SDTW Custom Wheels & Tires
Old 02-12-2014, 08:05 PM   #1
ksspeed
ksspeed's Avatar
Drives: 2013, Camaro 2LS (BRM)
Specifically 2LS people with NITROUS, Tuning???'s
I am setting up my ride with a 100 shot wet kit, and as many may know, the timing needs to be retarded 2 degrees per every 50 H.P. (or 4 deg. for 100 shot). What I need to know is what programming software, or even what means all of you are going about to achieve this. My goal is to run a "performance tune" while normal or any driving, and retard the timing while using nitrous. I have read that Trifecta can tune for using the cruse switch to activate a retard, I hope HP, or any others can as well. If this is the case, I would intercept the wiring to the cruse switch, and wire through my window switch to activate (only when its called for). Right now I am leaning towards an HP tune, however, in the end, I have to meet my goal regardless. Any thoughts or help is appreciated, I felt this was the best spot to ask, since in the tuner/programming section of the forum it is wide spread as appose to just FI V6. Thanks, KSspeed.
ksspeed is offline   Reply With Quote
Old 02-12-2014, 08:59 PM   #2
BlackoutLFX
BlackoutLFX's Avatar
Drives: 2012, Black 2LS
Interesting about the cruise feature. Same with their ghost cam tune. This could probably be set up in hp tuners, but I don't know because I haven't even thought about it. Most guys just run a different tune for nos.
Nytrex 100 hp nitrous triple threat system, NytrexAccu-pressure bottle heater, HP tuners, K&N Typhoon CAI, MACE 6mm MI, Solo Performance high flow cats, Flowmaster American Thunder cat back exhaust system, BMR subframe connectors, BMR tunnel brace, BMR lowering springs, BMR Xtreme Anti-roll bar rear, Hotchkins Strut brace, SS/LS3 3.45 LSD, Axles, and hubs, Elite Engineering catch can, B&M Supercooler transmission cooler, FTI 3200 Stall.
BlackoutLFX is offline   Reply With Quote
