JUICEDMOTORSPORTS
Old 07-27-2009, 03:38 PM   #1
2010 CAMARO SS RS
2010 CAMARO SS RS's Avatar
Drives: 2010 Camaro SS RS
Thumbs up How to get an LS9 for under $7000!
An LS9 is basically a TVS 2300 Supercharged LS3. So instead of spending $20000+ for an LS9, just buy a Maggie!!You would also get a little more horsepower!!
That is all
2010 CAMARO SS RS is offline   Reply With Quote
Old 07-27-2009, 03:41 PM   #2
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
That is all
Yes and no. LS9 has heavy duty guts, LS3 doesn't.
Hylton is offline   Reply With Quote
Old 07-27-2009, 03:44 PM   #3
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
That is all
Not quite .. there are more differences than that ..
The LS9 is assembled by hand at GM's Performance Build Center, a unique, small-volume engine production facility in Wixom, Mich., that also builds the Corvette Z06's LS7 engine and other high-performance GM production engines.
Cylinder block and reciprocating assembly details
The LS9's aluminum cylinder block features steel, six-bolt main bearing caps, with enlarged vent windows in the second and third bulkheads for enhanced bay to bay breathing. Cast iron cylinder liners - measuring 4.06 inches (103.25 mm) in bore diameter - are inserted in the aluminum block and they are finish-bored and honed with a deck plate installed. The deck plate simulates the pressure and minute dimensional variances applied to the block when the cylinder heads are installed, ensuring a higher degree of accuracy that promotes maximum cylinder head sealing, piston ring fit and overall engine performance.
Nestled inside the cylinder block is a forged steel crankshaft that delivers the LS9's 3.62-inch (92 mm) stroke. It features a smaller-diameter ignition-triggering reluctor wheel and a nine-bolt flange - the outer face of the crankshaft on which the flywheel is mounted - that provides more clamping strength. Other non-supercharged 6.2L engines, such as the base Corvette's LS3, have a six-bolt flange. A torsional damper mounted to the front of the crankshaft features a keyway and friction washer, which also is designed to support the engine's high loads.
Attached to the crankshaft is a set of titanium connecting rods and forged aluminum pistons, which, when combined with the cylinder heads, delivers a 9.1:1 compression ratio. This combination is extremely durable and lightweight, enabling the LS9's high-rpm capability.
Cylinder head details
The basic cylinder head design of the LS9 is similar to the L92-type head found on the LS3 V-8, but it is cast with a premium A356T6 alloy that is better at handling the heat generated by the supercharged engine - particularly in the bridge area of the cylinder head, between the intake and exhaust valves.
In addition to the special aluminum alloy, each head is created with a rotocast method. Also known as spin casting, the process involves pouring the molten alloy into a rotating mold. This makes for more even distribution of the material and virtually eliminates porosity - air bubbles or pockets trapped in the casting - for a stronger finished product.
Although the heads are based on the L92 design, they feature swirl-inducing wings that are cast into the intake ports. This improves the mixture motion of the pressurized air/fuel charge. The charge enters the combustion chambers via titanium intake valves that measure 2.16 inches (55 mm) in diameter. Spent gases exit the chambers through 1.59-inch (40.4 mm) hollow stem sodium-filled exhaust valves. The titanium intake and sodium-filled exhaust valves are used for their lightweight and high-rpm capability.
To ensure sealing of the pressurized engine, unique, four-layer steel head gaskets are used with the LS9's heads.
Camshaft and valvetrain
The broad power band enabled by the LS9's large-displacement supercharger allows it to make strong low-end torque and great high-rpm horsepower, which allowed engineers to specify a camshaft with a relatively low lift of 0.555-inch (14.1 mm) for both the intake and exhaust valves. This low-overlap cam has lower lift and slower valve-closing speeds than the Z06's 505-horsepower (377 kW) LS7, helping the LS9 - with its approximately 620 horsepower - deliver exemplary idle and low-speed driving qualities.
The camshaft actuates a valvetrain that includes many components, including the lifters, rocker arms and valve springs, of the LS3 engine. However, LS7 retainers are used to support the engine's high-rpm performance.
