GM Parts House
Old 02-15-2014, 07:33 AM   #1
redleader
redleader
Drives: 2010
Centre Gauge Console FAILED
So, I get in my Camaro 2010 1LT this morning and (after two years being installed as an Xtra) my 4 Cluster Gauges on my Centre Console are not working :-(
The TC Button and Cigarette Lighter are fine and working.
Where should I start to diagnose the problem please?
Thx,
redleader is offline   Reply With Quote
Old 02-15-2014, 07:35 AM   #2
Smokey jr.
Drives: 2011 inferno orange camaro
give gen5diy a call
Smokey jr. is offline   Reply With Quote
Old 02-15-2014, 07:40 AM   #3
redleader
redleader
Drives: 2010
Cheers 'Smokey Jr.' ... but I'm in the UK :-)
Old 02-15-2014, 08:07 AM   #4
rocknroll_jeph
rocknroll_jeph's Avatar
Drives: 11 Camaro V6 RS, 03 BMW Z4
Did you check the fuses? According to the manual for my 2011 the fuse for the cluster should be in the fuse box on the driver's side of the instrument panel, fuse F4. Still, if yours is aftermarket may be different. Good luck!
rocknroll_jeph is offline   Reply With Quote
Old 02-15-2014, 08:16 AM   #5
redleader
redleader
Drives: 2010
Thank you rocknroll_jeph,
I have checked and swapped the 10A F4 fuse and ... no change :-(
Loose connection on the console next?
Old 02-15-2014, 08:21 AM   #6
rocknroll_jeph
That's what I would do. Work backwards... I always am looking for excuses to take my toys apart anyway. Good luck!
Old 02-15-2014, 08:58 AM   #7
pocketcthulhu
pocketcthulhu's Avatar
Drives: 2014 2ss/RS 5th gen Camaro #2
you could try hooking a code reader up and see if it's throwing an error message, If it is that "Could" give you a place to start.
pocketcthulhu is offline   Reply With Quote
Old 02-15-2014, 09:51 AM   #8
redleader
redleader
Drives: 2010
Thank you all, FIXED now! :-)
I took it all apart...
http://www.camaro5.com/forums/showthread.php?t=151439
... and plugged it back together ... all Alive and well again.
Cold Weather?, Loose Connection? Knocked Loose a bit?
(I think it was the plug actually in the back of the internal 4 Gauges housing area itself FYI).
Thanks for being there :-) √√
