Old 02-20-2014, 03:21 PM   #29
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
Originally Posted by Gillis View Post
My SS takes a little over 8 quarts to be right at full.
Yes. Point is, you don't want it full if you run your car hard. If not, it won't make any difference.
Bye bye, Bumblebee!
Old 02-20-2014, 03:23 PM   #30
Gillis
Drives: Car
Originally Posted by strych9 View Post
You should check your oil every time you put gas in it, period. Plus, the OEM-specified 8qts is too much oil for the V8 engines. 7qts (right on the add line) is where you want to keep it if you run your car hard. Why? Oil aerates at high RPM with 8qts in the crank case.
Can you explain more about this please?
Gillis is offline   Reply With Quote
Old 02-20-2014, 03:26 PM   #31
ChocoTaco369
145lb Powerlifter
ChocoTaco369's Avatar
Drives: 2013 Camaro 2SS RS LS3
Originally Posted by nyrfan View Post
That is time to change.
If you have a GM Certified car, you get free oil changes for a year. You will not receive your free oil change until the OLM reaches <22%. 35% is still very fresh.
I wouldn't worry about it until you're <20%. My oil just hit 19% today and I just scheduled a change at the dealer for Saturday morning as of 25 minutes ago. Just make sure to monitor the LEVEL of the oil. That's what will hurt your motor. Old, dirty oil at the proper level isn't nearly as big a problem as fresh oil that's low!!!
ChocoTaco369 is offline   Reply With Quote
Old 02-20-2014, 03:36 PM   #32
strych9
Gone Euro!
strych9's Avatar
Sure! If the oil level is high enough to allow the crankshaft counter-weights to "beat" into the oil in your pan, it foams up a bit from air being "whipped" into the oil.
Valve lifters are small hydraulic pumps, and depend on air-free oil to operate properly. By introducing aerated oil to them, it can affect performance and create undue lifter tick. Air compresses; oil does not. That small bit of compression caused by aerated oil can cost a few thousandths of an inch of valve lift, thus affecting overall performance of the engine.
In extremely aerated oil (filling way beyond the full mark), you can end up with cylinder scoring and bearing damage. Rare, but it could happen.
Bye bye, Bumblebee!
Old 02-20-2014, 03:38 PM   #33
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
My point was the olm is showing the time to change, not the level. I was not debating when to change.
Sent from my AGM, 2SS/RS
FSP tuned: 377/389
Old 02-20-2014, 03:40 PM   #34
nelsont
Drives: 2011 2LT RS Convertible InfernoOrng
Really, Really!
nelsont is offline   Reply With Quote
Old 02-20-2014, 04:10 PM   #35
trashmanssd
trashmanssd's Avatar
Drives: Black 14 2SS/1LE/RS 14 Tundra
Originally Posted by Ides of March View Post
I have a question about the oil percentage. I pretty much check the dipsticks for how low the oil is and when to fill it up with a bottle or two. My Oil is 35% which I know is low and my fault for letting it go that low. But I have to ask, Is that for the oil change or just when to give it a fill. I have about 2500 miles on my Camaro at the moment. I was just going to put some oil in myself, don't think it's oil change time yet. Sorry if this is in the wrong section.
Don't do what one of the guys that works for me did. Tried changing his oil for the first time for him self. pulled off the oil filter. put 5 quarts back in checked the trany stick said wow perfect right on the line. started it up made it about 1/8 mile had oil bubbling out every where smoke from it burning off allover the engine. pulls back in smoke pouring out from under hood 3 of us laughing at him start asking questions on steps he took. Figured out he never took out the drain plug to drain it i looked in the oil pan was maybe a quart in it car had 9 quarts in it when it only took 5. Luckily he didn't blow a head gasket or do any damage other then his manhood.
trashmanssd is offline   Reply With Quote
Old 02-20-2014, 04:14 PM   #36
trashmanssd
a little knowledge can be helpful or very dangerous. If you are unsure there are no stupid questions. Stupid is thinking i should ask someone because i'm unsure and then ignoring that felling and doing it anyways and damaging something or someone.
Old 02-20-2014, 04:20 PM   #37
Flashpoint135
Rev Head
Flashpoint135's Avatar
Drives: 2016 SS
I agree with most of what the rest of you have said, but just wanted to point out OP has a V6, so the 7.5 and 8 quart discussions do not apply to him. Capacity on the V6 is only 6 quarts and they do use oil. It still shouldn't be overfilled, but it is a different engine design and we do often have to add oil between changes.
Trashmanssd - great story, funny for us, and another good point that if you don't know what you are doing don't work on your car! - at least not without asking someone who does know.
Flashpoint135 is offline   Reply With Quote
Old 02-20-2014, 04:20 PM   #38
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
As men, we would rather be a love pinata in a Mexican prison than read directions, or in this case an owner's manual. But all that info is in there.
Smoked tail lights/ZL1-1LE 3rd brake
Rotofab cai
Old 02-20-2014, 04:22 PM   #39
Flashpoint135
Rev Head
Drives: 2016 SS
I'm not going to agree with you this time... what you do on your vacation is your own business, but I'd rather read the manual.
Last edited by Flashpoint135; 02-20-2014 at 04:34 PM. Reason: edited and clarified for mclark
Old 02-20-2014, 04:24 PM   #40
ZED SLED
ZED SLED's Avatar
lol, the Mexican prison part I'm guessing?
Rotofab cai
Old 02-20-2014, 05:12 PM   #41
pyroguy
pyroguy's Avatar
Drives: ABM #825
OP, maybe I'm the only one who read it this way, but did I read your post correct that you only add but not change your oil? If so, remind me to never buy a car from you. If not I apologize for the mis-read.
To answer your question, personally for a brand new car I recommend changing the oil absolutely no later than 5,000 miles into a new engine. Personally I would rather change after the 500 mile break in period so you know if anything isn't going right before you get too far into a new engine. However, 3-5k is a good rule of thumb.
'10 Camaro 2SS/RS | Aqua Blue #825 of 3,903 | Silver Stripes
Follow SCPA5 on Instagram! Follow SCPA5 on Facebook!
Check out my build thread
Old 02-20-2014, 05:15 PM   #42
Mint
Mint's Avatar
Drives: 2013 Camaro SS
It's the oil life, tells you when to change it. What do you mean when you say you put more oil in when it went lower percent?
Mint is offline   Reply With Quote