Supercharger and charge cooler details
The LS9's R2300 supercharger is a sixth-generation design from Eaton, with a case that is specific to the Corvette application. The supercharger features a new four-lobe rotor design that promotes quieter and more efficient performance, while its large, 2.3-liter displacement ensures adequate air volume at high rpm to support the engine's high-horsepower aspiration. Maximum boost pressure is 10.5 psi (0.72 bar).
The supercharger is an engine-driven air pump that contains a pair of long rotors that are twisted somewhat like pretzel sticks. As they spin around each other, incoming air is squeezed between the rotors and pushed under pressure into the engine - forcing more air into the engine than it could draw under "natural" aspiration. The rotors are driven by a pulley and belt that are connected to the engine's accessory drive system.
Because the pressurized air is hotter than naturally aspirated air, the LS9 employs a liquid-to-air charge cooling system to reduce inlet air temperature after it exits the supercharger - reducing the inlet air temperature by up to 60 degrees C (140 F). Cooler air is denser and allows the engine to make the most of its high-pressure air charge. The charge cooling system includes a dedicated coolant circuit with a remote-mounted pump and reservoir.
The design of the supercharger case and its integrated charge cooling system was driven by the space and dimensions afforded under the Corvette's hood. To that end, the charge cooler was designed as a "dual brick" system, with a pair of low-profile heat exchangers mounted longitudinally on either side of the supercharger. Coupled with the supercharger itself, this integrated design mounts to the engine in place of a conventional intake manifold and is only slightly taller than a non-supercharged 6.2L engine. The air inlet and rotor drive pulley are positioned at the front of the supercharger.
Additional engine details
Oiling system: The LS9 uses a dry-sump oiling system that is similar in design to the LS7's system, but features a higher-capacity pump to ensure adequate oil pressure at the higher cornering loads the ZR1 is capable of achieving. An oil-pan mounted oil cooler is integrated, too, along with piston-cooling oil squirters located in the cylinder block. The expanded performance envelope of the Corvette ZR1 required changes to the dry sump system also used in the Z06. System capacity is increased and scavenge performance improved to meet the demands of Chevrolet's highest-performance sportscar.
Water pump: To compensate for the heavier load generated by the supercharger drive system, an LS9-specific water pump with increased bearing capacity is used.
Accessory drive system: In order to package the accessory drive system in the Corvette's engine compartment, the supercharger drive was integrated into the main drive system. This required a wider 11-rib accessory drive system to be used with the LS9 in order to support the load delivered by the supercharger.
Fuel system: The LS9 uses high-capacity 48-lb./hr. fuel injectors with center-feed fuel lines. The center feed system ensures even fuel flow between the cylinders with less noise. In order to ensure fuel system performance during low speed operation as well as under the extreme performance requirements of wide open throttle (WOT), a dual pressure fuel system was developed. This system operates at 250 kPa at idle and low speed, and ratchets up to 600 kPa at higher-speed and WOT conditions.
Throttle body: An 87-mm, single-bore throttle body is used to draw air into the engine. It is electronically controlled.
Rocker covers / ignition coils: Unique rocker covers with new, direct-mount ignition coils are used. Other Gen IV engines, such as the LS3, feature coil packs mounted to a bracket. The LS9's direct-mounted coils offer a cleaner appearance and a shorter lead between the coil and spark plug.
Beauty cover: A special engine cover is attached to the top of the LS9. It surrounds the intercooler, which is visible through a hood window, accenting the supercharger while simultaneously reducing noise. The cover has "LS9 SUPERCHARGED" script on the left and right sides, along with a debossed Corvette crossed flags emblem on the front.
Crowley
Crowley is offline   Reply With Quote
Old 07-27-2009, 03:46 PM   #4
2010 CAMARO SS RS
you are right but still it is almost like an LS9
Old 07-27-2009, 03:53 PM   #5
Chevyrocker
Weekend Rockstar
Chevyrocker's Avatar
Drives: Depends on the day...
Damn Crowley...nice work dude.
Shortcuts can slow you down...
