| V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters |
Thread Tools |
#101 |
Loose is Fast!
Drives: Mikes Hard Lemons Join Date: Feb 2010
Here is the diagram of the GTO hydraulic clutch system that we are borrowing the reservoir from, see No 1 for P/N 92065790. (Note this reservoir does not have any holes in the bottom to attach to a master cylinder)
#102 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
Pulling the oil out that low would probalby cause air bubbles to get in the lines. I would think it would be easier to have a couple plugs ready to go, put a bucket or towel underneath it and try to make the switch real quick.
Build Journal ![]() |
#103 |
Loose is Fast!
My plan is to fill the engine compartment with towels. (brake fluid eats paint like the cookie monster on some nestle tollhouse specials) Clamp the clutch line lightly. Pull it and plug the master. Slide on the hose clamp over the plug and tighten. Hold up the clutch line and release clamp and attach to reservoir. Fill clutch reservoir. Screw to pretapped holes on strut tower back side. About to attempt in 30mins. Will let you know how it goes along with pics of the plug pkg from autozone.
#104 |
Loose is Fast!
No dice, going to have to make a bracket to get the reservoir to mount how i want. Will post pics if i get it done today.
#105 | |
Keep us posted on how it goes and get some pics.
#106 |
Loose is Fast!
Ill try to finish up tomorrow. Only had 35 min to mess with it today. Next up, Bristol!!
#107 |
Dog Is My Copilot
Drives: 2011 2SS/RS LS3 Join Date: Jun 2009
Well, I didn't get around to doing my swap, either. I installed my Heritage grill instead. Here's a pic of the new reservoirs, in case anyone hasn't seen what it looks like without the clutch line tab removed. I can't exactly say it's pretty, but I'll feel more secure this way vs. using a plug:
#108 |
Loose is Fast!
http://www.dormanproducts.com/p-2166-41050.aspx
http://www.autozone.com/autozone/acc...mString=search Im just using the 3/8" cap from this kit with a hose clamp over it. Should be as secure as the original hose connection. $3.75+tax. ![]() ![]()
#109 |
![]() ![]() ![]() ![]() Drives: 11 IOM 2SS/RS M6 w/Hurst Join Date: Nov 2009
Depending on what those are made of you may want to switch out to EPDM caps.
http://www.mcmaster.com/#epdm-rubber-caps/=8j87t1 Cheers K |
#110 |
![]() Drives: 2011 2SS/RS SIM L-99 Join Date: Jun 2010
gmparts direct said the reservoir is on national backorder....
1st---2010 1SS/RS IBM LS3, Silver Bumblebee Stripes, Borla S-type---too many clutch issues, let her go....
Now---2011 2SS/RS SIM L99---Borla S-type, Black Rally Stripes. http://www.gofundme.com/Tom-Easter-Jr-Fund |
#111 |
Loose is Fast!
The ones I bought are Neoprene caps.
#112 |
Yes....but I found a couple in FL. I got charged but haven't seen it yet. Hope it comes in by tomorrow.
How did you install go? Where you able to finally get it finished?
#113 |
Loose is Fast!
Mounting to the strut tower looked like duke so im working on a bracket that mounts under the plastic cowl piece and turns 90 to face the other reservoir. Ill just have to turn the hose 180 where it comes off the master cylinder then. Ill post pics of the bracket once im done cutting and welding.
On a side note, theres a used c5 reservoir on ebay that looks like the same design as the gto for $60 shipped. |
#114 | |
#115 |
![]() Got my reservoir in today. I'll try to get it installed in the next week or so. Need to make a run to the auto store to pick up the remaining stuff. CAMARO.....waiting to see what you do with yours as well.
#116 |
On a list for a 2014 Z28
![]() Drives: 2010 Camaro 2SS M6 Join Date: Oct 2008
So i but my parts guy on this and there are only 2 GTO reservoir in the US right now and they are at your FL dealer, On the good side i ordered 10 Pc and hope to have them in 60 Days.
