Caryle Racing
Old 12-29-2010, 02:54 PM   #267
caverman
caverman's Avatar
Drives: '69 SS Convertible
Originally Posted by flht99b View Post
Was not my intention to hijack 2SSRS's thread. All I wanted to do was show how I approached the remote clutch reservoir installation which is what I thought this thread was about. If I stepped on anyone's toes, I apologize and will start a new thread on this subject if need be. I think most if not all of us agree Chevrolet should have installed a separate clutch reservoir in these cars.
Ed M.
I didn't see you step on any toes. I'm glad that you posted what you did. It gives all of us options on where to mount the resivoir and I think your's turned out great.
To me this is exactly the kind of stuff this thread is for.
Build Journal
Old 12-29-2010, 04:10 PM   #268
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
i,m glad he did. helped me..
mikepage0007 is offline   Reply With Quote
Old 12-29-2010, 05:19 PM   #269
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Hay all this is meant to help all, Any good info(and some not good) that helps us all is what the intention of this Thread was, Now for turboguy327 don't get mad at him i think he meant too help, We are all friends on C5, We all shear a love of a grate car.
Old 12-29-2010, 09:36 PM   #270
mrbrans5
mrbrans5's Avatar
Drives: IOM Bahia Int. 2LT RS M6 SR BH
Clutch Reservoir
Awsome information from even better people...
Thanks to all...
mrbrans5 is offline   Reply With Quote
Old 12-31-2010, 06:32 PM   #271
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Got around to flushing the clutch hydraulic system today so that the entire clutch system would be nothing but the ATE Super Blue Racing DOT4 fluid I'm using. Chevrolet sure made bleeding the clutch a bit of a challenge although with a small, short 8mm wrench and an air fed vacuum brake bleeder it wasn't all that bad. I didn't notice any change in the clutch feel or actuation after the fluid change and bleeding but at least both my brakes and clutch systems are all fresh DOT4 now. Installed MTI SS brake lines and Hawk HPS pads along with a complete flush of the brake system today. The pads and SS lines are a definite improvement, well worth the $$ and effort.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 12-31-2010, 06:37 PM   #272
caverman
caverman's Avatar
Ed M.
Yesterday I got my calipers in and installed them along with some stainless lines as well. I used IPS's lines since I was able to get them on sale for $80 shipped. Should mostly be DOT4 now after bleeding.
I meant to flush my clutch resevoir while I was at it. Need to setup a reminder to do it tomorrow.
Build Journal
Old 12-31-2010, 08:14 PM   #273
2SSRS@Gen5diy
Ed M.
Good job to you nicely done have a good new year.
Nice looking car you have there, the calipers look, Wow is all i can say, By the way i did the DRL harnesses on my car, I will let turboguy327 take the lead on this if he dos not do any thing i will post in 2 weeks.
Happy new year.
Old 01-05-2011, 08:08 PM   #274
flht99b
flht99b's Avatar
Finally got around to taking a picture of the parts I put together to mount the GTO clutch reservoir as I did in post # 237. PM if you have any specific questions.
Ed M.
Old 01-06-2011, 11:33 PM   #275
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Yes. I've read numerous threads on this topic and also saw a video that displayed the chunks of crap in the fluid.
Seems to me separating the two wouldn't hurt, and chances of a reservoir failing is fairly slim.
GM just wanted to save some cash. I'd like to see an aftermarket solution similar to the Vettes.
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
calbert1999 is offline   Reply With Quote
Old 01-07-2011, 04:10 PM   #276
2SSRS@Gen5diy
But there is and your on that thread, For the cost of a second reservoir and the regular changing of brake fluid you have a much better clutch pedal, One last thing this part is a Holden part so if it was good for them its good for US.
Old 01-08-2011, 03:17 PM   #277
mrbrans5
mrbrans5's Avatar
Brake Reservoir
I finally added my brake reservoir. I was torn between 2SSRS and flht99b’s location. Both are good locations and I would like to thank both of them for all their help. I think I’m going to replace my reservoir hose though. It would look better with a little more slack in the routing.
Next up is a remote bleeder for the system.
Old 01-08-2011, 03:29 PM   #278
caverman
caverman's Avatar
Nice work! Looks like you got yours nice and level.
I may end up re-positioning mine someday. Need to get a good and driver first.
Build Journal
Old 01-10-2011, 05:24 PM   #279
Hutch52
Hutch52's Avatar
Drives: 2011 Victory Red 2SS RS M6
Thanks flht99b, for all the help on the clutch reservoir.
Hutch52 is offline   Reply With Quote
Old 01-11-2011, 06:44 AM   #280
flht99b
flht99b's Avatar
Glad I could help.
Ed M.
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 01:04 AM
MATRIX – 24HR REVIEW CAMARO 2SS/RS - NO BS!! Matrix 5th Gen Camaro SS LS LT General Discussions 54 06-14-2009 03:37 PM
The Camaro, what it has come to mean for me Number 3 5th Gen Camaro SS LS LT General Discussions 23 04-13-2009 10:31 PM
2010 SMS Mustang TFord General Automotive + Other Cars Discussion 19 01-22-2009 12:00 PM
