Old 02-18-2014, 09:56 PM   #1
717Stunna
717Stunna's Avatar
Drives: 2010 Slp Camaro ZL327
Time to pump up the 6 Shooter
Got my isolator ported throttle body and ported intake manifold today can't wait to get installed hoping to see some gains I have all bolt ons now besides cams
717Stunna is offline   Reply With Quote
Old 02-19-2014, 12:29 PM   #2
KMPrenger
KMPrenger's Avatar
Good stuff!
I'd recommend getting a 2nd GM manifold gasket while you are at it, and purchasing slightly longer (10mm longer) intake manifold bolts.
Old 02-19-2014, 01:03 PM   #3
717Stunna
717Stunna's Avatar
Stock bolts won't work
Old 02-19-2014, 04:16 PM   #4
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Actually you can use the stock IM main mounting bolts, but you will be reducing the thread depth by half (from 1" to about 1/2").
Be sure and use a torque wrench (18 ft/lbs) and you should be fine if you're in a hurry to enjoy your new HP!
If you're more patient, a set of 140mm bolts will restore the stock depth. They can be found here- http://www.boltdepot.com/Metric_hex_...?Selected=6238
Either way, have fun
Old 02-19-2014, 05:26 PM   #5
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
let the fun begin !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 02-19-2014, 06:25 PM   #6
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Isn't the SLP Camaro already modded?? You don't need longer bolts for the 3/8 iceolator.
Eddiefuzz is offline   Reply With Quote
Old 02-19-2014, 06:44 PM   #7
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
When torquing the bolts be sure to do it when everything is cold. you do not want to strip ones of those holes. also, be sure to come back a week later and check the bolts, again when everything is cold.
Yes, you can use the stock bolts with the 3/8 spacer.
Yes, using a second gasket avoids having to use any silicone sealant.
Old 02-19-2014, 06:51 PM   #8
717Stunna
717Stunna's Avatar
Yes the the Camaro came modded with a slp blackwing intake and slp exhaust and a diablosport programmer but the exhaust was to raspy and the intake looked stock so I took all of it off and modded it how I want yes its not a ZL327 anymore but it still has the badges to full people hah
Old 02-19-2014, 10:40 PM   #9
717Stunna
717Stunna's Avatar
Im going to wait to install it i just ordered mace cams so I'm getting done all at once
Old 02-19-2014, 10:45 PM   #10
KMPrenger
KMPrenger's Avatar
yes you can use the stock bolts with the 3/8" ice-olator....In fact I used them myself when I was just running one gasket and then gasket maker on the other side.
But the recommendation from RX at the time was when using two gaskets, that getting longer bolts for the added depth was a good thing...so that's what I ended up doing. Like mentioned above...don't tighten over 18 ft lbs...especially when your only running half the depth on the bolts.
I'm looking forward to seeing your build! Keep us informed.
Old 02-20-2014, 03:04 PM   #11
Ventmaster
Ventmaster's Avatar
I would never contradict you KP- you are much too well informed! And I also recommend the use of longer mounting bolts when using 2 IM gaskets.
I just wanted to avoid the misinformation that stock bolts will not work in that application.
Stunna good luck with the Mace cams- keep us posted!
Old 02-20-2014, 07:44 PM   #12
rtcat600man
I ended up with the longer bolts when I ordered the plenum spacer. It was at this time adding the plenum spacer that I added the second gasket. Sorry I did not use the stock bolts when I added the 2nd gasket.
