Old 08-17-2010, 09:42 PM   #71
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Originally Posted by CAMAR0 View Post
It looked like you just unhook the hose from the brake/clutch reservoir, plug the hole, attach to the gto clutch reservoir. Am i right?
That is all it takes to do it, and get a 3/8 plug and 2 hose clamps
Originally Posted by Petersimov View Post
when u do this mod do u need to bleed the clutch after
No all you do is pump the pedal 10 times stop and pump it one more set.
Originally Posted by clg_98ta View Post
I just got my GTO clutch reservoir from GMPartsDirect... I ordered a month ago and got an email saying it was on national backorder (3rd time trying to order it). Then 2 weeks later I got another email saying it had shipped.
Now I guess I need to install it...
If you don't i will buy the reservoir from you for my Z28 next year.LOL
Originally Posted by nak3dsnake View Post
I'm interested in this mod as well. If it helps any on the v6 I'll probably end up doing it myself.
Don't see why not use it in the V6.
Old 08-17-2010, 09:53 PM   #72
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
True.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 08-17-2010, 10:33 PM   #73
CAMAR0
Loose is Fast!
CAMAR0's Avatar
Drives: Mikes Hard Lemons
It's going into my V6 tomorrow.
I'll get back to you guys and let you know how the install goes on a V6.
CAMAR0 is offline   Reply With Quote
Old 08-17-2010, 11:40 PM   #74
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
I also got the call that my GTO reservoir and new Camaro reservoir are in. I believe it's been posted before, but the L99 and LS3 cars both use the same combined reservoir...there's just a tab that they snap off to attach the hose for the manual cars. I am going with a new reservoir to avoid any issues with the hose plug leaking...
Kilo-9 is offline   Reply With Quote
Old 08-18-2010, 09:13 AM   #75
2SSRS@Gen5diy
That is right its the same brake reservoir on the LS3 and L99 cars. and the same on all the V6 cars.
Old 08-18-2010, 11:02 AM   #76
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
So the GTO reservoirs are available now? When I went to do this they were on backorder.
Cheers
K
Moriartii is offline   Reply With Quote
Old 08-18-2010, 11:25 AM   #77
Moriartii
Moriartii's Avatar
Just ordered both the GTO and Camaro reservoirs, so we shall see.
Cheers
K
Old 08-18-2010, 11:43 AM   #78
CAMAR0
Loose is Fast!
CAMAR0's Avatar
Yup, ordered thurs came in tuesday. $14 at dealer.
Old 08-18-2010, 03:02 PM   #79
caverman
caverman's Avatar
Drives: '69 SS Convertible
Which dealer did you buy it from?
I just called a couple local dealers and the don't have it, said it was on back order, and I would need a VIN to order it.....and no ETA on arrival.
Anyone have a GTO VIN they can PM to me so I can use it?
Build Journal
Old 08-18-2010, 04:42 PM   #80
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
There are some available,The dealer just has to know how to order them (And a GTO VIN does help!)
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 08-18-2010, 05:17 PM   #81
caverman
caverman's Avatar
I just got an email back from GMPartsDirect and they said they are backordered with no ETA.
Build Journal
Old 08-18-2010, 05:53 PM   #82
CAMAR0
Loose is Fast!
CAMAR0's Avatar
Question
Ill PM you the one i usd when i get home. Orderex from hubler chevrolet indianapolis, in.
Old 08-18-2010, 09:04 PM   #83
SC2150
The issue is the same one experianced by the C5 & C6 vettes for years. The real issue is several design flaws not corrected properly since 1997. First the line from the master to the slave runs to close to the exhaust, and adding headers makes it even more of an issue since the heat causes the fluid to breakdown & and develop sludge, which reduces the ability of the fluid to move back and forth through the system.
Second, the resivoir on the master is to small for agressive driving allowing the fluid to break down to quickly (you can do frequent changes like the road course guys do and avoid the issue).
The cars driven "normally" (read: slow shifts) rarely encounter this issue, but quick & frequent fast shifts and clutch action are where it rears it's ugly head.
There have been several fixes through the years, the "drill" mod, different fluids, etc., but the only real solution is a remote large capacity resivoir and a way to move, or circulate the fluid through it so there is always a fresh, cool, clean supply of fluid to the system.
Not very practical for the everyday average driver, but a great mod for the agressive driver or road racer.
I have not released this system yet, but if anyone wants more info let me know.
Old 08-18-2010, 10:49 PM   #84
Moriartii
Moriartii's Avatar
So let me pose this question, if the GTO reservoir seems to be a bugger to get, why couldnt one get another Camaro reservoir and use that in tandem? It it has the to outlets use that bridged into one line, so you would have the original reservoir for the brake system. Then the second Camaro reservoir with two lines going to a "Y" for the clutch??
Crazy idea?
Cheers
K
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 01:04 AM
MATRIX – 24HR REVIEW CAMARO 2SS/RS - NO BS!! Matrix 5th Gen Camaro SS LS LT General Discussions 54 06-14-2009 03:37 PM
The Camaro, what it has come to mean for me Number 3 5th Gen Camaro SS LS LT General Discussions 23 04-13-2009 10:31 PM
2010 SMS Mustang TFord General Automotive + Other Cars Discussion 19 01-22-2009 12:00 PM
