Anthony @ LG Motorsports
V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters
Old 07-25-2009, 12:51 AM   #1
camarogolfguy
Camarogolfguy
camarogolfguy's Avatar
Drives: 2012 ssrs
Cool transmission clunk
I have a 2ss rs 6m. It has about 500 miles on it. To my knowledge I am not one of those with the transmission failure problem. During normal driving, I hear an audible clunk when shifting in lower gears. If I let the clutch out slowly, I can ease it into gear without the clunk. I don't hop on it - just normal shifting.
I have had several mt over the years, but this is the first time I recall ever encountering this kind of issue.
Is this normal? Should I have the dealer look at it?
camarogolfguy is offline   Reply With Quote
Old 07-25-2009, 12:55 AM   #2
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
You're probably causing the sound by the speed you release the clutch. Try releasing it a bit slower after it hooks up with the 1st or 2nd gear... Mine makes no such sound btw so if yours still does at any speed you release the clutch at while giving gas, you should take it in to get checked.
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 07-25-2009, 12:57 AM   #3
JDBeck23
Drives: 2010 Camaro, 2SS/RS
Well from your description it sounds like you're lugging the car a bit when shifting (which actually is normal since these cars are designed to be skip shifted and lugged in the next gear). If you take the revs up a little higher you'll notice that the clunk goes away.
The clunk is the slack in the driveline. Because of the IRS, you now have 2 extra U joints that will "slack" when you press the clutch in to shift and then when you begin to let the clutch back out, that "slack" is drawn back up quickly. It's very normal for IRS cars.
But if you're concerned, by all means, take the car into the dealer and have her looked at.
And you havent been driving your car hard enough to encounter the "failure" problem yet. Rev it to 5k and dump the clutch (just kidding, dont do that during break in!) and you'll find out if your tranny is one of the broken ones!
2010 2SS/RS CGM
American Racing Headers, Magnaflow axle back, Roto-Fab CAI, Audio Integrations Sub box, Alpine Type R 10, Alpine MRP-500 amp, Pro Clips iPhone Mount
JDBeck23 is offline   Reply With Quote
Old 07-25-2009, 01:05 AM   #4
camarogolfguy
Camarogolfguy
Drives: 2012 ssrs
Excuse my igorance, Lugging?
Also, I have noticed the car asking me to go from 1st to 4th at a slow acceleration. I am aware this a GM thing. My brother's 03 Vette also had this feature. I have been going into 2nd anyhow (it fights me a bit, but will make the shift into 2nd). It just doesn't make sense to skip the two gears when the rpm's can't be much more than 1200 or so at the point it wants me to go directly into 4th. If I don't skip shift, is this going to cause a problem?
Old 07-25-2009, 03:14 AM   #5
BackinBlack
KASPR
BackinBlack's Avatar
Drives: 2010 Black 2SS RS LS3
DON'T FORCE IT TO ANOTHER GEAR if it wants you to go to 4th. Just speed up more or coast with the clutch in until the skip-shift message goes away before shifting into a different gear.
BackinBlack is offline   Reply With Quote
Old 07-25-2009, 04:34 AM   #6
JDBeck23
Lugging the motor means to have the RPMs too low while starting out in a particular gear. When you release the clutch you'll get a slight clunk and then the motor will "lug" along, and make it feel like the whole car is shaking.
That is the main reason why I hate skip shift. It forces you into lugging the hell out of the motor. It's designed to help you get better gas mileage, but I dont like skipping 2 gears, it makes the car barely crawl forward. I do the 1-3-5 alot, and it keeps the rpms low while still allowing me drive in a way that feels more natural for my driving style.
I agree with Back in Black, do NOT force the shifter when the computer is telling you to 1-4 shift. You can step on the gas a bit longer in 1st... or what I like to do is trick the computer a little... I juke it... Basically, when I get the 1-4 shift on the DIC, I put the clutch in and pull the shifter out of first and ever so barely move it down to 4th, just a tiny hair and it's enough to turn the 1-4 solenoid in the tranny off. So I've got it down to a silence when someone's sitting next to me they never notice that it took me an extra splits second to shift from first to third.
