Cold Air Inductions
Old 02-24-2014, 10:15 AM   #1
cliffdog89
cliffdog89's Avatar
Drives: 2LT/RS M6 '12 Camaro
SOLO HFC install questions
I just installed the SOLO HFCs (a shop installed the SOLO exhaust system previously) and I have one problem that I may just live with and could use a second opinion on. The driver side cat butted up nicely to the exhaust system; however, is a 1/2" gap between the passenger side cat and exhaust. I also had to push the exhaust upwards with a fair amount of force to marriage the two pipes together. For now I just bridged the 1/2" gap with the exhaust clamp. The x-pipe is already too close to the passenger side tunnel wall to move the exhaust over. Do you think the clamp is sufficient or should I have a piece welded onto the exhaust pipe? I have also considered unmounting the exhaust system and trying to move up the whole system but I am not sure if this will work as the driver side is flush.
Any suggestions would be helpful! thanks.
cliffdog89 is offline   Reply With Quote
Old 02-24-2014, 10:38 AM   #2
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
When I had the HFC installed, it was done by solo. They did undo my whole system to align correctly. There were no gaps that I saw. It was about 1hour of shifting and moving. Plus I'm a vert which was even tighter because of the undercarriage braces.
When I went SC I removed the HFCs and reinstalled the oem cats due to temp issues and at this time I wrestled with alignment for at least a couple hours.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 02-24-2014, 10:59 AM   #3
cliffdog89
cliffdog89's Avatar
Ok - I will probably unbolt the exhaust and play with things - also, what kind of heat issues did you have? would installing heat shielding help?
Old 02-24-2014, 12:05 PM   #4
KMPrenger
KMPrenger's Avatar
The heat issues are due to his supercharger. Aftermarket cats don't seem to play well with the extra exhaust heat generated by the supercharger and they have been shown to collapse over time. The stock cats, while a bit more restrictive, seem to hold up better to the heat from a supercharger.
Old 02-24-2014, 12:12 PM   #5
cliffdog89
cliffdog89's Avatar
Thanks - I should have figured that out I don't plan on supercharging so I shouldn't have any problems
Old 02-24-2014, 04:28 PM   #6
Nutbutt
Nutbutt's Avatar
No, you shouldn't. I loved the HFCs and the whole solo exhaust. Good luck, just take your time and things will line up.
Old 02-24-2014, 07:08 PM   #7
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Hey Cliffdog, How hard/ easy was the install. Did you do it yourself, ramps, jack stands, or full stocked garage? This is my next mod, I'm just wondering if I'll need a day or a weekend. I've already installed a few exhaust with ramps and jacks in my parking lot. Thanks in advance...
Eddiefuzz is offline   Reply With Quote
Old 02-24-2014, 10:33 PM   #8
cliffdog89
cliffdog89's Avatar
I created a DIY post: http://www.camaro5.com/forums/showthread.php?t=344024 I also link to a couple other threads that have pictures etc.
If you have any additional questions or anything is not clear I would be happy to explain. You should be able to do it on a set of ramps - it will be a little more challenging but doable.
