SDTW Custom Wheels & Tires
Old 03-28-2008, 06:18 PM   #1
SSNIGHTMARE
SSNIGHTMARE's Avatar
Drives: 2002 SS Camaro
LSA marine link
http://www.gm.com/explore/technology...LSA_Marine.pdf
SSNIGHTMARE is offline   Reply With Quote
Old 03-28-2008, 11:48 PM   #2
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
notice the torque line from ~2500 - 5000 rpm? Sure its just an estimate but still . . .
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 03-29-2008, 08:50 AM   #3
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
I need the part number... I wonder what a 4th gen Z28 would be like with one of these?
got tequila?
SilverTurtle is offline   Reply With Quote
Old 03-29-2008, 01:06 PM   #4
Mythic
Mythic's Avatar
Drives: '03 Monte Carlo SS
http://www.cadillac.com/cadillacjsp/.../news_ctsv.jsp
for the '09 CTS-V
Engine
Type: 6.2L supercharged V-8 (LSA)
Displacement (cu in / cc): 376 / 6162
Bore & stroke (in / mm): 4.06 / 103.25 x 3.62 / 92 mm
Block material: cast aluminum
Cylinder head material: cast aluminum
Valvetrain: overhead valve, 2 valves per cylinder; 0.492-in (12.5 mm) lift
Supercharger: Gen. 6 R19 with single brick intercooler; 1.9L displacement w/4-lobe rotor design
Fuel delivery: SFI; center feed
Ignition: direct-mount ignition coils; extended-life dual platinum-tipped spark plugs
Compression ratio: 9.0:1
Horsepower (hp / kW @ rpm): 550 / 410 @ 6200 (est)
Torque (lb-ft / Nm @ rpm): 550 / 745 @ 4000 (est)
Recommended fuel: premium recommended but not required
Maximum engine speed (rpm): TBD
Additional features: pan-mounted oil cooler; cast pistons; high-flow cylinder heads; block-mounted piston squirters; steel crankshaft w/ 8-bolt flange; close-mounted converters; acoustic engine cover; E67 engine controller
Mythic is offline   Reply With Quote
Old 03-29-2008, 07:00 PM   #5
SSNIGHTMARE
It's definately a nice looking motor
Old 03-30-2008, 02:17 AM   #6
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
This is all I want....PLEASE!!! It's not asking too much, is it?:(
GMHTP '09 CTS-V Gets 550+HP LSA! TAG UR IT General Automotive + Other Cars Discussion 8 02-28-2008 10:47 PM
Cadillac LSA pictures - directly from GM Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 01-22-2008 08:22 PM
All this LS9, LSA, and DI Speculation. Good53X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 12-12-2007 02:42 PM
