02-06-2014, 04:46 PM | #1 |
Banned
Drives: 2012 ss Join Date: Feb 2014
nobody?
camaro suspension
I was wondering if the suspension on the new camaro is the same uni body as the earlier models. I'm getting a little old to be laying on my back at the dealership lot to check it out and I might get shot if I tried it in a parking lot.**If you know the answer,*let's hear it. If you don't know, reply with the*. If you're not sure and don't want to mislead me, reply with the*. Thanks |
02-06-2014, 06:12 PM | #2 |
Drives: pleather and Chiclets Join Date: Mar 2012
101st????
The new camaro is different in every way from other generations.
02-06-2014, 06:14 PM | #3 | |
Drives: 2015 Z/28 #786 Join Date: Mar 2013
2015 Z/28 #786 - Black
2004 Silverado 3500 Dually - D'Max - Suncoast - Banks - Edge - Custom Tune by D'Max Tuner / Spitzer '32 Bantam Altered Drag Car - Blown Alcohol 380 CI Small Block Chevy |
02-06-2014, 06:53 PM | #4 |
Banned
02-06-2014, 07:01 PM | #5 |
Same same as far as I know. Basic chassis design and suspension remain unchanged. Some of the bushings have been improved and the rear sway bar was changed to move the mounts out towards the wheels (outboard of the shocks vs inboard) and the lower control arm was changed to accommodate the new sway bar mounting point. Others give input if you know of more.
02-06-2014, 07:45 PM | #6 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
If you're talking differences between the 2010 and the 2014, read below.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
02-07-2014, 09:36 AM | #7 |
Banned
thanks to all of you
Thread Tools | |