Chevyrocker is offline   Reply With Quote
Old 07-27-2009, 03:53 PM   #6
PolishMike
PolishMike's Avatar
Drives: 2010 2SS RS
In the same way the camaro is almost like a malibu.
PolishMike is offline   Reply With Quote
Old 07-27-2009, 04:05 PM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
HEY! I have a Malibu!
I'm sure you can crank up the boost on that LS9 and not spit the pistons onto the street unlike the OEM LS3. Dual-mode fuel system, forged everything, lower compression, and a bunch of other goodies really separate the two.
Hey - you're right about the power though. It's just that LS9 would live longer and would take a lot more. It's funny that it has to run at like 10.5 psi in order to get about the same power as an LS3 on 6 psi. Where's the math in that?!
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 07-27-2009, 04:05 PM   #8
Sales@Hennessey
Sales@Hennessey's Avatar
Drives: 2010 Camaro
Send a message via AIM to Sales@Hennessey
This is not true at all!
http://www.autoblog.com/2007/12/19/d...e-ls9-is-born/
Sales@Hennessey is offline   Reply With Quote
Old 07-27-2009, 04:07 PM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
JT - what's a safe limit on an LS9?
Old 07-27-2009, 04:11 PM   #10
SSINSTR
Michelin Man Assassin
SSINSTR's Avatar
Drives: '10 IBM 2SS/RS LS3
The LS3 and LS9 essentially just share the block and displacement. However, the LS9 is over-engineered (a good thing in this case) as Chevrolet wanted to maximize the 6.2's performance while still retaining the driveability and reliability of a base C6. Sure you could strap a 2300 on a LS3 and put a fully forged rotating assembly and it would exceed the power of a LS9. But... it's the little things that make the LS9 what it is: The pinnacle of small block engine technology. Besides, something about a factory forged engine just sends chills up my spine.
SSINSTR is offline   Reply With Quote
Old 07-27-2009, 04:14 PM   #11
Sales@Hennessey
Drives: 2010 Camaro
We are able to get over 750 so far with the LS9!
Old 07-31-2009, 08:20 AM   #12
JDBeck23
Drives: 2010 Camaro, 2SS/RS
Then by all means, slap a TVS 2300 on your LS3 and crank the boost up... and wait for the pistons to go BOOOM!
The LS9 is purpose built for a big positive displacement supercharger. The LS3's hyper eutectic pistons and 10.ish:1 compression, plus boost, creates a non wallet friendly situation.
If you wanna build an LS3 up to hold the boost, then im sure you could gitter-dun for cheaper than the cost of an LS9. But I believe it's part prestige to tell people that you got an LS9 under the hood. It just sounds better than saying, I have a built LS3 with a TVS 2300 running XX lbs of boost... See how much easier it is to just say "LS9" than all that?!
2010 2SS/RS CGM
American Racing Headers, Magnaflow axle back, Roto-Fab CAI, Audio Integrations Sub box, Alpine Type R 10, Alpine MRP-500 amp, Pro Clips iPhone Mount
JDBeck23 is offline   Reply With Quote
Old 07-31-2009, 11:21 AM   #13
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Word. That LS9 is running 10.5 psi of boost if I remember correctly, and I'm not sure an OEM LS3, even with a spot-on tune, is going to last as long as that engine will. That engine is so over-built, it's crazy. If I could just get an LS9 shortblock, add some GMPP ported heads with the 2300, that'd be pretty bad@$$.
Old 07-31-2009, 11:31 AM   #14
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
You can get anything you want .. you just need the $$$
Crowley
Get your LS9 Crate Engine for only $21K Caliman93230 Forced Induction - V8 7 02-21-2009 11:46 AM
stock ls3 vs. a ls9 w/ no charger? 454lsxss 5th Gen Camaro SS LS LT General Discussions 4 11-01-2008 06:05 PM
Advice---Supercharged L99, S/C'd LS3 or LS9? CamaroZR1 Forced Induction - V8 25 09-25-2008 10:21 AM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 05:35 PM
It's official: ZR-1 LS9 engine makes 638hp / 604tq !! Tran General Automotive + Other Cars Discussion 28 04-29-2008 06:38 PM
