Flowmaster Exhaust
Old 07-26-2009, 07:15 PM   #1
OrangeChevyII
Drives: 2010 RS/SS2
12.66@111 Tuned and catback
Hey guys,I've been browsing this website since I ordered my RS/SS2 car back in May. It has 710 miles in the video, I've had the car for less then 2 weeks. First and only pass on the bottle was a 11.80@121 mph with a 2.06 short time. Best 60ft last week was a 1.89, closest I got this week was a 1.99. Yes those are 16 inch wheels in the front.
OrangeChevyII is offline   Reply With Quote
Old 07-26-2009, 07:29 PM   #2
MONEY
Black 2ss/rs Mid-August
MONEY's Avatar
Drives: 1999 Silverado, 1978 Corvette
I like that, "Small Dry Shot"! How small was it? 100, 150? Good run. What catback are you running?
BLACK 2SS/RS INFERNO ORANGE INTERIOR (Ordered 6-10) ....... Pratt & Whitney J58 Jet Engine On Order, (Swap Details Soon!)
MONEY is offline   Reply With Quote
Old 07-26-2009, 09:13 PM   #3
OrangeChevyII
Drives: 2010 RS/SS2
Around 120, ran through the stock air filter. It's actually just a Magnaflow Muffler cut in where the stock H-pipe was. I deleted the rear mufflers. Still has the 2 resonators in place.
Old 07-27-2009, 11:18 AM   #4
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I see your doing a burnout in the water box. You're running the stock rear tires? People always say stay out of the water box with the stock tires.
Also, more info on those front wheels (drag wheels?) They look skinny.
Old 07-27-2009, 11:44 AM   #5
8ty8 ls1
Resident Engineer
8ty8 ls1's Avatar
Drives: 2010 Camaro SS, 1988 GMC S-15
yeah how'd you get a 16" on the front over those huge calipers? that thing runs good man!! nice runs!
12.68 @ 109: LSR cai, Borla S-type axle-back, Tunes
8ty8 ls1 is offline   Reply With Quote
Old 07-27-2009, 12:16 PM   #6
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Dude....
I'd kick the track guys in the NUTZ if they sprayed MY TIRES down like that just before a run. WTF are they thinking?!?!?
Stay out of the water unless you are running slicks. When you spin your tires in the water, you pick up water in the grooves of the tread and spin them easily. Even after your take off, you won't be able to catch as much traction. Water will still be in the wheel well...
On top of that, you see the guy walk out there and look at the track?...he's checking the track for water left behind from a running AC, oil, and water from your tires. Water also gets thrown up into the wheel well when doing a burn out and it'll drip down onto the track.
I'm sure you probably already know this (and I'm not at all trying to sound like the 'know it all', but I'm just trying to offer up some advice from personal experience.
Old 07-27-2009, 07:46 PM   #7
OrangeChevyII
Drives: 2010 RS/SS2
20" tires are hard as hell to smoke with out having water on them. The car wheel hops bad if you do a dry burn out. The water box area was pretty sloppy because they were having a "4.70 oulaw class" race and we ran right behind them. The guy was spraying water down for the next car behind me.
Brace yourself for this, that is a 16" ccw wheel on the front of the car. I took the Brembo brakes off the front and installed 2002 F-body brakes. This is only for the track. They do work just fine, I just saved 110 pounds off the front of the car. Some people dont understand, some do.
Old 07-27-2009, 07:48 PM   #8
OrangeChevyII
Drives: 2010 RS/SS2
Thank you for the compliments, Next video's, same set up, 12.40's on motor and 11.40's on spray. Same tires.
Old 07-27-2009, 10:59 PM   #9
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
Ballsy...you must be committed to making this thing into a straight 1/4 miler huh?
I understand where your coming from...good luck on your efforts!
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 07-27-2009, 11:11 PM   #10
rodimus prime
Drives: Cargo van.
Holy shit 110lbs! Didnt by chance weigh the stock rotors did you?
rodimus prime is offline   Reply With Quote
Old 07-27-2009, 11:15 PM   #11
ToddSS
ZZ Motorsports Sales Rep
ToddSS's Avatar
Drives: 2010 SIM 1SS
I for one support your efforts. Good work one the weight reduction.
ToddSS is offline   Reply With Quote
Old 07-28-2009, 09:50 AM   #12
OrangeChevyII
Drives: 2010 RS/SS2
The stock rotors weighed in at 25#s, f-body rotors weighed in at 15#s. If you multiply it all by 3 since its rotating weight, I took 330#s of rotating weight off.
Old 07-28-2009, 10:01 AM   #13
OrangeChevyII
Drives: 2010 RS/SS2
I just ordered a set of Kooks longtubes for the car on Monday, be 10 days before I can get them. I'd like to make a 10 second pass with the stock manifolds. Just to see if I can do it.......I bought a set of 18" Radials so I think it's possible. I know on motor, I never go to 4th gear. Just by the tires I should be able to drop this thing down in the 12.20 range IF I can get it in to 4th gear. I think 10's are feasable with radials. All I can do is try!
Untouched motor with a stock airbox and paper filter.
Anybody run a 10 second 1/4 mile yet?
Old 07-28-2009, 11:52 AM   #14
JTinFL
JTinFL's Avatar
Drives: Fast ones
Very cool.
JTinFL is offline   Reply With Quote
