BeckyD @ James Martin Chevy
Old 07-25-2009, 10:10 AM   #1
KK2010SS
Budafinger
KK2010SS's Avatar
Drives: 2010 Camaro SS
Muffler Delete with Dyno clips and pictures
I just had the muffler delete done this week and had them dyno it for before and after numbers. Here are the pictures of the install and the video clips of the dyno runs.
The numbers show a 6 HP and 9 TQ increase with the muffler delete. Stock numbers were 364 HP and 362 TQ @ 85 degrees and 67% humidity. After the delete I pulled 370 HP and 371 TQ @ 101 degrees 25% humidity. I am not sure how much the temperature and humidity affected my results. Does anyone with expertise know how to convert the numbers?
American Racing Technology here in Buda, TX did the muffler delete and dyno pulls. They are a GREAT shop to work with and will work with you on whatever you want done to your Camaro (or challenger, corvette, viper, etc..). If you are in the Austin/Buda area give them a call!
2010 2SS/RS, LS3, IBM, Silver Rally Stripes, Black Interior, 20" Polished, Doug Thorley Shorties, Flowmaster Catback, Hurst Shifter, K&N Filter, Vararam on order.
KK2010SS is offline   Reply With Quote
Old 07-25-2009, 11:43 AM   #2
linkwpc
The punching cat
linkwpc's Avatar
Drives: '10 Camaro SS Black W/Hugger&W/IOI
Very nice! Sounds much better!
My car build (COTW 7/23/12) - - - - - - > CLICK HERE! : http://www.camaro5.com/forums/showthread.php?t=80725
linkwpc is offline   Reply With Quote
Old 07-25-2009, 11:47 AM   #3
ljustin293
ljustin293's Avatar
Drives: 2010 VR CAMARO 2SS/RS
so now that it's done..do you like it?? or is it too loud?
Old 07-26-2009, 10:18 AM   #4
NAHURRY
Love's to Detail
NAHURRY's Avatar
Drives: 2010 SS,97silverado/08crewcab
...waiting on the reply.
NAHURRY is offline   Reply With Quote
Old 07-26-2009, 10:32 AM   #5
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Originally Posted by SGOS252382 View Post
Looks good.
How long was it between dyno runs? The reason I ask is the humidity changed drastically from 67% to 25 %. A long cool down (while they worked on your car) between runs could account for some the HP gain.
By looking at the angle of the sun in each dyno run, it seem like there was a lot of time between the two runs?
Best thing to do would be is to have the shop use the SAE numbers... that will take things like temp., barometric press. and humidity into consideration and apply the proper correction factor so you can better compare numbers...
One interesting thing I recently learned was that for some reason GM car dyno a bit better when the car is warmed up... I was skeptical when my dyno guy told me that... but sure enough, my first pull after a LONG cool down was the WORST! Best one pull was about the 3rd one with only a short cool down between pulls...
scrming is offline   Reply With Quote
Old 07-26-2009, 10:37 AM   #6
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I've seen that happen with a few cars. Usually a cool down will make more power. But sometimes, for whatever reason, the first pull can be a little weak.
Irpq11's dyno pulls are a good example. His car ran like crap on his first pull. I believe it made less than 300 rwhp on its first pull, if I'm remembering correctly. It seemed to recover on the second and third pull. But I'd have to ask Irpq11 how long his car sat before the first pull. It could have been hot from a drive to the dyno?
Old 07-26-2009, 11:04 AM   #7
KK2010SS
Budafinger
KK2010SS's Avatar
I would say its noticeable not too loud. The tone is great. Especially in the car. The first run was around 9 am and the last run was around 4 PM. they took their time and did it right since it was their first delete. I will try to get SAE numbers.
Old 07-26-2009, 11:20 AM   #8
SGOS252382
SGOS252382's Avatar
Where's "Buda" Texas?
I lived in San Antonio and Corpus Christi for many years before I made it to Florida.
Old 07-26-2009, 02:33 PM   #9
KK2010SS
Budafinger
KK2010SS's Avatar
About 45 miles north of San Antonio and 15 miles south of Austin. Right on I35.
Old 07-26-2009, 03:09 PM   #10
Legend
Hello!
Legend's Avatar
Drives: 2008 JSB Z06!
Sounds awesome...of course I might be a bit partial to the muffler delete
Good dyno numbers too...nice increase for not much money!
Legend is offline   Reply With Quote
