HeadlightArmor
Old 02-10-2014, 01:22 PM   #1
eblanchette
eblanchette's Avatar
Drives: 1LE
Catch can Installed, Oil still coming in the intake...
Hi,
I have an elite engineering can installed. Works great, picks up oil.
The problem I have is oil coming out of the other valve cover(driver side), and condensating into my CAI and intake manifold :(
I am aware of a certain oil cap with some valve inside, would that solve my problem? this oil ingestion needs to stop.
I was also thinking about adding another hose from the 2nd valve cover to the can, and splicing the can's intake hose(like a Y, so it would catch oil from both sides). I do not know if this would disrupt PCV flow though.
If a vented cap / splicing / or both is not the solution, what is?
Thanks!!
eblanchette is offline   Reply With Quote
Old 02-10-2014, 01:34 PM   #2
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Best thing I have found is get either a GM or RX oil separator that take the place of your oil fill cap and route to where currently is the driverside back valve hose goes to your cai. Cap the back driverside valve cover barb.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 02-10-2014, 01:45 PM   #3
eblanchette
Drives: 1LE
Do you have pictures or part numbers by any chance?
I see there's an oil separator for the 1LE V8, I don't know if it's the same..
thanks!
Old 02-10-2014, 02:01 PM   #4
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
thanks!
I was the first LLT to install the 1LE separator. Here is my DIY with plenty of info
http://www.camaro5.com/forums/showthread.php?t=312120
Proud owner of litho #179 Click Picture for Build Thread
Old 02-11-2014, 07:29 AM   #5
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
I had the same issue... fixed it with $20 and a stop at Lowes....
http://www.camaro5.com/forums/showthread.php?t=112152
scrming is offline   Reply With Quote
