sjm autoprod
Old 07-27-2009, 02:36 PM   #1
Bryan @ Speed Inc.
Drives: 2002z28
Speed Inc's 2010 Camaro ready to get blown!!!
We just got the car in after lunch for cool down and tear down. We plan to be on the dyno tomorrow. The blower will be the only addition over stock at this time.
some pics
more pics and dyno results to come
Bryan @ Speed Inc. is offline   Reply With Quote
Old 07-27-2009, 02:52 PM   #2
Tran
Administrator
Tran's Avatar
Very nice!! Looking forward to the dyno.
Old 07-27-2009, 05:00 PM   #3
NAHURRY
Love's to Detail
NAHURRY's Avatar
Drives: 2010 SS,97silverado/08crewcab
Watching.
NAHURRY is offline   Reply With Quote
Old 07-27-2009, 08:28 PM   #4
03ss
Drives: 03' Silverado SS/ TBSS 06'
Looks Nice. Any pictures of the heat exchanger for the water? Does the stock intake hook up to the supercharger? Kinda Curious how the Fuel hooks up. Hard to tell from the pictures. Anyone have an idea on what size injectors they are using on this setup. Looks like they finally stopped using the Green tops (42's). wonder how much HP they can support to.
03' Silverado SS
03ss is offline   Reply With Quote
Old 07-30-2009, 03:03 PM   #5
Bryan @ Speed Inc.
Drives: 2002z28
note: The car is stock other then Magnuson blower.
stock induction :
484 rwhp
471 rwhp
added Roto CAI combined with Magnuson tube
518 rwhp
486 rwtq
IATs 95 at the start of the run and 120 at the end
The car will be going to the track tomorrow on a drag radial for testing:devil:
Old 07-30-2009, 03:08 PM   #6
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Nice .... where do you pick up the Magnason Tube?
Thanks,
Crowley
Crowley is offline   Reply With Quote
Old 07-30-2009, 03:21 PM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
NICE! That OEM air box must present a pretty high restriction. It's nice to see other CAI kits will be compatible with this SC; hopefully more can be confirmed as time goes on. Were the only changes the SC and the CAI then? I imagine a tune was included. It'll be interesting to see more numbers with a CB and headers
Thanks for sharing!
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 07-30-2009, 11:41 PM   #8
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
Thanks,
Crowley
I think he means the intake tube included with the Magnuson kit.
Kilo-9 is offline   Reply With Quote
Old 07-31-2009, 07:01 AM   #9
usmcjlp
Drives: 2SS/RS LS3 RJT
Bryan@speedinc,
Please keep posting. Those are pretty impressive numbers. Better than a lot of builds I've seen. I would like to see what happens when a full exhaust system is applied. Do you intend to do anything to the internals? If you have a website for your company, please list it.
usmcjlp is offline   Reply With Quote
Old 07-31-2009, 07:30 AM   #10
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Ahh .. I wasn't aware that the tube came with it ... good to know
Crowley
Old 07-31-2009, 10:10 AM   #11
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by usmcjlp View Post
Bryan@speedinc,
Did Hennessey do a 600 RWHP TVS2300 car with CAI, full exhaust, and 10 psi?
Crowley
I think that tube is to be used with the kit and OEM air cleaner in order to conform to CARB certification.
Old 07-31-2009, 11:31 AM   #12
vsgls1
vsgls1's Avatar
Drives: 07 GMC Sierra
Send a message via AIM to vsgls1
Good data. I see a CAI in my future.
Keith 2SS/RS MN6 in CGM. Delivered 6/22/09. Blown 7/29/09. Sold 12/6/10.
07 GMC Sierra
vsgls1 is offline   Reply With Quote
Old 08-01-2009, 10:05 AM   #13
Bryan @ Speed Inc.
Drives: 2002z28
TRACK RESULTS!
so... bad day to go to the track and try and get a feel for the new setup. The ride was over 2 hrs in traffic and then over 1 hr in tech. We gave the car about a 15 minute cool down and went for it.
car just turned 1000 miles on the trip up to the track
1/2 tank of 93 BP
race weight..I would say 4K
tires were M&H 345/35/18 : http://www.mandhtires.com/store.php?...on=show_detail
2 runs is what I got...Jim got one off and Dan had a clutch pedal on the floor issue.
#1 tried a 3800ish launch with a smooth, but quick clutch release which resulted in a little spin and hop which I quickly pedaled through. I power shifted at approx 6500 ( stock tach ), but it did not seem to like the power shift at times...slight hesitation since I think the flare would hit the limiter. I tried to run out 3rd gear, but just short of the stripe the car nosed over from the limiter.
2.1 60ft
91 1/8
12.38
119.5
#2 was about 1 hr after the above mentioned clutch pedal stuck on the floor for Dan I decided to try it again. The hood stayed shut for the time it was sitting and the clutch still had a horrible smell. I worked the car through staging for about an hr and then finally got the second run. I came out at approx 3200 ( worried about clutch ) with a quick, but smooth clutch release again and had just a touch of spin/hop and stayed in it. The run felt good here...did not power shift 1-2 and shifted about 6200 on all gears + pulled 4th this time.
1.84 60ft
93 1/8
11.87
118.4
We really feel a gear or shorter tire would really help the car work well both on the front and back of the track
so we are very happy with the car considering lack of time last night to get a feel for the car. We will get back out and work the ET some very soon.
Old 08-06-2009, 01:17 PM   #14
Bryan @ Speed Inc.
Drives: 2002z28
updates on the project :
-3.6 6 rib upper ( was 3.8 )
-Innovators 10% overdrive 8 rib truck crank pulley
( we will be going 8 rib at some point )
We also took and modified an 03/04 Cobra HE reservoir for some added cooling capacity. We think it looks good and should help out some.
We are waiting on some LS9 injectors to get us by for now.
CAMARO WIKI Tran Wiki 55 03-28-2017 12:04 PM
2010 Mustang GT vs 2010 Camaro SS Fireball Chevy Camaro vs... 257 05-18-2009 11:04 AM
Tom Henry Racing Announces a Special Edition 2010 Camaro! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 72 04-30-2009 12:57 PM
Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 338 04-15-2009 05:33 PM
Hennessey 2010 Chevrolet Camaro 705-HP!! (HPE700) Caliman93230 5th Gen Camaro SS LS LT General Discussions 172 04-01-2009 06:12 PM
