Old 07-28-2009, 06:59 AM   #15
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
Originally Posted by Dynabyte View Post
Nope, there's no wobble lock to lock. The wheel is perpendicular to the column. The column itself is shifted a little to the left it appears. Up/down & in/out telescoping work fine. There's no left/right movement either with the wheel locked or when adjusting. It's as though the other end of the steering column is hooked up in the wrong spot (too far to the right). Anyone else notice it?
well thats good
maybe they can adjust it under the dash where it bolts up
you gonna make me go and check my other cars today
Gentry78 is offline   Reply With Quote
Old 07-28-2009, 11:38 PM   #16
gmag21
gmag21
gmag21's Avatar
Drives: 2010 Camaro 1SS/RS
Send a message via AIM to gmag21 Send a message via Skype™ to gmag21
Yikes
L99 | Billyboat Exhaust, American Racing Headers, Pfadt Springs and Sways, Tune | 350 whp / 371 tq
gmag21 is offline   Reply With Quote
Old 07-29-2009, 12:01 AM   #17
69 Hugger
69 Hugger's Avatar
Drives: 69 Convertible Camaro
How about the gaps between the back of the wheel and back part of the colume where the blinkers mount, do those gaps show the 1/2 inch or are the consistent Lside to Rside. good luck
69 Hugger is offline   Reply With Quote
Old 07-29-2009, 01:05 AM   #18
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Must be from the last transformation.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 07-29-2009, 01:11 AM   #19
Dynabyte
Dynabyte's Avatar
Drives: 2014 2SS/RS/NPP Red Hot
The distance between the back of the wheel and the front housing of the column (where the turn signal is mounted) is identical around the circumference, less than 1/2 " though. I did notice that the distance between the entire column and the dash is smaller on the left than the right - probably to be expected since the bottom part of the column (in the engine bay or wherever it mounts) is too far to the right. The steering wheel and column are fine as a unit - the whole assembly is off-kilter compared to the rest of the car.
Dynabyte is offline   Reply With Quote
Old 07-31-2009, 03:57 PM   #20
chevyridinghigh
The Bowtie Is Back
chevyridinghigh's Avatar
Drives: 2010 Silver Camaro SS/RS -Blk Int.
I think you should alter your test. Instead of trying to align the string from the same spot on the windows. Line it up so it's flush with the wheel (you'll need 2 people one on each side), then tape it down. the measure the distance to the end of the window.
2SS RS SIM M6 with Polish Silver wheels
chevyridinghigh is offline   Reply With Quote
Old 07-31-2009, 07:12 PM   #21
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
just go very slowly to make sure you dont press the string on the wheel and "bend" it slightly askew
I piss excellence
and fart awesomeness
Old 07-31-2009, 10:37 PM   #22
Dynabyte
Dynabyte's Avatar
Done - 5-15/16" on the drivers side, 8-3/4" on the passenger side. I can attach pics but trust me, the line is straight, and flush against the wheel. So one other forum member states theirs is the same. Anyone else? Or can anyone confirm that their wheel is spot-on? I would really like to know if it's something to be fixed or just the way it is - thanks much everyone
Old 08-01-2009, 03:08 AM   #23
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
Thanks for the confirmation I had a feeling that it might be just the way it is.
Mine has the same issue. I will take pictures in the morning.
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 11-09-2009, 12:55 AM   #24
Supermans
Supermans's Avatar
I knew I had posted in this thread awhile back but let this problem go for too long. So apparently a simple wheel alignment will fix the issue under warranty, and the car will handle better..I anyone has the exact dealer write-up information for this issue, that would be a great help as well.
http://www.camaro5.com/forums/newrep...eply&p=1147659
Old 11-09-2009, 01:49 AM   #25
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
You get it fixed?
Old 11-09-2009, 12:06 PM   #26
Dynabyte
Dynabyte's Avatar
You get it fixed?
Nope - when I went to the dealer, they also stated that it was just the way it is. I noticed another thread posted about this now - I'd be really happy to hear if there is a fix for it. Doesn't seem like a standard tire alignment would do the trick tho - those adjustments are at the wheels and shoudn't touch the steering column mount points. But who knows - I will inquire again on my next trip to the dealer.
Old 11-09-2009, 05:57 PM   #27
Supermans
Supermans's Avatar
Yeah, two dealers both said it was normal as well.. However one person in the other thread said a simple wheel alignment is the fix. I'm starting to think it's a little more difficult a fix than that.. I wish someone up above from GM can chime in on this issue.. God knows this is the correct forum and they do read these problem threads.
Old 11-09-2009, 06:03 PM   #28
Double Down 11
Drives: 2010 Camaro 2SS RJT A6
I mentioned my wheel was off alignment when I brought it in for the recalls. I sat in another SS they had on the lot and it was also off. The right side is closer than the left. Their response was "that's just they way it is" and nothing they can do about it. Something about how the steering column is welded and there is no adjustments.
Double Down 11 is offline   Reply With Quote
Steering wheel controls Timberline Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 06-05-2009 10:39 AM
Another new product from DSVcustoms... 2 Tone steering wheel Indpowr Cosmetics and Lighting Modification Discussions 11 05-25-2009 01:08 PM
Price release on DSVcustoms 2 tone steering wheel Indpowr Interior Parts & Accessories 0 05-24-2009 09:27 AM
Steering wheel and shifter material? Blacked Out 5th Gen Camaro SS LS LT General Discussions 13 05-20-2009 03:34 PM
Steering Wheel Radio Controls Bart 5th Gen Camaro SS LS LT General Discussions 19 02-28-2007 01:46 PM