And the best part is it's almost a natural motion. Pull the shifter out of first and it slaps to the center, ever so gently move the shifter torwards 4th for a split second and then push it up into third in a nice, affirmative motion, that's all it takes...
2010 2SS/RS CGM
Old 07-25-2009, 04:50 AM   #7
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
Drives: Sky Redline & Camaro 2SS/RS
Can you get rid of the SKip SHift in competition mode?
ITS HERE! : 2010 Camaro 2SS / 6 Speed Manual (No other way) / Silver Ice Metallic / Inferno Orange Interior Accent / RS Package / Polished Wheels / SOLO MACH X CAT BACK
Xmicro_SS is offline   Reply With Quote
Old 07-25-2009, 12:50 PM   #8
LosXC451
LosXC451's Avatar
Drives: 2010 SS SIM w/ RS
My transmission broke and i didn't even drive it hard.
LosXC451 is offline   Reply With Quote
Old 09-04-2009, 10:56 AM   #9
Mi P
Drives: 10-2ss, 02 Z71, 00 Buell X1, 87 S15
re
Ok so my first impression, When on the Highway, lets say Cruising at whatever speed in 6th, you let off the gas for whatever reason then give it the gas again, there is a Thud/clunk. Not talking about tromping on it either here, just normal lift pressure from pedal and re-aapply it.
Is this the same thing? i can understand the IRS and the extra linkage, but it seems like it is prominent.
IOM 2SS/RS MN6 w/IOM Interior Sunroof - 1100, Preliminary order accepted - 6/12/09 NKNJV9 - 2000, Accepted by GM - ??? -- 2500, Preferenced ~ 7/29/09 - 3000, Accepted by production control ~7/31/09 TPW--08/17/2009 TY Viz
3300, Scheduled for production ~ 8/5/09 - 3400, Broadcast - Being Built ~ 8/13/09 - 3800, Produced - Built- has VIN ~8/19/09 2G1FT1EW2A9137896 - 4000, Available to ship - 8/21/09 - 4200, Shipped - 8/25/09 via Truck.
4300, Intermediate Delivery-4B00, Bayed-5000, Delivered to the dealer - 8/31/09
6000, Delivered to the customer- 9/03/09
Mi P is offline   Reply With Quote
Old 09-04-2009, 11:05 AM   #10
djm96z28
djm96z28's Avatar
Drives: 2012 Camaro 1SS LS3
Can't you just go from 1st, to 3rd, then to 4th? That's how I drove a buddy's 4th gen 6 speed with no problem.
djm96z28 is offline   Reply With Quote
Old 10-17-2009, 11:29 AM   #11
Bigred1981
Drives: 2LT Red Jewel Coat 6sp
help Im hearing the same type of clunking noise at very low speeds in my v6 6speed. It only happens when I'm in first gear and it continues when I'm driving in first up to about 15 miles per hour, when I shift into second it is fine. The car has only 100 miles on it
Bigred1981 is offline   Reply With Quote
Old 10-17-2009, 05:00 PM   #12
JDBeck23
if you're hearing a clunk while in gear and accelerating, that's a different problem and you need to take your car to the dealer have them look at it. That's not normal.
2010 2SS/RS CGM
Old 10-23-2009, 07:55 PM   #13
Dave the Mule
Dave the Mule's Avatar
Drives: 2LT/RS
I'm having a similar issue with my V6 6M. When I shift from 1st to 2nd, I get a clunk as I let the clutch out. I've found it very difficult to have a nice smooth acceleration because the 1st to 2nd transition is so rough. I've got about 250 miles on mine so far. I'm hoping some of this may go away as the transmission breaks in and as I get better at driving it.
Dave the Mule is offline   Reply With Quote
Old 10-24-2009, 06:47 AM   #14
PsyDoc
Drives: Soon-to-be 1st Gen
With a two-piece drive shaft, you are bound to have a clunk due to slack as JDBeck23 stated. A lot of guys on the Mustang forums have gone to the "traditional" one-piece drive shaft and doing so eliminated the "clunk" that is also present in the Mustangs. For whatever reason, a two-piece is somehow more cost effective from a manufacturing standpoint than a one-piece.
