK71
SoloSK71's Avatar
Nice find Doc, signed up for it for a friend of mine who bought an SS also.
- SK
- 2G1FT1EW9A9132212
Old 09-05-2009, 03:23 PM   #37
CamaroSpike23
The Jalopy Jedi
sweet doc. thanks
I piss excellence
Old 09-17-2009, 02:40 PM   #38
2SSRS
2SSRS's Avatar
My cap also leaks.
Doing this will not fix the "Killians Red" color of you Fluid, But it dos stop the leaks on your cap, And that Fluid is not in you brakes, I still change my fluid in the new Reservoir all the time but not in the brakes.
Old 09-17-2009, 02:45 PM   #39
coolman
Guest
Originally Posted by Vash View Post
Looks normal. With the dark background hard to tell.
The fluid system is sealed dust from the clutch won't get into the juice unless there is a defect. And if your temps are nominal for eng and tranny you should be fine.
Not true this issue has been a proven problem on vettes for a long time. Look it up. My dad has no problems on his vette as long as he fushes the brake flluid after he runs the car hard. I would greatly help to do a redesign. I don't know if that means seperating the two or not.
coolman is offline   Reply With Quote
Old 09-17-2009, 02:57 PM   #40
jamesc1123
jamesc1123's Avatar
Drives: CGM 2SS RS w/ white stripes
What about changing to a Corvette ZO6 master and slave cylinder? Anyone tried that yet? I know it'll be a lot more expensive, but looking at some aftermarket clutches, some of them tell you to get a corvette slave cylinder anyways, so prepare for the future...
Also, does anyone know if there's a difference between the ZO6 and standard corvette master and slave cylinders?
jamesc1123 is offline   Reply With Quote
Old 09-17-2009, 05:10 PM   #41
2SSRS
2SSRS's Avatar
You can do a Corvette master and slave cylinder but it is a lot of $ like 260 or more and that part is $19 so you can do what you want.
Old 10-02-2009, 08:14 AM   #42
mstrfdsstr
mstrfdsstr's Avatar
Drives: 2010 SS/RS CAMARO
is there another part pontiac cant find one everyone doing this
IOM 2 SS/RS LS3 vin9862
mstrfdsstr is offline   Reply With Quote
Old 10-02-2009, 08:41 AM   #43
rodimus prime
Drives: Cargo van.
I had huge problems with this on my t56 in my 98ss...especially after going to long tubes. It was commonly thought that the heat from the exhaust was boiling the clutch fluid and caused the slave to not get any fluid. I wrapped my headers, insulted the fluid line, did the master drill mod (not an issue on new masters) then even changed the master and slave cylinder. I had this issue with a 100% new clutch. There is no way it was brake dust alone causing this problem. I dont have a manual trans, but you might want to take a look at the routing of the clutch fluid line. Id bet its still near the stock exhaust.
I never had problems until I went to long tube headers though. After changing fluid upon fluid, modding parts and replacing everything. I gave up and went with a th350 anyways. Part of the reason I stayed away from stick this time. Its a huge problem throughout the lsx community.
http://www.ls1tech.com/forums/manual...-write-up.html
New dog with the same problems.
rodimus prime is offline   Reply With Quote
Old 10-02-2009, 09:54 PM   #44
2SSRS
2SSRS's Avatar
If you look at your brake master you can see where the hose for the clutch master and it is not near the stock exhaust.
Old 10-02-2009, 09:59 PM   #45
2SSRS
2SSRS's Avatar
You can go to any GM dealer and get it, Hear is a pic that is from http://www.gmpartsdirect.com/
And it shows that unit is good.
Old 07-27-2010, 11:22 PM   #46
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
I know that this is an old thread but it is worth bumping with a question in my opinion .
What size rubber plug did you buy for the brake master cylinder reservoir? Thanks and thanks for the write up, I've been telling quite a few people about this .
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 07-28-2010, 05:23 AM   #47
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Looking to do this mod also. I didn't like the rubber plug sealing off the brake master cylinder reservoir so I looked at an a6 transmission equipped SS Camaro to see if it's brake master cylinder reservoir could be used. It appears the brake master cylinder reservoir is the same for the m6 and a6 transmission cars, the factory just breaks off a plug to attach the clutch slave line on the m6 models. Now I have to find the P/N for the master cylinder reservoir. Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, Hawk HPS Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9 & 20x11 DS3 wheels with Pirelli Pzero 275/40/20 & 305/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, GM SS Fender & LS3 Emblems.
flht99b is offline   Reply With Quote
Old 07-28-2010, 07:46 AM   #48
daphatgrant
June '10
Huh... this is another great idea, looking at GMPartsDirect.com I think I found the correct reservoir part # 92234622.
I also got an answer back from 2SSRS, it's a 3/8" plug.
Old 08-08-2010, 10:31 PM   #49
drtwo
drtwo's Avatar
Drives: 2SS RS Yellow, Raptor, Vrod
So if I suck out the brake fluid (which apparently is DOT3 stock on the LS3) and replace only what is in the reservoir with DOT4, will that mixing DOT3 and 4 be a problem?
2SS RS Rally Yellow, LS3, M6, sunroof, extra on the fast!
drtwo is offline   Reply With Quote
Old 08-11-2010, 12:19 PM   #50
2SSRS
2SSRS's Avatar
No, you can mix dot 3 and 4, But not dot5.
Winner, winner - Jalopnik compares the Big 3 Number 3 5th Gen Camaro SS LS LT General Discussions 31 04-17-2011 03:24 PM
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 12:04 AM
MATRIX – 24HR REVIEW CAMARO 2SS/RS - NO BS!! Matrix 5th Gen Camaro SS LS LT General Discussions 54 06-14-2009 02:37 PM
The Camaro, what it has come to mean for me Number 3 5th Gen Camaro SS LS LT General Discussions 23 04-13-2009 09:31 PM
2010 SMS Mustang TFord General Automotive + Other Cars Discussion 19 01-22-2009 11:00 AM
