JDP Motorsports
Old 02-13-2014, 07:50 PM   #1
aggieguy13
aggieguy13's Avatar
Drives: 2013 SS/RS VR 1LE
Possible development over site PLEASE READ
So I was installing my heritage grille and noticed rub marks on the collar on the front springs. Front tire rub. Not constant. But when they are at compression. Please check your cars and see if it is on yours as well
2013 SS/RS 1LE VR-Backup System, SOLO Perforsance HF Cats, Muffler Delete, BBK Off-road X-pipe
2002 35th Aniversary SLP SS-Sold
aggieguy13 is offline   Reply With Quote
Old 02-13-2014, 08:29 PM   #2
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Very interesting,will be in there tomorrow,thanks for the info.
cornerspeed92 is offline   Reply With Quote
Old 02-13-2014, 08:48 PM   #3
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
What kind of camber are you running?
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 02-13-2014, 09:14 PM   #4
aggieguy13
aggieguy13's Avatar
Stock setup
Old 02-13-2014, 09:50 PM   #5
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
When the spring compresses only the section from where your finger is upward changes. From the spring down to the hub assy it is solid and the distance between the tire and that area (lower spring perch) should not change unless something is very wrong. (bad wheel bearing, loose ball joints, loose bolts between knuckle assy and lower strut, loose wheel...etc) Basically there is no way that should make contact unless something is broken.
That looks like wear from debris being thrown up from the tire to the lower perch effectively "sand blasting" that area.....Do you drive on dirt or gravel roads with the car?
Old 02-14-2014, 08:34 AM   #6
Dropspeed
Dropspeed's Avatar
Labelled a picture for you....
-Matt
Old 02-14-2014, 08:46 AM   #7
MLL67RSSS
Drives: car
Disk brake first gens are notorious for tire rub on the sub-frame at full steering lock. Usually anywhere you have tire rub you'll see bare, shiny metal with all paint/rust rubbed off. You're OK!
EDIT: Looks like third gen 'vettes do it also.
MLL67RSSS is offline   Reply With Quote
Old 02-14-2014, 11:16 AM   #8
hcsi99
Cadillac Service Manager
hcsi99's Avatar
Drives: 2014 Camaro 1SS, 1LE, NPP, RECAROS
I think that might be from the rocks that stick to the tires then come off as you speed up. It doesn't look like a rub to me. Plus I would think you would hear that or feel it in the steering if it was rubbing.
hcsi99 is offline   Reply With Quote
Old 02-14-2014, 11:31 AM   #9
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
Yeah, I don't see anything rubbing. I see some paint missing from debris being thrown off of the tires. No worries.
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 02-14-2014, 07:13 PM   #10
HuJass
Drives: GM
I see chipped up metal that began to corrode.
2015 Camaro 1LE
2009 Challenger R/T
2007 Solstice GXP
2004 Colorado ZQ8
2002 Trans Am WS6 Collector Edition
1999 Blazer
1994 Grand Prix SE B4U
HuJass is offline   Reply With Quote
Old 02-14-2014, 07:28 PM   #11
whan
Drives: 2014 1SS/1LE
Luse4: It's probably different between normal SS and 1LEs due to the wider tire width and different suspension setup
whan is offline   Reply With Quote
Old 02-14-2014, 07:39 PM   #12
Realist
Realist's Avatar
Drives: 2013 Black SS/RS 1LE
Ditto of my thoughts.
Realist is offline   Reply With Quote
Old 02-14-2014, 08:49 PM   #13
LuSe4
LuSe4's Avatar
I am not sure what you are trying to tell me, but there is no rubbing there.
Old 02-14-2014, 10:16 PM   #14
GMUSA#1
GMUSA#1's Avatar
Drives: 2014 Camaro 2SS/RS 1LE
You got to be kidding me!..Thought I had left that problem when I traded my'06 GTO in on the Camaro..... as with driveshaft problems as well. Hope this isn't the case. It was the collapsing of the upper strut mount/bearings that was causing this if I remember correctly.
Brent
'14 Camaro 2SS/RS 1LE
'96 Impala SS
'69 Camaro Convertible
GMUSA#1 is offline   Reply With Quote
