HURST
Old 07-27-2009, 02:45 AM   #1
Paperer
Ragin' Cajun
Paperer's Avatar
Drives: '02 Camaro SS - '10 CGM 2SS/RS
Horrible Brake Squeal
Okay, going down the highway, and all of the sudden, the left brake begins to make an awful squeal as if it's locking up, I'm not far from home, so I turn around. It's just basically screaming the highest pitch you could think of all the way back at any speed.
I park and look at it, then I decide to head to the dealership. I get a quarter mile down the road, and it stops, I drive around some more and everything is good.
Anyone have any idea what could have caused this? It only as about 500 miles on it. You couldn't feel the brake or anything, it wasn't holding back much at all. It was just the highest pitch noise you could think of. A person in front of me pulled over because they thought something was wrong with their vehicle.
I've read that it could be brake dust???
Oh, it's a CGM 2SS/RS
http://img.photobucket.com/albums/v202/paper2302/Siggy.jpg
Paperer is offline   Reply With Quote
Old 07-27-2009, 10:34 AM   #2
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
my GUESS is you had some type of debri wedged in between the pad and rotor and it worked its way out,rock,pebble dirt that kind of stuff,not uncommon
firestone_ss is offline   Reply With Quote
Old 07-27-2009, 11:19 AM   #3
Mr Twisty
Mr Twisty's Avatar
That was the LS3 telling you you're hitting the wrong pedal!
OK, seriously, the other response was probably correct. You can keep an eye on that rotor, make sure it isn't wearing strange.
-- Benjamin Franklin
Old 07-27-2009, 11:55 AM   #4
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
Did your caliper weights fall off?
Old 07-27-2009, 01:12 PM   #5
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
I would tonight park the car and let it cool off for 1 hour or so. The crawl down by the wheel and feel the surface front and back of the disk to make sure it did not get a groove cut in it. I have seen small rocks get in between the pad and disc and do some major damage to the disc. If it cut a deep groove in the disk you pad could start forming a groove in it when braking and cause issue and maybe a locked wheel.
Better safe than sorry. Check it.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-27-2009, 01:29 PM   #6
coolman
Guest
Was the car pulling to one side when this was happening? I know this is a dumb question but did you have the e bake fully released?
coolman is offline   Reply With Quote
Old 07-27-2009, 01:35 PM   #7
Paperer
Ragin' Cajun
Paperer's Avatar
Yeah, you guys may be right, they've been doing a ton of road work everywhere around here, odds are it was some rock or other debris from all the work they're doing.
I'll go take a peek and see if there's any noticeable wear.
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 34 05-04-2016 12:11 PM
Camaro Brembo Big Brake Kit, Installed!! SS Mike Suspension / Brakes / Chassis 125 09-09-2010 01:34 PM
brake dust ssmike Wheels and Tires Talk Sponsored by The Tire Rack 7 09-05-2009 11:44 PM
brake jobs Iroczlover Off-topic Discussions 16 11-03-2008 10:36 AM
