Anthony @ LG Motorsports
Old 10-02-2009, 09:41 AM   #43
rodimus prime
Drives: Cargo van.
I had huge problems with this on my t56 in my 98ss...especially after going to long tubes. It was commonly thought that the heat from the exhaust was boiling the clutch fluid and caused the slave to not get any fluid. I wrapped my headers, insulted the fluid line, did the master drill mod (not an issue on new masters) then even changed the master and slave cylinder. I had this issue with a 100% new clutch. There is no way it was brake dust alone causing this problem. I dont have a manual trans, but you might want to take a look at the routing of the clutch fluid line. Id bet its still near the stock exhaust.
I never had problems until I went to long tube headers though. After changing fluid upon fluid, modding parts and replacing everything. I gave up and went with a th350 anyways. Part of the reason I stayed away from stick this time. Its a huge problem throughout the lsx community.
http://www.ls1tech.com/forums/manual...-write-up.html
New dog with the same problems.
rodimus prime is offline   Reply With Quote
Old 10-02-2009, 10:54 PM   #44
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2010 2SS IOM ,2014 Z/28, 66 Nova
If you look at your brake master you can see where the hose for the clutch master and it is not near the stock exhaust.
Old 10-02-2009, 10:59 PM   #45
2SSRS@Gen5diy
Originally Posted by mstrfdsstr View Post
is there another part pontiac cant find one everyone doing this
You can go to any GM dealer and get it, Hear is a pic that is from http://www.gmpartsdirect.com/
And it shows that unit is good.
Old 07-28-2010, 12:22 AM   #46
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
I know that this is an old thread but it is worth bumping with a question in my opinion .
What size rubber plug did you buy for the brake master cylinder reservoir? Thanks and thanks for the write up, I've been telling quite a few people about this .
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 07-28-2010, 06:23 AM   #47
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Looking to do this mod also. I didn't like the rubber plug sealing off the brake master cylinder reservoir so I looked at an a6 transmission equipped SS Camaro to see if it's brake master cylinder reservoir could be used. It appears the brake master cylinder reservoir is the same for the m6 and a6 transmission cars, the factory just breaks off a plug to attach the clutch slave line on the m6 models. Now I have to find the P/N for the master cylinder reservoir. Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 07-28-2010, 08:46 AM   #48
daphatgrant
June '10
Huh... this is another great idea, looking at GMPartsDirect.com I think I found the correct reservoir part # 92234622.
I also got an answer back from 2SSRS, it's a 3/8" plug.
Old 08-08-2010, 11:31 PM   #49
drtwo
drtwo's Avatar
Drives: 2SS RS Yellow, Raptor, Vrod
So if I suck out the brake fluid (which apparently is DOT3 stock on the LS3) and replace only what is in the reservoir with DOT4, will that mixing DOT3 and 4 be a problem?
2SS RS Rally Yellow, LS3, M6, sunroof, extra on the fast!
drtwo is offline   Reply With Quote
Old 08-11-2010, 01:19 PM   #50
2SSRS@Gen5diy
No, you can mix dot 3 and 4, But not dot5.
Old 08-11-2010, 07:34 PM   #51
drtwo
drtwo's Avatar
excellent. So if I see that the 'brake' fluid is getting dirty looking, I can gradually replace it with Dot4 fluid (which apparently is somehow better)?!
Old 08-11-2010, 09:39 PM   #52
2SSRS@Gen5diy
Depending on the brand Dot 4 has a some what higher boiling point, So yes you can. ( That sounds like a theme from 2 years ago)
Old 08-11-2010, 09:59 PM   #53
CAMAR0
Loose is Fast!
CAMAR0's Avatar
Drives: Mikes Hard Lemons
I will be doing the GTO reservoir also to help this POS Stick / Clutch in the V6 to feel more like a decent trans. When I sit at the light after decent braking on a HOT day I get a light pulsating feedback in my pedal when the clutch pedal is to the floor.
CAMAR0 is offline   Reply With Quote
Old 08-12-2010, 08:56 AM   #54
lellowSS
lellowSS's Avatar
Drives: 2010 Rally Yellow 2SS M6
At the dealership now for the same problems and they say there is nothing wrong with it. I guess I'll try the separate resevoir and also a tranny fluid exchange for RP. See if it makes any difference. Where were you able to find the 3/8" plug? Auto parts store, home depot???
Thanks for your help.
Deliv. 8/20/09 SOLO Mach X Catback, SOLO HF cats, CAI Cold Air
lellowSS is offline   Reply With Quote
Old 08-12-2010, 12:07 PM   #55
2SSRS@Gen5diy
Any auto parts store will have it, One more thing I know as this is a new car we as customers don't think we are its right to have too change the brake/Clutch fluid in the reservoir, And i think the same way, But this is a high performances can and dos require some maintenance.
All i did was go to walmart Get some dot 4 brake/Clutch fluid .
Old 08-13-2010, 12:30 PM   #56
CAMAR0
Loose is Fast!
CAMAR0's Avatar
GM put a hold on my reservoir order. Had to get on cars.com to find a vin for an 06 gto m6 to get them to release the hold.
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 01:04 AM
MATRIX – 24HR REVIEW CAMARO 2SS/RS - NO BS!! Matrix 5th Gen Camaro SS LS LT General Discussions 54 06-14-2009 03:37 PM
The Camaro, what it has come to mean for me Number 3 5th Gen Camaro SS LS LT General Discussions 23 04-13-2009 10:31 PM
2010 SMS Mustang TFord General Automotive + Other Cars Discussion 19 01-22-2009 12:00 PM