#117 |
Loose is Fast!
I'll take pics installed and out. The problem with the strut tower is that i don't have a tight 90 degree drill to drill the holes where you'd have to in order to get it to mount properly and even then it looked out of place when I held it there. I want it to appear stock. I had a M6 gto and I know how they mounted and it was up above just below where the hood seals to the plastic cowl piece. I am hoping to do something like that and get a new hose or make my bracket turn 90 and reuse the hose.
I have the metal partly done but haven't had time to finish it up. My mom is selling her business and I'm renting out my other home this week so spare time has been non existent. Thursday or Friday I should be able to get this wrapped up though. |
#118 |
![]() Drives: 4 wheels Join Date: Apr 2009
When I checked on Friday at my local dealer,
(1) Bunnin Buick, CA (SOLD) (1) Shamley Pon-Buick-GMC, TX (1) Day-Centennial Chevy, PA (2) Homestead Chevy, FL CA piece is sold and being delivered. Guess the others are being scooped up. Need to find someplace that has reasonably priced fog lamp housings and wiring harness in stock. |
#119 | |
FL was the only place that could be found right now.
#120 |
Dog Is My Copilot
I've got the one from Day-Centennial. It was special ordered...it should be out of their inventory by now.
#121 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3/6M Litho#190 Join Date: May 2010
Well....I can positively tell you that Day-Centennial does not have one anymore,I'm the parts manager there and its sold!
![]() '11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned Proud Litho owner #190 - Homecoming Litho #120 '07 SILVERADO Z71 1500 Ext.Cab Z71 6.0 "VortecMAX"-GMPP CAI-CORSA-Black Bear tuned |
#122 | |
#123 |
#124 |
Did my resivoir a couple days ago. Of course it wasn't as easy as I thought. The theory is easy but getting your hands in that small of an area to pre-drill the wholes isn't.
There isn't a real good level area as well so my resivoir is tilted upwards some. Still looks okay. It doesn't take very much fluid at all to fill it up. Like 1 - 1.5 oz. BTW: Even after getting the shaft for the acutal resivoir I have about $40 and about 2hrs in the whole thing.
Build Journal ![]() Last edited by caverman; 08-31-2010 at 10:50 AM. |
#125 | |
![]() Drives: 69 Camaro, 87IROC, 96 SS, Z06 & 2LT Join Date: Apr 2010
If you read the Corvette forum, you will see that if you do much high RPM shifting, the clutch fluid becomes dark quickly. Some forum members have analyzed the fluid and found the contamination to be clutch dust and not natural deterioration from moisture, seals, etc. What happens is that when you get a lot of clutch dust in the clutch housing, some of it works its way past the slave cylinder seal and into the fluid. This is also confirmed by the fact that if you drive and shift normally, the fluid stays clean much longer. It only takes a few drag racing runs to turn the fluid dark again, and you can actually see bursts of clutch dust out the bottom of the car during shifts. http://www.rangeracceleration.com/Clutch_Care.html Last edited by Texhawk; 08-31-2010 at 07:54 PM. |
| Thread Tools | |
| Winner, winner - Jalopnik compares the Big 3 | Number 3 | 5th Gen Camaro SS LS LT General Discussions | 31 | 04-17-2011 03:24 PM |
| What's considered a Muscle Car? | SyN | General Automotive + Other Cars Discussion | 125 | 09-25-2010 12:04 AM |
| MATRIX – 24HR REVIEW CAMARO 2SS/RS - NO BS!! | Matrix | 5th Gen Camaro SS LS LT General Discussions | 54 | 06-14-2009 02:37 PM |
| The Camaro, what it has come to mean for me | Number 3 | 5th Gen Camaro SS LS LT General Discussions | 23 | 04-13-2009 09:31 PM |
| 2010 SMS Mustang | TFord | General Automotive + Other Cars Discussion | 19 | 01-22-2009 11:00 AM |
