Solo Performance
Old 07-25-2009, 07:02 PM   #1
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Sport vs Tapshift
Went to the track today... I made a couple of back to back passes, one in Sport and one shifting manual. First the slips:
Almost identical! (for some reason the track has trouble with my trap speed... LOL)
The Sport slip is on the left and the manual is on the right.
Here are the data logs. First the Sport mode:
Now the manual:
So the sport mode:
1->2 .325
2->3 .275
and manually shifting:
1->2 .350
2->3 .225
so there in this very unscientific test there is a very slight advantage to using the tap shifter....
scrming is offline   Reply With Quote
Old 07-26-2009, 02:26 AM   #2
Countach
Countach's Avatar
Drives: Future 2010 Camaro 2LT/RS
its great to see that the sport mode is so good, and that the tap shift is also very good
2LT/RS Auto with IO interior
1100 - 7/12/09 - NMGJKP
2000 - 7/20/09 - Order Accepted By GM
2500 - 7/22/09 - Order Preferenced
3000 - 7/23/09 - Order Accepted by Production Control TPW 8/17/09
3100 - 8/5/09 - Order Available to Sequence
3300 - 8/5/09 - Order Scheduled for Production
3400 - 8/12/09 - Order Broadcast
3800 - 8/19/09 - Order Produced 2G1FC1EV6A9137780
4200 - 8/20/09 - Order Shipped
5000 - 8/27/09 - Delivered to Dealer
6000 - 8/27/09 - Home
Countach is offline   Reply With Quote
Old 07-28-2009, 08:45 PM   #3
JesseJames
JesseJames's Avatar
Drives: 2010 2LT/RS
so glad all autos come with tap shift.
JesseJames is offline   Reply With Quote
Old 07-28-2009, 08:50 PM   #4
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
This looks promising..
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 07-28-2009, 08:58 PM   #5
scrming
scrming's Avatar
Yep... and look at the torque management system pulling ALL the timing on the shifts! Timing goes to -8 degrees! LOL
Old 08-10-2009, 03:42 PM   #6
NEO_ITguy
Drives: 2010 1SS / 2004 WRX
Was driving with my brother yesterday. I have the L99 A6. I noticed that in Sport mode that when you stop like at a stop sign or in the middle of the road, the car does not go into 1st gear, it will go into 2nd and that's where you take off from. You have to manually shift down into 1st while stopped.
Basically we were doing burnouts (yes I'm 34) and couldn't get the car to do them in drive or sport even with TC off. Hold down brake, hit gas, and let off brake while gas is floored. If you shift down into 1st you can leave a nice long dual rubber track into 3rd gear before the car catches. Lotta smoke, good stuff. Won't do jack in 2nd gear as I found out.
Anyone else notice Sport not starting from 1st gear and is there a reason besides preventing me from ruining my tires?
I was also researching online and noticed a lot of gear differences between the transmissions. I don't know what it means, I'm assuming the bigger the number the more torque?
Transmissions
Hydra-Matic 6l50 six-speed automatic (LS, LT) w/ TAPshift
Gear ratios (:1):
First: 4.07
Second: 2.37
Third: 1.55
Fourth: 1.16
Fifth: 0.85
Sixth: 0.67
Reverse: 3.06
Final drive ratio: 3.27
Hydra-Matic 6l80 six-speed automatic (SS) w/ TAPshift
Gear ratios (:1):
First: 4.03
Second: 2.36
Third: 1.53
Fourth: 1.15
Fifth: 0.85
Sixth: 0.67
Reverse: 3.06
Aisin Warner AY6 six-speed manual (LS, LT)
Gear ratios (:1):
First: 4.48
Second: 2.58
Third: 1.63
Fourth: 1.19
Fifth: 1.00
Sixth: 0.75
Reverse: 3.67
TR6060 six-speed manual (SS)
Gear ratios (:1):
First: 3.01
Second: 2.07
Third: 1.43
Fourth: 1.00
Fifth: 0.84
Sixth: 0.57
Reverse: 3.28
Final drive ratio: 3.45
NEO_ITguy is offline   Reply With Quote
Old 08-10-2009, 03:47 PM   #7
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
My tapshift is faster than your tapshift..Wanna race..?
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 08-10-2009, 06:26 PM   #8
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Transmissions
Gear ratios (:1):
First: 4.07
Second: 2.37
Third: 1.55
Fourth: 1.16
Fifth: 0.85
Sixth: 0.67
Reverse: 3.06
Gear ratios (:1):
First: 4.03
Second: 2.36
Third: 1.53
Fourth: 1.15
Fifth: 0.85
Sixth: 0.67
Reverse: 3.06
Gear ratios (:1):
First: 4.48
Second: 2.58
Third: 1.63
Fourth: 1.19
Fifth: 1.00
Sixth: 0.75
Reverse: 3.67
Gear ratios (:1):
First: 3.01
Second: 2.07
Third: 1.43
Fourth: 1.00
Fifth: 0.84
Sixth: 0.57
Reverse: 3.28
The only mode that doesn't automatically start out in 1st gear is M (manual - tap shift mode). In manual/tap shift mode, it only drops you down to 2nd gear when you come to a stop. As you mentioned, the only way to be in 1st gear is to tap down into it.
The other modes (D -regular drive), (M -regular sport mode) start you out in
1st gear everytime you come to a complete stop.
Old 08-10-2009, 06:32 PM   #9
jakemaxx
jakemaxx's Avatar
Drives: 1969 impala
you had a bad rt on the second slip.
ordering 1SS, IOM, White Stripes, Sunroof, BA Sound System, RS Package, LS3 6M
:5thgenvert:
jakemaxx is offline   Reply With Quote
Old 06-05-2010, 08:23 PM   #10
StlRomAniaN
StlRomAniaN's Avatar
Drives: IOM 2010 Camaro 2SS/RS
BUMP. TAPshift is pretty quick, even with the stock tune. I need the datalog my tuned tranny. I bet it's close to .1 sec. Can anyone outshift that? lol
StlRomAniaN is offline   Reply With Quote
Old 08-24-2010, 10:26 PM   #11
VictoryMuscleCars
VictoryMuscleCars's Avatar
Drives: 2012 Camaro SS RS Convert
Interesting info and results... nice post! Thanks
Tom P
VictoryMuscleCars is offline   Reply With Quote
Drive and handling of the Camaro not as good as the Mustang? :( goldwave84 Chevy Camaro vs... 46 05-05-2009 07:33 PM
2010 Corvette Grand Sport nester7929 General Automotive + Other Cars Discussion 17 04-24-2009 11:49 PM
Camaro Laps Nurburgring In 8:19! wohho 5th Gen Camaro SS LS LT General Discussions 75 03-21-2009 01:36 AM
The Proliferation of Super Sport The_Blur General Automotive + Other Cars Discussion 25 10-26-2008 09:08 PM
Everyone talks about horsepower, but what about handling? exilio 5th Gen Camaro SS LS LT General Discussions 30 10-15-2008 04:06 PM
