Rick@Livernois
Old 02-11-2014, 04:07 PM   #15
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Originally Posted by spd2612 View Post
It looks a though your top end was starving for oil Which means you probably have more damage. how long has your oil pressure been at 15 psi at idle ?
About 3 weeks before the noise started.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged LS3 (9.8:1 CR), Maggie TVS 2300 SC (11 psi), Custom Comp cam (223/244, .610/.596, 114 LSA), 90-lb. injectors, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Lashway Motorsports.
fldrummer is offline   Reply With Quote
Old 02-11-2014, 04:59 PM   #16
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Your cam looks just like mine did but I never had any noise. Now would be the perfect time to build it right if it's in your budget, better now then later since it's already being tore apart.
MODS:
Old 02-11-2014, 06:19 PM   #17
Slowhawk
Drives: 1999 Trans Am
I've dealt with this about 8 times last year. All different makes of Cams so that I took out of the picture. Before this I had 1 cam failure in 10 years like this.
We narrowed it down to oil quality. EPA had the oil company's cut the zinc content in a lot of oils including Mobile 1 5w-30. All our failures came from cars running lower zinc oil.Figure the extra load from the cam springs puts the stress level high enough to promote wear.
As for the fix.
Most of them just got a new cam,lifters,oil pump and clean out the oil pan, oil pump pickup. They have been fine since.
Problem I see with yours is that the car was driven a long time with the issue. Usually starts with 1 lifter lobe and works it's way down as metal gets caught in the others. It could very well have a lot more damage to the bearings now.
Safe thing would be to pull the motor and check all the bearings.Rings should be fine. While out flush out all the oil ports going through the motor.
Slowhawk is offline   Reply With Quote
Old 02-11-2014, 06:28 PM   #18
10aSSee D
10aSSee D's Avatar
As for the fix.
What oil do you use/recommend?
MODS:
Old 02-11-2014, 07:34 PM   #19
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
Mobil 1 5W30 full synthetic, and add a bottle of comp cams break in oil with every oil change.
http://www.summitracing.com/parts/cca-159/overview/
If it has high spring pressures, treat it like it is a flat tappet cam..... use assembly lube, break it in good, change oil often and give it zinc its whole life.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 02-11-2014, 08:17 PM   #20
Cat988h
Cat988h's Avatar
Drives: Rally yellow 2011 Camaro 1SSRS
I just installed the JRE 470 cam this Christmas, I'm running Amsoil Z-rod, it is a high zinc full synthetic oil I hope this stuff helps my cam along the way.
ATI Super Damper, Katech C5R Chain, Jannetty 470 Comp Cam, Comp Valve Springs, Mellings Oil Pump, Manley Push Rods, Comp Tringion Upgrade, Cold Air Inductions Intake, 1-7/8 American Racing Headers w Cats, MBRP 3 Inch Exhaust, RX Catch Can, Eaton Tru Trac, 3.91 OEM, DSS Drive And Half Shafts, LPW Diff Cover,3 Inch Noweeds, Amsoil Z-Rod, Tuned by Jannetty Racing
Cat988h is offline   Reply With Quote
Old 02-11-2014, 08:38 PM   #21
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Great stuff, we are an Amsoil Dealer if anyone needs any Z-Rod.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 02-11-2014, 09:32 PM   #22
fldrummer
"Black Ace"
fldrummer's Avatar
Thanks for all the input, guys. Since this is my daily driver (and probably will be for a while) and I plan on keeping it for a long time, I I think I'm just going to bite the bullet and do a rebuild now with forged internals, rather than gamble (it would have to get done some day, one way or another anyway, I figure). 'Will probably go with 9.5:1 compression and up the boost a bit. It's also a perfect time to upgrade the clutch since it has to come off anyway.
It's a good thing my car loan and Maggie are paid off and Uncle Sam came through quickly this year, or this would be a lot more painful. 'Still hope to make it to Camaro5 Fest, but won't be racing with the rest of my drivetrain still being stock. Hopefully it will last a bit longer (was just about to invest in a 9-inch and twin-disk clutch when this mess happened, but at least part of that will have to wait now).
Old 02-12-2014, 05:41 AM   #23
Slowhawk
We mostly run mobile 1 0-w40. It has a higher zinc count and we have not lost a motor on it yet. There are many other good oils too.
Old 02-12-2014, 07:34 AM   #24
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Mobile 1 5W30 is garbage. The have reduced the zinc too much to run in anything other than a stock engine. Some run it with no issues, then again all kinds of inferior parts are used also, and work out for some people. Put the odds on your side by using a good oil with more zinc in it. I use Driven (joe gibbs) LS30 but I'm sure the other higher zinc products are fine too.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 02-12-2014, 09:44 AM   #25
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
I have been running Rotella 5W40 for 2 years after the rebuild with a avg of 10 hard passes a month at the track and 5,000 highway mile. Changed the oil this passed week cut the oil filter open and its clean.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 02-12-2014, 09:57 AM   #26
dan0617
dan0617's Avatar
Just add the break in oil with every change then you don't have to worry about how much zinc is in the oil of your choice.
Old 02-12-2014, 04:02 PM   #27
White92RS
Drives: 1992 RS
Hope you get it resolved soon John!
If you've got the funds then get r done right...
White92RS is offline   Reply With Quote
Old 02-12-2014, 05:20 PM   #28
fldrummer
"Black Ace"
fldrummer's Avatar
Thanks. It will be just like buying the blower all over again, but should be able to pay it off by the year's end (knock on wood!). Should have her back on the street within the next month and making well north of 600 rwhp.
