ADM PERFORMANCE
Old 02-06-2014, 04:41 PM   #1
Ravensrock12
Drives: 1991 camaro rs, 2010 2ss 6M
Exhaust vibrating
Hey guys, I have a 2010 2ss camaro m6 and I am hearing a very loud vibrating sound coming from in or around the exhaust. I have installed an x pipe, and an slp muffler delete kit and that's it. Any idea what this vibration could be? I hear it letting the clutch out in 1st and then 2500-3500 rpms in every gear. I think the exhaust could be lose or the heat shield is hitting it. Help!
Ravensrock12 is offline   Reply With Quote
Old 02-06-2014, 05:19 PM   #2
ilirg
ilirg's Avatar
Drives: 2011 Camaro 2ss
Similar thing happened to me after getting HF cats installed, guys on here said it was the tunnel brace, and that's exactly what it turned out to be. Could be a loose clamp or something too...
ilirg is offline   Reply With Quote
Old 02-06-2014, 05:23 PM   #3
Ravensrock12
If it ends up being the tunnel brace how would I fix it?
Old 02-06-2014, 05:31 PM   #4
ilirg
ilirg's Avatar
With mine they just loosened it, moved it back a little so it wasn't touching the exhaust then tightened it back up.
Old 02-06-2014, 05:33 PM   #5
Ravensrock12
Sweet. Thank you man! I will see what I can do this weekend. I can't stand that vibrating...
Old 02-06-2014, 05:48 PM   #6
scott's45
Scott's45
scott's45's Avatar
Drives: 2012 2SS 45th Anniversary
Or, you can take the bolts out of the tunnel brace and put in washers to get it away from the pipes. Hope you figure it out, good luck.
2012 2SS 45th Anniversary, Hurst short throw shifter, Stainless Power LT headers, high flow cats, SW Retro Chambered 3" cat back, CAI, Heritage grill, tinted windows, red/silver hash stripes, AAC LED sidemarkers, blacked out turn signals/tail lights, splash guards. 402RWHP
scott's45 is offline   Reply With Quote
Old 02-06-2014, 05:49 PM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Yep, most likely the tunnel brace. I would take it back to whoever installed your X pipe and have them fix it.
Best regards,
Tyler
888-308-6007
Old 02-08-2014, 11:39 PM   #8
Tpayline
Drives: 2010 2SS RS,
Had borla s type installed and had the same thing. I installed the hotchkis chasis brace and found the tunnel brace was rubbing on the exhaust. About a 16th away from it. Drove me nuts
Tpayline is offline   Reply With Quote
exhaust
