Old 02-24-2011, 08:23 AM   #295
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Any more pictures of different installs of the reservoir ??. Curious if anyone has come up with a different solution than the 2 different mounting locations detailed in this thread. It may be in all my head but since I installed the GTO reservoir, changed to DOT4 fluid and bled the system my clutch pedal feel and shifting are smoother. Anyone else notice an improvement ??
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 02-24-2011, 09:07 AM   #296
TC
TC's Avatar
Drives: 2010 VR 2SS-RS
Here are some pics of the custom brackets I made for the reservoir and battery terminal. I wanted to install it in a way that looked like a factory part. I cut the brackets out of 1/8" Aluminum plate. I mounted the reservoir to the bracket with a couple of blind screws from the local hardware store.The new bracket is mounted to the front mounting whole in the master cylinder using the original screw. Haven't installed the new terminal bracket yet but should have it done sometime today and will post up some pics.
TC is offline   Reply With Quote
Old 02-24-2011, 09:09 AM   #297
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
Now that's a good lookin install.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 02-24-2011, 09:46 AM   #298
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Ed M.
As long as you replace the fluid, You will have smoother shifting, And you will see that you fluid does not get red like the OEM.
Old 02-24-2011, 10:29 AM   #299
booenson
Drives: 2010 1SS/RS M6
Nice install TC. I've been wanting to do this mod but wasn't happy with what people have been doing, but that's just me. I had the idea of fabbing up a bracket and mounting it to the reservoir somehow, but your idea is looks good.
I take it that the stock hose is plenty long enough to reach the new spot as well? And was moving the battery cable over necessary?
booenson is offline   Reply With Quote
Old 02-24-2011, 11:06 AM   #300
TC
TC's Avatar
The stock hose is not long enough. It takes about 16"- I think the original hose was only 14". I purchased the new hose from a commercial truck supplier. 3/8" triple wall, I believe the OE is metric and could not find the right size. 1/4" is a bit to small.
I have Procharger that came with a relocation bracket. Problem is that I put a much bigger filter on than which came with the kit and the inside is being smashed by the terminal.
Old 02-24-2011, 05:43 PM   #301
ssmike
BliSSard has come!
ssmike's Avatar
Drives: '16 Camaro 2SS, '13 Equinox CRT
TC, Looks great! Good job!
ssmike is online now   Reply With Quote
Old 02-24-2011, 06:03 PM   #302
sting808
Drives: 2010 SS RS
Just installed reservoir and remote bleeder. Some observations...
Reservoir could be bigger, constantly filling after couple air bleeds.
I installed a remote bleeder. OE bleeder a PITA. Borescope helps, but still PITA. Finger tip threading and unthreading. Take precautions not to allow OE bleeder tube to drop in the bell housing.
Anyone use a Motive brake/clutch bleeder kit on the Camaro? Comes with compatible clutch and brake caps? Manual bleeding sucks.
sting808 is offline   Reply With Quote
Old 02-24-2011, 08:21 PM   #303
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
just thought i would mention ..napa sells the edmp caps for around 4.00 with 2-3 caps in package..got mine local..http://www.napaonline.com/Search/Det...698_0006409386
mikepage0007 is offline   Reply With Quote
Old 02-24-2011, 09:15 PM   #304
sting808
Drives: 2010 SS RS
Good point I didnt mention. Used edpm cap and hose. Looking into a motive power bleeder for clutch and brakes just for convenience.
Had 7000 miles on car and fluid was dark.
Old 02-24-2011, 11:31 PM   #305
Nomad
Nomad's Avatar
Drives: '11 2SS/RS RJT M6
Nice job! Oh, to have a shop at my disposal again...
Vararam CAI, Elite Engineering Catch Can, Separate Clutch Fluid Reservoir, Ghost Armor Full Protection Package, Chromed Turn Signal Bulbs, RPI Stealth Splash Guards, Skip Shift Eliminator, Defenderworx Chrome Bowtie Inserts, Pfadt Trailing Arms, Camaro Decal Store CGM Hood Spears with "376ci" custom text, Billet Depot/Drake Underhood Polished Caps, CGM Lug Nut Decals, Pedders Front Radius Rod Inserts, JacFab Front License Plate Bracket
Nomad is offline   Reply With Quote
Old 02-24-2011, 11:43 PM   #306
Orange Krate
Not just any car!
Orange Krate's Avatar
Drives: Orange Krate DOB - 11/22/2010
Lightbulb
Question for the group... in looking at the awesome mods for the relocation of the aux reservoir, I noticed some brackets being painted. Since brake fluid/hydraulic fluid is so corrosive to paint, is there any kind of paint that will not be eaten up by fluid getting spilled on it? I don't know enough about powder coating but I am thinking maybe that is the way to go? Painters out there???
Simi Valley, CA
email: orangekrate2011@yahoo.com
Orange Krate is offline   Reply With Quote
Old 02-25-2011, 12:05 AM   #307
turboguy327
Banned
Drives: 2011 Chevy Camaro
Dont spill the brake fluid on the bracket. Once the cap is on and sealed your bracket will be fine.
turboguy327 is offline   Reply With Quote
Old 02-25-2011, 08:36 AM   #308
caverman
caverman's Avatar
Drives: '69 SS Convertible
I put towels down under it to help protect the fender wells and if you do accidentally spill some pour some water on it as fast as you can....but don't get any water in the resivoir. Keep a cup next to you ready to go.
Build Journal
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 01:04 AM
MATRIX – 24HR REVIEW CAMARO 2SS/RS - NO BS!! Matrix 5th Gen Camaro SS LS LT General Discussions 54 06-14-2009 03:37 PM
The Camaro, what it has come to mean for me Number 3 5th Gen Camaro SS LS LT General Discussions 23 04-13-2009 10:31 PM
2010 SMS Mustang TFord General Automotive + Other Cars Discussion 19 01-22-2009 12:00 PM