PsyDoc is offline   Reply With Quote
Old 10-24-2009, 09:29 PM   #15
nemosgt
Drives: 2006 Ford Mustang GT
Send a message via ICQ to nemosgt
Mustangs and Camaros all have wide tolerances that cause drive train slop when rowing the gears. Once you get into the next gear everything tightens up in that direction and shifts are normal. But as soon as you shift out of order or start shifting in the other direction you get the clunking again as everything lines up the other way. Nature of the beasts. The ones that do not, have better tolerances. Consider yourself lucky in that case. These are not BMWs after all. I've owned two late model Camaros ('95 and '98) and two late model Mustangs ('03 Mach 1 and '06 GT) and they were all the same. It's normal. Ditto for the transmission rattles. Come up through the shifter as a vibration. If you want to hear a real noise, try an after-market shifter. I've done it twice and both times had them removed. Don't learn I guess.
This was part of my reply to another thread.
Regarding the skip-shift; just accelerate a little harder and shift at a higher RPM or short-shift direct to third gear. The 4th gens had the same fuel-saving feature, but could be defeated with a $29 resister plugged into the transmission housing and did not throw any codes. Should be available from someone soon or maybe it can be removed with one of the plug-in tuning devices. Anyone know?
Cheers.
nemosgt is offline   Reply With Quote
Old 04-08-2010, 10:59 AM   #16
pilot_52
Drives: 2SS
Summit has a skip shift defeat plug and works great.
pilot_52 is offline   Reply With Quote
Old 04-08-2010, 02:59 PM   #17
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: 2010 1SS/RS IBM
Ouch
It hurts me to read this.
You will destroy the synchro if you keep trying to force it like that.
Old 09-26-2010, 11:06 PM   #18
junkM6
Drives: 2010 1ss RS
I have many of the same issues with my 2010 1ss m6, it just seems to me most of th slop is in the transmission. The dealership says it's normal, but I think it's embarrassing when you can hear the rattle/clunk outside of the vehicle... I say fix it or buy that noisy junk back, after all mustang transmission is made in China and does not make noises like that.
junkM6 is offline   Reply With Quote
Old 09-28-2010, 04:22 PM   #19
ICEMAN 316
ICEMAN 316's Avatar
Drives: FAST
I have this problem with my 2SS too. It only happens when i'm driving slow in 1st or 2nd gear it'll happen either when I let go of the gas or depress the clutch. I had this problem with my other stick cars too one was a 2006 Scion xB and my 2007 BMW 550i..
2011 Camaro 2SS M6 | Matte Orange Vinyl Wrap | Turbonetics Turbo System | Phoenix Gold iAMP Sound System | BR Coilovers | BMR Swaybars | 22" ForgeStar | Havoc Spoiler & Diffuser |
https://www.facebook.com/ExtremeAW
http://www.yelp.com/biz/extreme-autowerks-cerritos
ICEMAN 316 is offline   Reply With Quote
Old 10-29-2010, 10:15 PM   #20
LineofPerfection
LineofPerfection's Avatar
Drives: 2010 2SS Camaro "Big Blue"
I am having the same type of noise but mine is more like a backlash/ clunking issue in the rearend. I took it in to the service department and they REPLACED the rearend and gave it back to me. Unfortunately this didn't fix the problem so I took it back. This time they had a Chevy engineer come in and diagnose the problem. He acknowledged a problem that is a reoccurring problem in other 2010 Camaro's but said Chevrolet has no official fix for it yet and deemed it "servicable". My Chevy dealer gave me the number to the GM warranty department and they are now investigating the problem.
Big Blue
LineofPerfection is offline   Reply With Quote
Sealed Transmission?? Transmission fluid doesn't need change until 150k miles? DevilKnightFalcon Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 34 12-07-2009 06:32 PM
Transmission problems anyone??? 376camaro 5th Gen Camaro SS LS LT General Discussions 3 07-14-2009 08:02 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
LS3 Transmission Question Seawolf 5th Gen Camaro SS LS LT General Discussions 13 06-12-2009 02:16 PM
Which transmission will the L99 have? mega V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 19 01-08-2009 07:53 PM
