Old 02-18-2014, 10:41 PM   #15
Mikebrinda
Mikebrinda's Avatar
Drives: Ferrari F430 Spider F1 Azzurro Arge
Originally Posted by brt3 View Post
One interesting thing about this press release is that it indicates, to me at least, that magazine tests should begin shortly. Can't wait to start seeing actual tests of this beast in the buff mags.
Agreed, plus the final N-ring number.
Mikebrinda is offline   Reply With Quote
Old 02-18-2014, 11:19 PM   #16
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Also, it sounds like the differential they described is like the Eaton Truetrac, with gears instead of clutch disks. Anyone have insight on how it might compare to the Truetrac?
AG1LE is offline   Reply With Quote
Old 02-18-2014, 11:30 PM   #17
Camaro Dude
and Sledge
Camaro Dude's Avatar
Drives: '13 1LE, 2SS, NPP
Originally Posted by ThaCamaroKid View Post
This made me laugh, a stock SS is supposed to stop around 120 ft from 60, I would hope to God the Z/28 stops under 120 ft. It better stop under 110, Hoping for 105 ballpark. Honestly under 100 ft would not surprise me, I know that is a lot to ask but this has bigger and allegedly better brakes than the GT-R. Not to mention the GT-R brakes from 60 right under 100 ft, + the GT-R and Z/28 weigh roughly the same, + the Z/28 will have bigger stickier tires.
Originally Posted by Juiced1 View Post
With those brakes it's gotta be damn close to 100 ft.
Didn't Motortrend stop a 1LE from 60-0 in 101ft?
Speaking of which, I'm surprised that the Z28 is only 55lb lighter then a SS, even taking into consideration its increased mass on certain components for structural rigidity, etc.
Camaro Dude is offline   Reply With Quote
Old 02-19-2014, 01:10 AM   #18
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
Originally Posted by JMWNERW View Post
Why would they use smaller-diameter sways than the 1LE? What is the performance advantage?
I remember JusticePete saying something along the lines of with an optimized suspension set up, the sway bars don't need to be as big.
Bhobbs is offline   Reply With Quote
Old 02-19-2014, 01:28 AM   #19
brt3
Runs with scissors...
brt3's Avatar
Drives: '14 Z/28s SIM/SW
I wonder about that. If and when they release the final Ring time for a dry track, I think they'll want video. So, unless they've been holding back on us and sandbagging (by saying that stitching all their good sectors together should give a 7:31.xx), I have to think they'll return to the Ring in May to run some final, good weather hot laps for posterity...
brt3 is offline   Reply With Quote
Old 02-19-2014, 06:32 AM   #20
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
Yes Motortrend did get 60-0 in 101ft with a 1LE.
Im looking forward to Motortrend running the Z28 on VIR, we know where the 1LE and ZL1 stands.
CamaroTom is offline   Reply With Quote
Old 02-19-2014, 06:36 AM   #21
camaro500
camaro500's Avatar
Drives: 2017 Jaguar F Type R
GREAT CAR! Love it in red!
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller
camaro500 is offline   Reply With Quote
Old 02-19-2014, 09:47 AM   #22
AZCamaroFan
9 YEARS on Camaro5/6
AZCamaroFan's Avatar
Drives: sometimes
so it weighs 3,820.
I thought they said last year it would be a hundred pounds less than the SS.
Old 02-19-2014, 10:30 AM   #23
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
Originally Posted by AZCamaroFan View Post
so it weighs 3,820.
Hundreds less than the ZL1.
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 02-19-2014, 10:32 AM   #24
AZCamaroFan
Drives: sometimes
no I went back and looked. they said 300 less than the ZL1 and 100 less than the SS
Old 02-19-2014, 11:02 AM   #25
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
On a race car you tune the suspension with the spring rates and the sway bars are used to fine tune. At some shorter tighter tracks (Waterford Hills in MI) some races discount the sway bars. For the street the OEM have to compromise the best of both worlds which usually means a softer springs with a larger bar (1LE)
The Z/28 is a "no compromise" track car that will be driving on the street.....so stiffer spings combined with the DSSV dampers will be doing the job and smaller sway bars can be used.
Eaton Trutrac and JTekts Torsen diff are of the same design......Both should work the same.
so it weighs 3,820.
That is a general marketing statement......It depends on the trim and options.
If it does weigh in at 3820 that is withing 3lbs of my 1LE with a 1/4 tank of fuel (1ss/non RS, no sunroof)
This made me laugh, a stock SS is supposed to stop around 120 ft from 60, I would hope to God the Z/28 stops under 120 ft. It better stop under 110, .
Having driven a couple cars with Carbon Ceramic brakes on track (ZR1 / Ferrari) The inital stopping distance when cold is not the greatest result of feel from the them (relatively speaking as it best most) What is impressive is how they get better (short, better bite) when hot and then continue to be consistent lap after lap.
-Matt
Old 02-19-2014, 12:13 PM   #26
Mikebrinda
Mikebrinda's Avatar
-Matt
To the last point, anyone not familiar with cold ceramics should be advised not to push the car with cold brakes. You will not enjoy that braking bad moment.
Old 02-19-2014, 01:42 PM   #27
1985airborne
One Slow Automatic
1985airborne's Avatar
Drives: 2017 GS 2010 CAMARO SS
I have got to get my hands on that wickerbill!
650HP 725TQ 2010 CAMARO SS STOCK 2017 GRAND SPORT
1985airborne is offline   Reply With Quote
Old 02-19-2014, 09:21 PM   #28
ThaCamaroKid
ThaCamaroKid's Avatar
Drives: 2010 Camaro 2SS/RS L99
This link claims as much, http://www.motortrend.com/roadtests/...le_first_test/
HOWEVER, I find it hard to believe a 1LE brakes from 60 in 20 ft less than its SS brother. + based on that math the Z/28 should brake under 95 ft, which I'm sorry isn't going to happen. Motortrends fastest braking car they have tested was the 2011 Corvette Z06 Carbon edition which stopped in 93 ft. That car had the same, or close to size ceramic brakes as the Z/28 will have and it weighed a good 600 lbs less. So I do not see a sub 95 ft brake from 60 mph happening.
375RWHP/399RWTQ
ThaCamaroKid is offline   Reply With Quote
